View Full Version : Total noob 1/8th scale ML 172 extreme
Tetefroid
10-22-2018, 09:15 PM
I got a box of sticks that that some how will become the 2013 oh boy! Oberto. 162196
Tetefroid
10-22-2018, 09:19 PM
162197 This looks like a good place to start. How can I screw this up? Fits perfect in those little dotted lines.
Tetefroid
10-22-2018, 09:26 PM
162199 More dotted lines(I can do this)(maybe)!
Tetefroid
10-22-2018, 09:37 PM
162200 162201 162202 Soo clean...except where I touched it, with my gluey fingers. Yes yes, the motor will go here and the batteries will go there, it will be wonderful. More dotted lines.
Tetefroid
10-22-2018, 09:46 PM
162204 It was all going so well, and then a beavis and butthead moment...ummm..uh..huh-huh-huh..what the hell does this mean?
Twood69
10-24-2018, 10:37 AM
How are you going to install and remove batteries once the motor in installed?
Tetefroid
10-24-2018, 11:45 AM
162220 Just to clarify and qualify anything you see and read from me here; I have no idea what I'm doing...but to your question, I am removing a portion of the frame, to gain access. And I will put back what I cut out, a bit further back, for strength.
don ferrette
10-24-2018, 03:12 PM
Here's a couple pics from the ML Elam I did a short while back. The packs were forward of the motor/ESC with just enough room to lift them in and out. Hope this helps....
Tetefroid
10-24-2018, 10:57 PM
Wow! That is a real nice job on that Elam. Did that kit have cockpit inside frames, that dipped down for, I am assuming, the rear sponson outline? like this? 162245
don ferrette
10-25-2018, 02:29 PM
Actually no I had to hand make mine
Tetefroid
10-27-2018, 01:27 PM
Don, thank you for that. I am struggling with those rear sponsons, especially the left side (on the 1/8th scale) because the frames on the 172 extreme kit do not allow me to make the rear sponson to scale, or make them look like the real ones anyway162329. The real ones turn out and up and are kind of 1/4 torpedo shaped, while yours, and the way I'm forced to do mine, with the frames the way they are, is to turn in and up. And then they are to long to make it look like the real ones. Ugh and I am confused by just trying to describe it. lol. I wish I understand the intention from ML.
785boats
10-28-2018, 01:07 AM
Tetefroid.
There is a bit of detail in post #23 & post #33 on how I did mine in this build thread, if it is of any help. Pretty much the same as Don I think.
https://forums.offshoreelectrics.com/showthread.php?58559-U-3-1-8-scale-Hydroplane
Tetefroid
10-28-2018, 02:23 PM
[QUOTE=785boats;727666]Tetefroid.
785boats, if that truly is your real name,(lol just kidding) Thank you for the example, I am not there yet, but I think you have inspired me to use that cockpit you used for mine (we'll see). But back to these tricky rear sponsons: hope you don't mind, I stole a picture of your rear pads:162361 to use for an example of a question I have, so the boat will turn right, meaning the transom will slide left, did you install a fairing on your left pad to keep the rear from "tripping" in the turns, and how did it turn out?
785boats
10-28-2018, 08:22 PM
He!He! No. The real name is Paul.
I left the ride surfaces flat.
If you go to post #9 & watch the video of them flipping over the boat, you will see that they are flat. Just pause the video at various stages.
I know it is a different boat but they are basicaly the same hull. Just without the big holes in the main tub.
The boat isn't finished yet, so it is untested.
Cheers.
Tetefroid
12-01-2018, 09:11 PM
Cheers.
162821 Hey Paul, this is the best picture I could find so far, not a great one, of the slide side of the rear sponsons. As you can see it's seems to be a two piece fairing so the rear sponson does not "trip" in the turn. The other side is a one piece fairing and is flat.
Twood69
12-01-2018, 09:45 PM
162822
Tetefroid
12-03-2018, 11:16 AM
Thank you. Man that was such a beautiful boat! R.I.P. Bernie. I'm having difficulties scaling those rear sponsons, that's a great picture but the angle makes it hard to determine the size.
