View Full Version : "The Gecko" aka Miss Geico
ScottSpanker
04-10-2019, 12:08 AM
Just finished polishing the clearcoat on the new paint. Time to get busy. She's gonna be a twin. I've had this one in the works for about 3 years and have had the parts and hardware for over 2 years. I'm also planning on machining some pretty cool stuff for her too. Oh, and this was my first crack at a professional paint job. What a learning curve. Lots of mistakes.
meangenesracing
04-10-2019, 07:32 AM
I like the gold. What kind of paint did you use and do you have the paint code?
larryrose11
04-10-2019, 08:55 AM
Great work. Painting well is not easy
ScottSpanker
04-10-2019, 09:12 AM
Thanks guys. Createx auto air. Candy pigment yellow shot over metallic gold. Hotrod sparkle white mixed 50/50 intercoat clear shot over whole boat. Summit high solids clear coat. Mini hvlp touch up gun with 1.2 nozzle.
fweasel
04-10-2019, 11:05 AM
That paint job will not be hard to spot out on the water. Nice work.
ScottSpanker
04-21-2019, 12:00 PM
164888164889 Starting the build. I weave plain. A little on the wet side but layed down pretty nice.
ScottSpanker
04-22-2019, 08:52 AM
164901164902 The hatch. Again a lil on the wet side but got it to form to the lip pretty well.
ScottSpanker
04-26-2019, 08:55 AM
164935164936 sponson stringers. Carbon kevlar. Got it layed out, now I'll throw it on the mill. I still need to cut the middle one for the bow.
fweasel
04-26-2019, 05:53 PM
Those templates are my least favorite part of reinforcing a hull. Depending on the room and access, they can be a real pain to make.
ScottSpanker
04-27-2019, 09:15 AM
How right you are. Such a necessity in a high speed setup, and such a pain to fabricate and install.
ScottSpanker
04-27-2019, 03:14 PM
164942164943 The process of cutting the design and the finished product. I gotta be honest, this was my first time carving up carbon kevlar and it will probably be my last. The kevlar doesn't leave a nice finish like carbon fiber. I had the material so i decided to use it. Good enough for stringers.
ScottSpanker
07-15-2019, 09:54 PM
165801 Stringer's mounted.
ScottSpanker
07-15-2019, 10:00 PM
165802165803165804 Roughing out the motor mounts and getting dialed in.
ScottSpanker
07-15-2019, 10:11 PM
165805165806 Strut time!
fweasel
07-15-2019, 10:18 PM
Coming along. It's going to look mean once those drives are mounted.
ScottSpanker
07-15-2019, 10:24 PM
165807165808 Had a lil bit of a problem with one of my water jackets fitting. It was a thousandth under the motor. The other one fit fine however was a bit different in design with the same part#. Weird. Had to bore it out quite a bit. I'm not into the interference fit.
ScottSpanker
07-15-2019, 10:28 PM
Thanks. I'm getting to those pictures as we speak. I've been procrastinating posting the progress. I have a bunch more.
ScottSpanker
07-15-2019, 10:36 PM
165809165810165811165812 Mocking up the motors, struts are on!
ScottSpanker
07-15-2019, 10:43 PM
165813165814165815 Motor mounts in, stuffing tubes in.
ScottSpanker
07-15-2019, 10:50 PM
165816165817165818165819 Machine time! Transom mounted strut braces or clamps, whatever u want to call them.
ScottSpanker
07-15-2019, 10:53 PM
I'll post more later. The clamps are still unfinished in these pictures, but u get the idea! :rockon2:
fweasel
07-16-2019, 12:03 AM
Oh, such wonderful tools
ScottSpanker
07-16-2019, 07:27 AM
Yeeesss! I love em!
ScottSpanker
07-16-2019, 07:34 AM
165842165843 Putting the final touches on the clamp.
ScottSpanker
07-16-2019, 07:44 AM
165844165845165846 Clamps finished up. Preparing to drill and install T or blind nuts.
ScottSpanker
07-16-2019, 07:55 AM
165847165848165849 Rudder bracket just finished.
ScottSpanker
07-23-2019, 08:02 AM
165912165913165914165915 Cutting and chamfering the struts. All mounted up. Not too bad if i do say so myself. Almost ready for powder coat.
NativePaul
07-23-2019, 03:58 PM
Wow!
I've never seen so much time effort and skills put into modifying an RTR before, it looks like you have done a proper job there.
I really hope it holds up with all the reinforcing you have done, but don't forget to fill it with flotation of some sort, so the worst doesn't happen if a bit you cant reach with reinforcement gives way.
