View Full Version : ZTW Seal boat esc's
Raydee
07-18-2018, 10:36 PM
Just curious if anybody is using the ZTW seal esc's yet? Can't seem to find much info on them.
Prodrvr
07-20-2018, 09:56 PM
A friend of mine knows two guys who had bad luck with them. One lasted two passes, the other lasted about 18 seconds. Until I started looking around, I was going to get two 300A units, but I'll just go with the Swordfish X now.
kfxguy
07-21-2018, 01:31 PM
I really like the new swordfish x.
kfxguy
07-21-2018, 01:34 PM
Wow. I didn’t even know Ose carried these. They look pretty cool. I like the design. Any experienced boaters tried these yet?
Raydee
07-21-2018, 01:41 PM
No problems at all? Just picked up a boat with one installed and I am hoping it will be good to go.
eric113
07-21-2018, 04:45 PM
I bought a 200a ztw I will be running in my 8th scale hydro. Maiden voyage is next Saturday. I will post back afterwards.
Prodrvr
07-22-2018, 10:58 PM
Please do!! I don't care to burn up $500 if they're crap.
Mike W
08-03-2018, 08:01 PM
My 200A is working great.
Prodrvr
08-03-2018, 09:01 PM
What are you running with it?
fweasel
08-03-2018, 09:53 PM
Steven V has been testing them for a little while now and has positive things to say about them. I don't recall exactly which models he's been running. Some of the early failures I've read about were very early on in production, not the models I see available now. I agree, those 300A units look beefy and have a lot of caps on them.
Prodrvr
08-03-2018, 10:03 PM
Ok cool.
Prodrvr
08-03-2018, 10:06 PM
Unfortunately, no data logging.
Gofast12s
08-04-2018, 02:03 AM
I am thinking of using them in my twin 53'' cat but won't buy till they are out for a bit... I just have a Swordfish die with only two runs on it. Worked just fine whet to run it a 3rd time and it won't start back up.... Seems to be like most things today made in China you mite get a good one or you mite not........
Prodrvr
08-04-2018, 05:09 AM
Was it the Swordfish X ? I just bought the 220 for my Geico boat. However, I'm still waiting for the Radtek to show up and in need of two 300A controllers for it. Two MGM's would cost about $150 more that the SF X 300's. May buy them, but that's a lot of $$$.
Mike W
08-04-2018, 10:57 AM
Running it pretty hard with a TP4050 1950KV 6S5000 4x1000uF 1716 in a Genesis for a full 5 minutes at 77mph in the straights.
Gofast12s
08-04-2018, 12:03 PM
It was a 300 Plus with 1k motor running on 6s with 9 63v 1000uf caps only got two runs out of it before it stop working....
Prodrvr
08-04-2018, 10:57 PM
Nice!
Prodrvr
08-04-2018, 10:58 PM
That's it???
Gofast12s
08-05-2018, 02:49 PM
Two runs from one of the two Swordfish 300+ The other one still works fine.... Problem being the 300+ is no longer made and Swordfish has a very bad return record. Logger showed it working just fine no high heat no high voltage no high amps rpms high point of 2130 so WTH ????? I'm going to get inside of it and see why it won't work even if I have to cut the outer case in half to do it. What do I have to lose $300 LOL I'm out $600 because one ESC is no good with a twin cat is it. The good ESC is going in the hydro that was gas now I get need a motor.... Mad that I need to get a new set of high dollar ESCs to run my newer cat because one ESC takes a crap...... :( I won't buy a swordfish ever again waiting to see how the ZTWs are!
Prodrvr
08-05-2018, 03:15 PM
The more I read, the more I want to just bite the bullet and get a pair of MGM's.
Peter A
08-05-2018, 03:40 PM
Agree with you the Sf esc's, have only had two 220A and both lasted less than 10 runs. The V2 T 180 was awesomw, why did they ever stop making it and not make a bigger version, IDK!
eric113
08-12-2018, 11:18 AM
I been running mine in 8th scale hydro on 8s and been fine. Other guys in club run 200a in P mono and P sport hydros with no problems. I live in Texas where been upper 90’s-100’s during the summers.
Prodrvr
08-12-2018, 05:44 PM
Sounds good. I also got another recommendation for these from a high end boat builder.
