View Full Version : Avoiding Problems with the UL-1 Hydro
12-21-2008, 12:39 PM
Now that a few UL-1s have been on the water we can identify areas to watch. Several owners have found that their motor cooling jacket leaked. I moved my jacket before I tested it for leaks so it may have arrived fine - but after I adjusted it, blowing into one of the inlet tubes showed a leak at the jacket threads. Yours may or may not leak, be certain to check before you run the hydro. Here is how I easily fixed it:
- Remove the motor from the hull and unplug the wires and water lines.
- Shoot some WD-40 or similar lube into the inlet tube, enough to coat all the motor housing that's inside the jacket. Don't be stingy.
- Loosen the end rings no more than two turns and put a thin oil on the threads where they enter the end rings.
- Tighten the end rings by hand until tight. Make certain that the water inlets are positioned correctly.
- Wipe off any oil from the motor and jacket.
- Check for leaks by blowing into one of the inlets with the other inlet plugged. There should be no sound of air passing by the threads.
- Reinstall the motor, wiring and cooling lines.
The small rear winglets are held on with a thin strip of double sided tape. When mine arrived they were also held down with strips of regular clear tape, but I removed those. That made the winglets too easy to remove or to come off on the water. I suggest leaving the outside factory tape in place and forgetting about them.
Most of the fasteners (maybe all of them) are metric, so heed the instructions and be sure to have the correct metric tools - especially allen wrenches - available. Stripping out a socket head machine screw by using the wrong wrench is not a pretty thing.
I'm still very impressed with the UL-1. Like any new product there are minor issues to iron out, but by sharing that information we can maximize everyone's enjoyment with this fun little boat.
JimClark
12-21-2008, 01:14 PM
If those O rings are silicone the WD-40 may soften them. I know I used WD-40 to install the Gundert Silicone water jackets and ruined two of them.
Jim
H&MWill
12-21-2008, 01:22 PM
Jim
Soapy water works good and is safe for Orings.
Plain old dish soap is a great lubricant for installing cooling jackets. A thin bead of silicone around both ends of the cooling jacket WILL solve any leak issues.
egneg
12-21-2008, 02:18 PM
I use a few tricks from airbrushing that I and other airbrusher's have been using for many years.
One is to use Glycerin to lube the o-rings for ease of installation (also great for putting on water tubing). It is water soluble though so it can't be used as a sealant just an aid in getting the water jacket and tubing on. The other is to use bees wax to seal the threads. Soften it by warming it up and use a small amount on the mail threads before assembly. Both are perfectly safe to use and will not harm any parts.
12-21-2008, 02:57 PM
Relax. The instructions state to use WD-40 to flush out the cooling system - WD-40 is perfectly safe. :smile:
JimClark
12-21-2008, 04:48 PM
I wasn't all stressed about it Jay. At least not about that.
Jim
12-21-2008, 04:51 PM
NOT if the leak is past the threads on the jacket, which it was. :wink:
Eyekandyboats
12-21-2008, 05:20 PM
thats what she said... LOL!!!!
i am sorry back to topic
sewerpit
12-23-2008, 08:12 AM
fluid, what batteries are you using in your boat
Grimracer
12-23-2008, 08:37 AM
Jay..
Here is how i hold my wings on..
Clean off all the old tape.
Lay down some radio box tape (Sorry its got to be Grimracer for this job) over the recess pocket for the wing.
Using black two sided tape (the RC car stuff) place a full amount under the wing.. Stick the wing to the tape that is covering the pocket..
Done..
If the wings get hit.. no hole in the boat..
Gim
12-23-2008, 04:03 PM
I run two, 2S1P 5000mAh ThunderPower V2 cells. In series of course.
