View Full Version : No speed at full throttle / high RPMs
rahulbpatel
09-08-2019, 01:43 PM
I?ve got an American Express a.k.a. Henglong 3837 Atlantic boat that I?m trying to upgrade with new drive shafts and propellers. When I start out slow the boat moves ok but when I get past 1/2 throttle there is no pick up and it looks like the propellers are creating splash but not pushing water. It has a twin motor setup spinning in counter rotation with 3 blade 36mm propellers. These are the propellers I installed:
uxcell RC Boat Propeller 4mm... https://www.amazon.com/dp/B06XJ3SWSH?ref=ppx_pop_mob_ap_share
Not sure what?s wrong. Is this what cavitation is? It originally came with 2 blade propellers that worked fine but one broke. Should I just go back to 2 blade propellers?
I know these boats can go much faster there are YouTube videos of it on the internet:
https://m.youtube.com/watch?v=Jesq0AfZdoA
https://m.youtube.com/watch?v=vn22QfI3bjc
Totally new to RC boating so any help is appreciated. TIA!
09-08-2019, 04:42 PM
Not all propellers are created equal, even with the same diameter, pitch and number of blades. The most likely explanation is poor propeller design which is causing severe cavitation. First, install the original propellers and see if that works. Next try a set of decent quality props like the CNC variety OSE offers.
I am nor familiar with that boat or the specs on the original props, but you should be able to upgrade performance with the right props, 2- or 3-bladed. The risk is that as you increase prop diameter, pitch or blade number you will stress the motor, ESC and packs. So, you can go too far and break something.
I know this is pretty general but I won’t recommend props unless I know more about the boat. Have you looked at YouTube videos for modifying this boat?
TRUCKPULL
09-08-2019, 07:04 PM
You said that some videos show the boat going a lot faster then yours.
The differance between the two videos that you listes is the boat in the upper video has been modified with brushless motors and ESC;s to match.
Here are the replacment props.
http://www.heli-parts.com/3837007-propellers-replacement-spare-parts-accessories-for-hl-henglong-3837-atlantic-yacht-35kmh-3ch-double-motor-speedboat-remote-control-rc-high-speed-boat-model-p-14507.html
Larry
rahulbpatel
09-09-2019, 12:22 AM
Thanks for the replies. One of the original props broke which put me down a big rabbit hole. I thought instead of getting replacement ?toy? props, I would do a few upgrades as seen on YouTube. I ended up ripping out the original drive shafts and replacing them. The original props don?t fit the new 4mm shafts.
I can try different props but wasn?t sure what direction to go in. 2-blade vs 3, pitch, size, etc. So the problem I?m describing does sound like cavitation? Ill try to take a video of it and post it here.
Thanks!
