View Full Version : abs repair/ receiver pack
Jeepers
06-03-2007, 08:59 PM
I have a cambell shovel nose that just hit the shore (rock) and it has a huge hole
(3"x .5") any ideas on how to repair this? I am good at repairing glass hulls but never repaired abs before. I could just buy a new hull but am low on cash and next race is 3 weeks away. any help appreciated thanks.
has anybody have a receiver pack just fail, like the cell end coming off? this is an hpi 1200mah pack, the cause of the above crash:mad:
Doug Smock
06-03-2007, 10:11 PM
Can you post a pic of the damage??
Doug
Piranha2
06-03-2007, 10:17 PM
:eek: Doug would your avatar be an indication of how you know what Jeepers is going through?:D
Doug Smock
06-03-2007, 10:27 PM
LOL,Yeah, that happened when I was tuning my Titan 29 for the 1/6th mile oval we are running on now.:eek: I think that pic is on the second bounce. :rolleyes:
I've got her dialed in for those long straights now.;)
Doug
Piranha2
06-03-2007, 10:34 PM
huh? I just bought a Titan 29 :eek: is that what I have to look forward to :mad:
Doug Smock
06-03-2007, 11:25 PM
You won't be disappointed !!!! You have to understand I have this boat screaming.:D
What are you going to power it with?
We are stomping all over Jeepers thread. Sorry sir.
Doug
Rex R
06-04-2007, 03:17 AM
think I would go down to the local hardware store and; buy a cheap yard sign(for sale), and a can of 'abs pipe cement'. cut and glue a piece of sign over the hole(preferably from the inside) then use the pipe cement like 'bondo' (use thin coats)till I got a nice smooth patch. paint as needed. hth
rex
Piranha2
06-04-2007, 07:13 AM
7XL hydra 240
Doug Smock
06-04-2007, 08:03 AM
7XL hydra 240
I sent ya a pm.
Jeepers
06-04-2007, 09:04 PM
Doug Not a problem I kinda like when things go off track sometimes, some one always posts an interesting idea or something!
Jeepers
06-04-2007, 09:05 PM
D Smock nice avatar pic on RRR I cracked up when I seen it.
Jeepers
06-04-2007, 09:08 PM
Doug i will see if I can get a pic on tonight/ tomorrow :)
avengersteve
06-04-2007, 09:46 PM
has the pack ever gotten wet? i had one fall apart on me after boat was capsized for about 10 min
Doug Smock
06-04-2007, 10:04 PM
That is my 4th grade school pic. LOL:eek:
Doug
saleens7
06-04-2007, 10:22 PM
whoa...i just saw the pic.....:D :p ...
Jeepers
06-04-2007, 11:37 PM
here is the hole:( please keep in mind that the I have removed alot of the damaged plastic so that I could see the damage done to the wood structure.
Jeepers
06-04-2007, 11:38 PM
Doug heheheheh!!!!:D
Jeepers
06-04-2007, 11:40 PM
:p are you related to a wookie?:p hehehehe!
Jeepers
06-04-2007, 11:46 PM
yeah when I had a crack in my hatch. but what do you mean by fall apart? this pack looked like the end of the cell just fell off. (sorry no pic already disposed of it)
avengersteve
06-05-2007, 01:11 AM
mie was an ib3600 6 cell pack, the bottom 2 cells fel clean off. (shrinkwrap was removed to see obvious damage
saleens7
06-05-2007, 09:05 AM
.....uhh.........maybe.....
thats just the back of my head...ever see shaun whites (pro snowboarder) myspace picture on the HP computer commercial....that was my inperationg for it...
Doug Smock
06-05-2007, 09:16 AM
That is pretty ugly Jeepers.:eek: I've never had to repair one in that bad of shape. You may be able to shape a piece of foam to glue in the hole and then glass over the top.
Doug
Jeepers
06-05-2007, 08:28 PM
heheheh! thats funny! yeah I seen that commercial!
Jeepers
06-05-2007, 08:37 PM
Doug
Doug, this boat hit an erosion wall the impact was so hard that it ripped the motor screws through the wood, washers and all, it also pulled on the wire drive so hard that it pulled the octura pointed brass prop nut off the shaft!
i will give your suggestion a try. I will post pics of the repair if it comes out good.
Doug Smock
06-05-2007, 08:50 PM
Give it a shot. You got nothing to loose but a little time and material.;)
Good luck!!
Doug
Jeepers
06-05-2007, 10:52 PM
Good luck!!
Doug Thanks Doug!
Doozie870
06-06-2007, 09:22 AM
Wow that was quite a smack, what happened?
Jeepers
06-07-2007, 07:41 PM
Wow that was quite a smack, what happened? reciever pack failed, hit an erosion wall at full speed. jacked it up pretty good:(
Mich. Maniac
06-08-2007, 12:30 AM
WOW! that pic of your 4th grade pic is on a couple billboards in my town for a real-estate company! thats funny stuff
Jeepers
06-08-2007, 01:15 AM
ahhh man Mr smock you got rid of the pic in your avatar:( I gotta kick every time i seen it:D
Doug Smock
06-08-2007, 06:23 AM
Whats up with that????:confused:;)
Yankees, you can't trust them. The real estate co.has obviously been thumbing through the year books from Mayfeild Elem.:rolleyes:
I lived in Lapeer Mich. for most of my childhood.:)
Doug
boater76
06-10-2007, 08:20 PM
Wow thats looks fubar! Have you had any luck fixing it?
Ken
Jeepers
06-11-2007, 01:18 AM
I have made some progress this last couple of days!! I roughed up the inside of the hole with a sanding drum, cleaned it with soap and water, then used a wax&grease remover to remove any oils. I used a shaped piece of pink foam, coated in waterproof epoxy, I also coated the inside of the damaged area in epoxy then inserted the foam. Then I took some 3 ounce hi power rocketry grade "glass" cloth and inserted it between the abs and the foam working epoxy in to the "glass"with a stiff brush. let cure for 24hrs, sanded smooth , and using automotive glazing putty to fill in any imperfections( blue stuff in pic). the repair is very solid probably the strongest part of the boat:D now i am sanding to remove most of the paint as it was badly damaged in the crash. hoped to get it painted by this coming weekend.
ps here is some pics of a "small" rocket my friend Jason(pictured) and I are working on,this rocket will be fully finished in carbon fiber when done.(this is were i get my glass cloth from) the engine casing in the next pic is 29" long 54mm dia. the rocket is 7 ft 6 inches tall 6" dia. :D just thought I would explain the hi power rocketry comment in the above post:D
Jeepers
06-27-2007, 10:59 PM
almost complete! just waiting for my lettering, and some few minor touch ups, and it will be on the water this weekend!:D
Doug Smock
06-28-2007, 07:33 AM
Wow, great repair job Jeepers!!!!! The rocket is pretty cool too.:D
Doug
Jeepers
06-28-2007, 09:01 AM
Doug Thank you Mr Smock!
longballlumber
06-28-2007, 11:08 AM
Jeepers,
Is that a speedmaster rudder assy that your using? What strut did you use?
Thanks,
Mike
Jeepers
06-28-2007, 11:58 PM
Jeepers,
Thanks,
Mike Yep its speed master got it off this site! I am using an octura 3/16strut for .130 flex cable, but its set up for wire drive.
Jeepers
06-29-2007, 12:04 AM
FINISHED cant wait to get it on the water:D :D
boater76
06-30-2007, 09:24 PM
Excellent rebuild! I like the skeleton guy at the helm.
Ken
Jeepers
07-01-2007, 12:00 AM
Ken
Thanks I cant take credit though it was my wifes idea for the "theme".