ScottSpanker
07-24-2019, 08:10 AM
Wow!
Thank you much Paul. It's true that once upon a time she was a RTR, but now i think she no longer knows the meaning. Hehehe! I had a lot of hours into truing the bottom when i originally put her out of commission. The plan was to bring her back as a twin. I really tried to put my best for forward on this one. As for the flotation i use loctite expanding foam in the sponson tips and bow. It also helps with structure. Then I'll fill the rest with pool noodle foam.
ScottSpanker
08-09-2019, 07:54 AM
166217166218 Got the water pick ups cur, bent, and soldered.
ScottSpanker
08-09-2019, 08:05 AM
166219166220166221166222 Moving right along. Servo mount, carbon posts with nylon inserts. Just finished the dress up washers.
ScottSpanker
08-09-2019, 08:39 AM
166223166224166225166226166227 Just finished the servo mount , carbon posts with nylon inserts. Spun up some dress washers too. Couldn't have done it without the help of Taylor, "Big Mister".
fweasel
08-09-2019, 01:58 PM
The orange epoxy is a nice touch. Did you make your own brass barbs for the water pick-ups? If so, how did you make the cone pieces? I ended up just soldering on a small section of brass tube one size larger to give the hose something to bite on.
ScottSpanker
08-13-2019, 06:11 PM
No i didn't, but that's not a bad idea. Nor is the way you're doing them. That works too. I think i could cut my own tho, using the rotary table and like a 60° dremel burr, or something of that nature. I had purchased these from OSE. Quick and dirty! Thanks for the compliment. I dumped a lil createx in the g flex. Makes it a little stringy and a tad thicker too especially with micro fibers in it.
ScottSpanker
09-05-2019, 01:04 AM
I'd love to share some of my recent progress, but for some reason every time i upload it says "upload failed". Any suggestions?
ScottSpanker
09-14-2019, 12:37 AM
166492
ScottSpanker
09-14-2019, 11:51 AM
Alright! I'm back to posting pictures. A little more of my progress, and some more handy work on the mill.
ScottSpanker
09-14-2019, 12:28 PM
166508166509166510I got the linkage close. A little more tweaking and I'll have it. What a long drawn out process fabricating the servo horn, clevis, and pins out of stainless steel socket heads.
Mike W
09-15-2019, 08:09 AM
Your machine work is gorgeous. What machine tools are you using? I'd love to have a small lathe/mill someday.
ScottSpanker
09-16-2019, 05:02 PM
Thank u so much Mike. I use a lot of 3 flute small diameter end mills 1/8",3/16",1/4", serrated flutes for roughing. Drill point 2 flute end mills 90?and 82? for chamfering, spotting and fine finish. I'll post some pictures of some of my favorites later.
Alfa Spirit
09-16-2019, 11:35 PM
Cool KBB style small cat.
ScottSpanker
09-18-2019, 12:05 AM
I'll take that as a huge compliment, thank you. I learned a lot watching his builds. It's a shame his forum doesn't exist anymore.
ScottSpanker
10-05-2019, 08:54 AM
166690166691166692A little more progress. Esc mount painted and ready for clear coat. I quick look at half the power plant. We're sneaking up on it. Won't be long now.
ScottSpanker
10-15-2019, 10:25 PM
166739166740166739166741 Moving right along. Carbon posts for esc mount are in. Got the mount all cleared up. The carbon really comes to life under some high solids clear.
ScottSpanker
10-19-2019, 12:11 AM
166746166747166748 Power plants hooked up!
ScottSpanker
10-22-2019, 08:41 PM
166798 The race gas arrived today straight from Singapore!
fweasel
10-22-2019, 11:15 PM
Nice. I always got pretty quick shipping direct from Revo.
ScottSpanker
10-31-2019, 11:10 PM
166867166868166869 Got all the soldering done. That was a lot of work. Gonna start routing wires and start plumbing.
ScottSpanker
11-06-2019, 08:06 AM
166956 I'm not the only one dreaming of finishing this thing. Sometimes he even helps! :banana:
Rayhynes
06-22-2020, 04:38 PM
Hay man if you don?t mind where did you get the outdrive made and your rudder
ScottSpanker
06-22-2020, 07:49 PM
I machined the strut standoffs, rudder standoff, and rudder on my benchtop mill. There should be pictures of all this being made except the rudder, i forgot to snap some pictures of it. Struts are OSE 3/16" cut down and turned the bevel using my rotary table. Should be some pictures of this as well.