Mike:
I'm sure that works fine and thanks for the suggestion. Frankly I'm not a fan of wings anyway so I'll just leave them off my boat. That will also make it easier to identify my hull in a heat with five other UL-1s!:banana:
12-23-2008, 04:31 PM
. Unless any future rules changes say that you need them on there.... :zip-up:
Treydog
12-23-2008, 04:50 PM
Guys, just got a UL-1 Superior and the boat flies man! Still a noob here and I also got a Proboat Brushless Miss Elam a few weeks ago. My dad was driving the Elam and I was driving the UL-1. Didn't seem to have any problems with the radio frequencies but i guess later we did. Anyways, somehow I didn't turn sharp enough and the boat ended up banking itself while trying to turn. So I jump in the golf cart to get over there too it and when i got there the boat was running full throttle and water shooting up from the bank like a fountain. Yes, the propr was still somewhat in the water. So I pulled all the hockeytape off and immediately disconnected the lipos. Propr was still running wide open while i am doing this so it was a bit scary. Didn't seem to have had any damage except for a few chips taken off the plastic prop. No worries there since i also bought the hop-up prop when i bought the boat. Nonetheless, I took the boat home, cleaned her up, and recaharged the lipos. Now I am trying to restart the boat but the ESC or motor just keeps beeping - not giving me a chance to arm it. How do I fix this or is my ESC or motor shot? Nothing felt really hot when I got there after the accident so I wouldn't think anything was blown...I can steer the servos but I cannot get it to stop beeping or for the throttle to spin the prop at all. FYI, the servo is plugged into the CH 1 Slot and the ESC is plugged into the CH 2 slot inside the boat. Please help. Thanks so much!
Treydog.
Grimracer
12-23-2008, 05:10 PM
Jay.. yea wings on a sport hydro or any full body hydro can be a bummer.. The system I designed is baced on my Sport 40.. I designed tape on wings for it and they have saved the boat from sure deck death a few times.
Grim
Doug Smock
12-23-2008, 05:16 PM
Nice boat!! You know, for a nitro unit :lol: J/K
Doug :popcorn2::beerchug:
Ub Hauled
12-23-2008, 06:05 PM
I like the 'depth' on the paint job.. pretty sweet...
and then I saw the pipe... Boooooo, also j/k :tongue_smilie:
ReddyWatts
12-23-2008, 06:53 PM
Can anyone help this new member?
Treydog.
Grimracer
12-23-2008, 07:04 PM
Check the throttle trim on the TX...
Grim
alvinsmith75
12-23-2008, 07:39 PM
I had the same "arming" problem and it was simply the throttle trim. It should be centered.
Alvin
Treydog
12-23-2008, 09:16 PM
I just checked and all of the knobs on the transmitter are straight up and all switches are in the "R"position. I will tell you this though. I have found that the beeps will eventually stop when instead of pulling the throttle trigger, I actually push it forward. I hear two quick little bleeps and then it stops. Then when i do it again, The throttle goes wide open again just like on the bank when i came upon it. I can sorta get it to stop when I quickly depress the throttle a few times it will kinda sync up with the transmitter but it will still act funny like it's picking up stray radio waves or something. So I disarm the lipos and when I retry, the beeping process starts all over again. Open to any other suggestions you all might have.
Trey
Ub Hauled
12-23-2008, 09:23 PM
if the ESC is anything like the 35amp one, it has a safety feature... you hook the main power and then you need to go full throttle, listen to the beeps then neutral, listen to the final beeps, in order for it to arm.
Treydog
12-23-2008, 09:44 PM
Ub, I'll remember that from now on. BUT, I managed to get it running properly again. After typing that last e-mail, I ran down to the shop just to try it once more before I gave up for the day. Darn thing worked like a charm this time. No continuous beeping. Strange.
Fluid, I even powered up the Miss Elam and you are correct, neither one interfered with the other.
Here is my theory of what happened, The Brushless Miss Elam has a radio reciever in a balloon inside the watertight tray. The UL-1 does not. Now, I have heard stories of water getting inside a boats reciever and causing it to do all kinds of crazy stuff and while I do like the openess inside the UL-1 (The Miss Elam has no room inside except for the batteries) I guess I need to know if I should be wrapping the reciever inside some watertight "balloon"?
Always a good idea:biggrin:
12-23-2008, 09:57 PM
Once the water jacket is sealed and if the hatch is taped on well, there should not be any water in the hull that a piece of paper towel stuck in the bottom can't absorb. I used to put my receivers in balloons, but I soon discovered that water got in anyway. Because of the hassle I would seldom open the balloon to check. Result - ruined receivers. Now I take off the receiver case and spray the board with CorrosionX, then reassemble. I have not had a single problem due to a wet receiver since I started doing this - even with a hull completely full of water. I don't know that CorrosionX is safe on the Tactic receiver, but I bet it is. Mike?
12-24-2008, 07:31 AM
You are probably on to something there. Before running again I would take the rx apart to check for water and dry it out completely. It only takes a single drop to move around on the rx to cause another issue.
Grimracer
12-24-2008, 09:07 AM
Jay. that is funny.. has to come only from experience.. I also never place my personal race RXs in balloons. O I know.. some guys like em so we do indeed sell them..
