View Full Version : Control Rod Boot
sundog
12-21-2019, 10:32 PM
Here is a generic control rod boot I designed that you can print with TPU flexible filament. Use a 4mm or smaller nozzle and print slowly - 10mm/s would be good. CAD design is a hobby of mine - if you think of something useful, shoot me a PM and I may give it a go.
M3Bluegsr
12-22-2019, 04:20 PM
Here I made a hull fitting, might fit this boot. 8mm Cylinder x 11mm Length with a 7mm hole.
Norwest
12-26-2019, 08:54 AM
Many years ago ,i used airplane 1/8" plastic pipe ( I call it ) and drilled a 1/8" hole with correct alignment from servo to arm of rudder. Now you may have to bend the piano wire a little but works great. Just put grease in the plastic pipe. I don't know the correct name for pipe. Later I will give the answer after breakfast. I to had problems with boots that ripped. Now a gentleman from Canada told me of this idea, good for him!
