MarcosAC
04-03-2019, 03:55 PM
Urgent help with ESC Seaking V3, from 180A (to fail)
on April 2, 2019
I live in Brazil (I'm sorry for English errors), I'm trying to build a TFL Genesis, but with a lot of problems, I think it's ESC:
Propeller Shaft: OSE
Engine: SSS 4082 2200KV
Lipo battery: 2 x 3S - 50C 6000mha
Propeller: 1716 from Pro Boat (from Veles) and X642 (octura).
ESC: SeakingV3 180A
ESC Settings:
1 - Forward and Backward (default)
2 - Auto Calculate (default)
3 - 3.2V/Cell (default)
4 - Timing modified to 7.50° (default is 15.00°)
The boat fell into the water - soon after 10 seconds it started to fail, I believe it is ESC.
You have a video and pictures attached.
Can someone help me? Did I do something wrong?
I think I'll go back to the lake now (after lunch) and try other settings .
Is it true that this ESC fails anyway?
to complete: At other times, the ESC failed (quick cut) but the boat did not stop. ESC, Engine and batteries did not heat up. The only thing I noticed that warmed up a bit was the two capacitors in the wiring of the ESC.
https://youtu.be/6G1IdaSMq_A
Lipo battery: 2 x 3S - 50C 6000mha = 22.2v
Propeller: 1715 dasboata.com
ESC: SeakingV3 180A
ESC Settings:
1 - Forward Only (default forward and backward)
2 - 6S Lipo Cells (default auto calculate)
on April 3, 2019
Hi all,
Today I did several tests, unfortunately all without success.
It was running with 2 5600mA 100C - 7.4v (2S) batteries.
Notice in the video that with the boat "totally cold", in 8 seconds it already fails ...
1st test - ESC configuration:
2 - S4
2 X 5600mA 100C - 7.4v (2S) batteries
I then moved to:
2nd test - ESC configuration:
2 - S4
3 - LVC
Unfortunately I do not have this video, but the boat kept crashing, I accelerated at most, it was too slow for 4S (but it was fast, I mean slow because it was a SSS 4072 2200KV engine). It ran for just over 1 minute, stopped for a few moments ... but there was no speed expected from this configuration. After 1 minutes the boat stopped. I had to rescue him.
When I opened it, I noticed that the battery plugs melted ... check the image. It melted not only the plugs, but also the battery case. But it was not fast for this havoc.
3rd test - ESC configuration:
2 - S6
3 - LVC
2 X 6000mA 100C - 11.2 (3S) batteries
in 5 seconds it failed again, I returned with the boat.
4th test
2 - S6
3 - LVC
4 - Timing modified to 3.75.
I have 2 things to do and I wanted suggestions:
Remove this ESC and put a Flycolor 150A (it's the only one I have in Brazil for now);
or
Redo the connections (solder again - I thought there might be some failure in soldering of the EC5 pulgs ...
On redo soldering of the plugs - it is laborious and I will lose the plugs that I soldered, but it would be possible in this picture (which burned / melted 2 2S batteries (the plugs) having failed my solder? These plugs that I soldered did not melt, I believe that the service is good ...
thanks
Marcos A Corbi (from Brazil)
164541164542164543164543164544164545
on April 2, 2019
ESC: SeakingV3 180A
ESC Settings:
ESC: SeakingV3 180A
ESC Settings:
on April 3, 2019
Hi all,
2 - S4
I then moved to:
2 - S4
3 - LVC
2 - S6
3 - LVC
4th test
2 - S6
3 - LVC
or
thanks