The tactic RX was water tested and it will stop working like the rest of everybody’s if it gets wet.. good news is that all the units tested all came back from the dead.
If you like.. hammer away with C-X..
Grim
egneg
12-26-2008, 06:35 PM
The problem with the cooling jacket is a bit beyond a quick fix with WD-40. As many have stated the problem is with the cooling jacket around the motor, it leaked at 10 psi. The problem is the lack of surface area for the o-rings to seat properly - the threads run all the way up on the jacket and the end pieces - not to mention the side walls are a bit too thin. If nothing else I will use silicone to seal it. This seems to be an inherent design flaw that needs to be addressed in order for this boat to be called an RTR. All I had to do was squeeze the ends with my fingers and the leaks became much worse.
12-26-2008, 06:56 PM
The problem with the water jacket is easily fixed as I described, unless someone has already damaged the O ring by getting medieval with it. The jacket which came on my UL-1 was fixed just as I described. There is sufficient sealing area for the deformable O rings as long as they are not scored or cut.
I have another UL-1 jacket I bought for another project, and I installed it on the same UL-1 motor and performed the same procedure to seal it. Zero leaks when forcing water through the system with a fuel bulb squeezed as hard as I can. That's two for two. As I said, easily fixed if not damaged first.
Would I design the jacket this way? Probably not, but then it isn't my company. I imagine there is a reason for a three-part jacket versus a one-part jacket. Bottom line is it can easily be made to work, although I agree that it would be good if they all worked as they come from the factory. That is for the next shipment.
Jetbill
12-26-2008, 10:33 PM
Outside of some plumbers tape on all water jacket threads, it’s clear it was sealed @ about 30psi. I ran it and no problems. The O rings were seated however the larger threaded ends were barely screwed on. The brass fittings were loose and just needed to be tightened and added tape.
The turn fin I had noticed right out of the box had a crack by the hex, around the edge and on the bottom. This caused a leak in the boat that was easily drained by the rubber plug (I like this design-a quick clear epoxy fix)
Overall, this thing drove like a dream and handled like it was on rails- steering rate did not help the steering issue, likewise changing the servo horn hole to the next helped increase overall servo throw. (75'tirn radius didn’t quite suite my play area).
Gps @ 42.2, on Flightpower evo 30's-stock prop- run time was a bit lower than the my stock sv.
I like it; hopefully it will be somewhat stable with some wind..:
thumbup1:
12-27-2008, 12:28 AM
One thing that needs to be remembered - although I doubt it has any significance with the UL-1 - is that when moving the pushrod to an outer hole on the servo horn you lose steering torque. On large heavy boats or very fast boats this can mean the difference between having enough turning and not having enough, since the rudder can overpower the servo.
I've had this happen on P Sport hydros when using the cheap Futaba 3001 servos with their limited torque value. Substituting an 80-ounce servo returned the hydros to their good steering response. I believe that many steering problems that folks report are due to inadequate servos. Also note that you can increase your servo's steering torque by ~20% when using a 6 volt receiver pack.
birdy233
12-27-2008, 07:37 PM
Quick, question, should I need to re-adjust my strut from box stock factory set up? I ran my UL-1 for the first time today and thought I bought a submarine instead. The front would plow under the water and I could on get it somewhat on plane only if I tossed it, even then it was pathetic as my recovery boat was faster. I'm running a set of Team Orion 3800, 30C race Spec packs, but it seems it's way nose heavy, any thoughts?
Raydee
12-27-2008, 08:35 PM
That is very common with sport hydro's that have the CG up front. Here is a little trick i learned a while back, blip the throttle just enough to raise the front end and let off. Once the nose drops down and starts to pop back up nail the throttle and the hydro will jump up on plain. I might have a youtube vid showing exactly what I mean, let me go look.
12-27-2008, 11:33 PM
....should I need to re-adjust my strut from box stock factory set up?....front would plow under the water and I could on get it somewhat on plane only if I tossed it, even then it was pathetic as my recovery boat was faster.....
Ray's comments on starting are very good, but I am concerned with your statement that even on plane it was slow. This latter may have to do with the strut setting or something else.
A few questions:
Are you running the stock prop?
Are you running the stock radio?
Are you using the stock pack wiring harness?
Have the LiPos worked well in other boats?
What was the approximate temperature of the LiPos when you started?
How is your strut set up now?
