Santig
12-17-2019, 10:24 AM
Good morning gents. Could someone please direct me to a replacement flex shaft. The skunkworks 32 I just received has a busted shaft. Luckily I was wise enough to check it before running her. The flex shaft was sliping even with the coupling tight and the saver had a striped nut and had to remove the motor to pull it out the other end. It came apart where the metal peice conects to the shaft. I also think it has no stuffing tube .Here is the size I am looking for. Thank you in advance.
167404
167405
167407
167404
167405
167407
