Aquaman92
01-21-2020, 09:22 PM
want to upgrade my props on my zelos36 what is the best for quick lift and better speed have been reading about cuped props ??? anone used them
fweasel
01-21-2020, 10:12 PM
Simple upgrade is a pair of Octura x447 props which will bump you up to about 70ish on a stock boat with good batteries. The ABC 1715 props are a step up from there, more speed, less run time. You can go up to the ABC 1716's for really fast passes, but I wouldn't recommend them unless you have the newer 3831 motors, and they're only good for a few straight line passes than back to the dock before things overheat. PM member Dasboata, he can get you setup with whatever prop you choose.
