View Full Version : Zelos 29
CharlesR
05-10-2019, 09:51 AM
Leveled strut with hull bottom On 4 cell shes fine on 6 cell shes taking flight any help would be appreciated
fweasel
05-10-2019, 09:18 PM
Are you talking about a Zelos 36 or a Veles 29? Because you mentioned a single strut, I'm assuming its the Veles. There are two primary ways to keep a catamaran hull from flipping at higher speeds. You can try adding in a small amount of negative trim angle on the strut, which would point the rear of the strut and prop down, and the front of the strut up. This will force the bow of the boat down, counteracting the additional air being packed under the tunnel at 6S speeds. Another option is to slide the batteries forward in the trays, towards the bow, to shift the center of gravity forwards.
CharlesR
05-11-2019, 06:15 AM
Velos 29 yes to u I've tried the battery placement .I'll try the strut tip this weekend Thank you