The bottom of the strut on my UL-1 is 7/8" below the hull and angled down about 1-2 degrees at the prop. Set you model on a flat table and measure.
birdy233
12-27-2008, 11:55 PM
Thanks for the quick responses, It was a bit choppy out today, but the boat seemed like it was way heavy up front, the whole front of the boat went under the water. I'm not new to boats, I've owned three or four SV27's several BJ26's, Warehouse Enforcer, BJ 55 to name a few. This is the first hydro I have owned though.
As for the questions, I'm running stock strut setting, measured 7/8" from the bottom of the hull to bottom of the strut angled down about 2 degrees
I am running the upgraded Grim 40X57X3 prop, stock radio, pack wiring harness is stock, Lipo's are brand new (I did run them once on my Traxxas Slash, the packs are fine, temps on the packs, well, I charged them and headed out to the pond, it was about 80 here in Dallas today so I assume close to that temp. So I am stumped, I was thinking about trying the stock prop for the heck of it tomorrow.
One other thing I'm not impressed about on my boat, there is numerous HUGE paint runs all over the sides of the boat and one side near the transom was molded wrong so there is a swoop on the side/bottom of the hull, for $330 I'm not happy. I've seen my 5 y/o nephew paint better. I may need to contact Aquacraft/Grim on these issues.
Ub Hauled
12-27-2008, 11:57 PM
Jay, Birdie, Tony (properchopper) had the same problem with his UL, his lipos were a bit on the heavy side and the boat
would not get on plane... we tossed it and then it was slow as hell... I think the stock prop is not the most suitable for a heavier boat.
We ended up changing the prop to an X442 then it would take off (with the little trick Ray mentioned) but still is not unwinding... we ran out of batteries that day, tomorrow we'll test again with a little setup change (strut) and see how it goes... I am sure we'll get it going tomorrow. Maybe the 442 is also not the best choice, but now it doesn't have to be thrown.
birdy233
12-28-2008, 12:19 AM
Well I call BS, or Aquacraft needs to explain and send a refund check to me for the $230 I laid out for my Lipos. The stock battery they recommend weighs 6.2 oz, the optional upgrade battery printed in their manual weighs 9.2 oz, my pack which I just bought specific for this boat weigh in at 8.6 oz per pack. My pack weight should not be the issue, seems like a strut issue or cg issue, if it's a pack weight issue, someone has some explaining to do!
Ub Hauled
12-28-2008, 12:29 AM
Birdie,
try extrapolating the positive strut to 4 degrees and nailing the gun... maybe you'll get enough momentum to get outta the hole, if she gets a bit too lose, at least you can take a degree off to try to make up for it... I was talking to Tony about something else as well, maybe if push comes to shove you can use a different motor mount and take that bar away from the middle so you can push your packs back a bit.
I wonder what B. Buaas faced on his maiden voyage...
egneg
12-28-2008, 09:06 AM
I ran my boat for the first time yesterday stock except for the prop which was a M445 (mentioned by Brian B in another thread). It did take a couple of trigger pulls to hook up but once it did it was fast (GPS'd at 44.2 mph). I had 2 x 2s1p polyrc 4250's at 7.4 oz each. The upgrade 40x57/3 I believe is a lifter prop and when I tried a V940/3 also a lifter prop it turned into a submarine.
properchopper
12-28-2008, 10:39 AM
I had the submarine experience with the 40X50/3 also, [ with some fairly heavy Elite 2S 4800's]. Switching to a Bar cut X442 got 'er going pretty good. I've re-adjusted the strut & just got some smaller & lighter Elite 35C 5000's inside now & will try the M445 today. How were your temps ?
Tony
Raydee
12-28-2008, 10:54 AM
Tony let us know how the 35c Elite's work in that hull. We are planning to use them in our UL-1's this season.
properchopper
12-28-2008, 11:20 AM
Ray, as soon as I laid eyes on them last week in Jan's hydro, I had to jump on them. They're smaller & lighter than the leftover Elite 25C 4800's I used last week.
I'll post some results tonight.
Tony
LuckyDuc
12-28-2008, 11:46 AM
You might also consider Xcite Packs. I've used these in my EDF jets and they hold voltage better than Thunder Power Extreme packs, and are pretty reasonable price wise.
