stac1627
10-13-2019, 04:27 PM
I could sure use some advice...I'm not an electronics guy by any means.
I hope I explain whats going on correctly.
I'm running twins...two OSE Raider 6s 150amp Esc's powering two motors.
When I squeeze the throttle both motors smoothly accelerate to full speed. In about 5-6 seconds the port motor cuts off...if I quickly go back to neutral and accelerate in the same fashion the same thing happens. Since the scenario can be reapeted over and over I'm thinking there is a programming issue with the port ESC?
I made a plywood mock-up of the transom last year to mock up the drives and motors with power...all went without issue but now that I'm finally installing the drive components into the finished hull there's issues...166731166732
