View Full Version : Miss Geico 36 twin
Mr Zelos
01-18-2020, 01:24 AM
I?m wanting to try some 3 blade CNC stainless props on her. Anyone have any suggestions.
Running
2-3s 9000mah in series to 6s with splitters.
2- dynamite 120a esc
2- dynamite 4 pole 1900kv at 11deg timing.
https://uploads.tapatalk-cdn.com/20200118/93f54991d3df91209199997fe47dd957.jpg
Aquaman92
02-05-2020, 09:08 PM
https://www.ebay.com/itm/645-3-3D-Pro-Boat-Zelos-36-Twin-champion-propeller-stainless-steel-prop-RC-boat/223750862736?hash=item3418973790:g:Hi0AAOSw38Vbp-tM might work! im looking to get these on my Zelos and im pretty sure theyd work - look pretty too, very well made props I have the same sellers polished and sharpened prop for my sonicwake and it gets up on plane mush faster!
Also - how are you liking that oxidean tubing? did you have to put different sized inlets/outlets to make sure they fit? or is it the same inner diameter as the stock tubing? Im looking to get colored tubing and I want to make sure i get the right ones!
tpworld
03-06-2020, 07:55 PM
I recently put the oxidean marine tubing on my geico 36 and it fits but due to larger inner diameter it requires some small zip ties to make sure it stays!! I also drilled stock fittings inner diameter slightly larger to promote better cooling as well..