Their 4100mAh packs weigh 203g and their 4800mAh packs weigh 270g.
http://www.xcitebattery.com/newfrontpage74V.htm
egneg
12-28-2008, 11:48 AM
Tony
I forgot my temp gun so I don't have accurate readings but the motor and esc were only warm and the lipo's a bit warmer but not hot to the touch after 2 or three minutes.
Raydee
12-28-2008, 01:03 PM
Tony
Yeah I plan to try them in my Whiplash Hydro this season too. I was running 4s2p3200mah cells and they were Ok but I am going to try two of the Elite 2s5000mah packs in series and see how they handle in that hull. That way I can use the same cells in multiple boats and cut some of my pack costs down a bit.
properchopper
12-28-2008, 08:13 PM
Ray, here's the scoop : Put the 5000's in the boat with an M445. OhMiGod !! Totally different boat than with the older but well taken care of 25C 4800's. Lots of wind & chop & the boat was flying. Put the 4800's back in to weigh down the front some[they're heavier & longer] it was and Boring !! Later in the day the water layed down some; put the 5000's back in & with the M445 the boat was almost too much to handle. Then [there still was a little wind] she blew over & ripped the turn fin out of the hull. Bummer but fixable. [Jan should be posting some vids by this evening]. Do I like these batt's ; Hell Yeah !! :banana:
birdy233
12-28-2008, 08:28 PM
Well, took mine out today, put the stock prop back on and bingo, worked great, GPS'ed at 43.8 with the orion Lipos.
For the heck of it tried the upgraded prop again, adjusted some on the strut, no luck, that prop for me just does not work, what a waste of $20
On a good note what a great handling boat, sticks to the water like it's on rails!
12-28-2008, 09:06 PM
Jay, Birdie, Tony (properchopper) had the same problem with his UL, his lipos were a bit on the heavy side and the boat would not get on plane... we tossed it and then it was slow as hell... I think the stock prop is not the most suitable for a heavier boat.
Jan, I really doubt that the problem is too much battery weight. My TP5000s weigh about 9 ounces each, and I have no problems getting up on plane and speeding away. Brian wasn't using light weight cells at the SAWs and his never subed. I suspect that the problem most guys are having is with the strut setting. Don't freak out and condemn Aquacraft! If you are not familiar with how to trim out a hydro just ask. Hydros are not like monos...
The bottom of my strut came 7/8" below the hull and angled at most 1 degree down at the prop end. If you are having trouble getting on plane you can simply flatten the strut. You do not want to angle the strut any more or you'll never get on plane! A flat strut is the default setting; if the bow flys then angle it down a bit at the prop end. It won't take much. If the boat runs too hard on the water raise the strut 1/8". Several guys have e-mailed me about problems getting up on plane, and in every case a minor strut adjustment was all it took regardless of the packs used.
Different props can cause trouble getting on plane too. Screw on a lifting prop combined with too much strut angle and you'll never get on plane. If you are using a lifting prop, flatten the strut. You may even need to run the strut up a degree at the prop end. Actually I believe that the "best" all-around prop may be an m445 or K45, all things considered. It will take some additional testing to find out for certain. The x442 is pretty small, I doubt it has enough blade area to load the motor enough.
BTW all strut adjustments must be done on a flat surface like a table. The hydro should rest on the sponsons and the strut. The strut angle will be between the bottom of the strut and the tabletop. Don't try to do it "by eye", it won't work.
Ub Hauled
12-29-2008, 12:21 AM
Jay, I totally agree with you about the prop, we tried a 445 today and man... was that thing alive!
The strut was at zero, that was not the problem, on a more extensive look to the problem, we realized the batteries that Tony was using were not up to par, either not enough charge or just weak, we used a pair of 5000/35C Elites today with the 445 and the same strut setting and the thing was hauling. We are not blaming anyone, just stating what happened... I had the chance to
drive the UL for a while and it is a very nice handling lady!
Jay, I don't own any monos:tt2:
12-29-2008, 09:24 AM
I know you weren't Jan, but others in the thread were starting to blame AquaCraft. My post was really meant as a general comment to all readers.
It is interesting that you found Tony's packs to be sub par....another boater e-mailed me with problems very similar to yours, but when he charged the packs again the boat ripped. I guess it is another example of how different a hydro is from a mono - the latter will at least get on plane with low voltage packs, the hydro may not.
egneg
12-29-2008, 05:44 PM
Thanks for the info Fluid!
I checked the strut and found that it was 1" below the hull and 3 degrees down on the prop end. I also found that the rudder was angled back 3 degrees as well. This explains why it nose dived with the V940/3 and with the M445 it was quite loose once on plane. I will make some adjustments and run again.