Tetefroid
12-30-2018, 05:01 PM
Shaping the left rear sponson, non-trip fairings. Tricky for someone who lacks the skills like me (and a good picture to go by):163185 163186 163187
Tetefroid
02-03-2019, 09:53 PM
163749 Woa....WTH fellas...used this 30min epoxy for the sponson step, clamped her down for 6 hours, removed clamps and it pop off. And I did sand both surfaces before i tried to glue it...any ideas?
mpschofield
02-04-2019, 05:05 PM
30 min slow epoxy can be handled after 8 hours. Full cure time is 24 hours. Sounds like you did not wait long enough. 30 min is just your working time.
Something you may want to try in the future is titebond iii. Just as strong as epoxy and much quicker bonding times. Must be wood to wood bond.
Sent from my SM-G965U using Tapatalk
Tetefroid
02-04-2019, 09:50 PM
That stuff looks promising, I'm going to order a bottle and check it out. Thank you for the suggestion.
Tetefroid
03-11-2019, 12:19 AM
Been working on the sponsons, those compound curves are a pain, especially when trying to clamp the sheeting....164191
Tetefroid
03-11-2019, 12:25 AM
Did the sponsons steps: 164192 I haven't done the runners yet : 164193 164194 Gawd that camera makes it look awful...and maybe it is...I need glasses.
Tetefroid
03-11-2019, 12:38 AM
Also did the top decks finally, did an experiment with the spray foam and the total boat epoxy I am using for the decks, It seems the Epoxy will adhere very well to the spray foam. Not sure if I can just use it in place of 3/16x3/16 and 1/4x1/4 stock, glued to the frames or not...164275 164276 164277
bogieboy
03-11-2019, 12:42 PM
second the Titebond.... it has held together 5 of my guitars and a banjo (2 of them headstock repairs, taking all the string tension) for many years now... all of these have been repaired with Titebond...
164211
Tetefroid
03-12-2019, 04:25 PM
Nice. I will be using that stuff on my next boat, for
sure.
Tetefroid
05-11-2019, 11:56 PM
165076 Does anyone know if there needs to be a belly pan installed on this 172 extreme kit? Does anyone have any pics on how they did that on this particular kit?
meangenesracing
05-12-2019, 09:41 AM
None on mine
Tetefroid
08-31-2019, 11:54 PM
https://youtu.be/9iFuU8vluTU I got a chance to test this thing today, wanted to make sure it would go straight and handle safely. Ran it less than two minutes, 3 times. Thing keeps coming back HOT. ABC H2215 prop, 8s, 5000mah, one set 45c and a set 50c, 130a Seaking-HV-V3, HET Typhoon 700 Series 840KV FE Motor. Motors comes back really hot (it would burn you if held it for more than a few seconds) to the touch same with batteries, I did not have a temp gage with me so I don't know the actual temp, but you wouldn't want to put them down your pants. After a less than two minute run....this doesn't seem right... ?
don ferrette
09-01-2019, 09:05 AM
Which 2215? That is a somewhat aggressive prop regardless. I would start by propping down some and see if the heat comes down.
Tetefroid
09-01-2019, 10:26 AM
Hey Don, it's a 2215-19-38 2 blade...I don't know too much about props yet, but I had asked for a fairly mild one, when I ordered it. But if this is a "somewhat aggressive" one, then looks like I might be maxed out for speed with this set up, without burning up stuff, unless my strut is out of wack too...or something, IDK.
don ferrette
09-01-2019, 02:10 PM
Hey Don, it's a 2215-19-38 2 blade...I don't know too much about props yet, but I had asked for a fairly mild one, when I ordered it. But if this is a "somewhat aggressive" one, then looks like I might be maxed out for speed with this set up, without burning up stuff, unless my strut is out of wack too...or something, IDK.It's a 56mm diameter but a 1.5 pitch progression. If you can find or borrow one try a de tongued Octura X455 3 blade to get dialed in on. Does your ESC have data logging?
Tetefroid
09-01-2019, 04:47 PM
I will give that Octura prop a shot. No data logging with the BEC I have as far as I know.
