View Full Version : Motor Rotation 1/10 Scale Hydro
klloyd67
08-10-2018, 11:02 PM
When I ran 1/8 Scale nitro we ran with left rotation when looking at prop from transom. Do 1/10 scale FE guys do the same thing?
Thanks,
Kevin
JimClark
08-10-2018, 11:09 PM
They turn left and use right hand props
klloyd67
08-11-2018, 10:49 AM
So I need a right lay flex cable?
Sent from my VS985 4G using Tapatalk
TRUCKPULL
08-12-2018, 12:42 AM
YES
Larry
leonard feeback
08-12-2018, 11:48 PM
Offshore Electric has both flex shafts and props needed for 1/10th scale.
klloyd67
08-27-2018, 09:01 PM
Question?, if the brushless motors can rotate left or right and there are more prop options for left rotation, why wouldn't I run left hand?
JimClark
08-27-2018, 09:36 PM
There used to be only a couple of RH props that would work but there are now quite a few to choose from. When the 1/10th scale first started in Seattle it was a bunch of Hydro Geeks that wanted to mimic the real Unlimited's and they turn left.
TRUCKPULL
08-27-2018, 09:43 PM
If you want to run with the 10th class and turn left. You want a right hand prop.
If you run a left hand prop, you boat will not like it (very hard to turn left when spinning a left hand prop.
The prop walk helps the boat turn.
Larry
klloyd67
08-27-2018, 09:44 PM
Thanks, little slow on hydro physics