12-29-2008, 09:52 PM
Yes, the v900 series props are lifting props and need a flat strut. It still may be tough to get the boat on plane, those props are really SAW props, not well suited for oval racing or general sport running. Sometime in the future I plan on trying them just for fun....
Ub Hauled
12-29-2008, 11:39 PM
I thought it was not meant directly at me, but I just wanted to get things cleared out...
don't like when people get the wrong impression from my already troubled English grammar :laugh:
Jay you should have seen her with the "bad" packs, it was like a dear or dog just hit by a car limping away... it was asking to be taken out if it's misery. «-- maybe a bit exagerated but you get the point. ;)
But it surprised me with the 35C cells on an M445.
Grimracer
12-30-2008, 10:37 AM
Dont Pussy the throttle... its a hydo for gods sake... drive it like one......:buttrock:
Grim:rockon2:
Grimracer
12-30-2008, 10:52 AM
Also let me state..
If you have bad batts.. (truth is I have tested allot of "questionable" batteries) and I gota tell ya.. Some that claim 30C.. not even close.. Just an FYI..
Our EF and FP batteries are very good.. the C ratings are dead on... If.. you are getting a "deal on batters" just be mindful of what you might be getting.
Also.. if you are new to hydros having a lack of understanding how they work.. how does that fall on my shoulders? We/I do all I can to design the best product we can. We also do our best to take as much of the guess work out of the boat as we can.. We all we can to make sure the door is open (Hobby Services) as well as Hobbico allowing me time to come and chat with you dudes..
Calling out BS… you have my attention..
As for the bad paint.. you have the option before running the boat to return it for full refund.. this is stated in the manual, and I can not think of one hobby source that would balk at not taking care of you. But because you have ran the boat the best you can do it contact Hobby Services and see what they can do for you. I bet.. they can help..
Grim
properchopper
12-30-2008, 11:36 AM
I just gotta' say this is one FANTASTIC boat, and reflects years of experience and racing knowledge. That Grim & company put out this boat, at an unbelievable price for all you're getting, is not to be taken lightly. To mass produce something like this, and allow FE novices { and racers alike} to get on board with the "real deal" should be heartily applauded. Further, I firmly believe that behind this effort is an openhearted invitation to those that want to get into the hobby for the first time, and allow anyone that wants some adrenaline therapy to jump in without breaking the bank. Before this boat and it's predecessor, the SV-27, nothing even came close. Sure, at this price point there may be some cosmetic imperfections, but anyone that's bought some rather expensive European hulls have suffered the same fate for lots more moola.
Finally, Hydros may require just a little more tweaking of the setup than monos and everyone should be both aware and patient of this issue. No boat will be perfect out of the box given variations in props & batteries that are dropped in by various boaters. To this end, there's plenty of help on the forums as well .
I'm certain that it took a lot of heart & some big cajones to get this product to market, especially knowing that some backlash would occur.
Be Patient,Be Happy, & Let 'Er Rip:rockon2:
Tony
WTF, Run Amuck
12-30-2008, 01:01 PM
Actually, the boat is not nose heavy when using a more aggressive prop than the factory one. With two 2S/5000mAh ThunderPowers (not light cells) the CG is about 2.7" behind the sponsons. My personal LSH and P Sport hulls have the CG within 1.5" or less of the sponsons to help keep the boat on the water at speed. The UL-1 has so much lifting area that I believe that we can use the heaviest cells we can fit to keep the boat on the water. Air dams and lead weights are cheaper means of preventing blow-overs, but at least right now I believe that low-weight packs are not a solution to anything for those wanting more than strock speeds.
I may try an experiment with a 4S2P setup, my 3300 mAh ThunderPower packs will fit under the hatch in place of the 2S/5000s. Actually, I just checked and the 3300s will fit cross-wise in the hull, so I can move the CG forward with a single 4S1P pack - or use two for 4S2P and more balast. Hmmm....
Raydee
12-30-2008, 07:17 PM
Grim:rockon2:
That is going to be one of the main problems releasing a RTR Hydro. Some of the guys that buy this boat probably have never run a hydro and will expect to run it like the super vee. They don't know that the hydro needs to be run at full throttle and turn RIGHT only. A hydro is a race hull and needs to be run like one.
Ub Hauled
12-30-2008, 07:34 PM
Huh?! Did anybody say hydro?
