maryellencarter
06-27-2018, 07:57 PM
160087
OK so I've got a 2'crackerbox nearly complete. Since this was my first attempt and its for the 8 year old grandson (don't want to break speed records just yet), I went with a brushed motor, and parts from the local hobby shop. I took the boat in and said I didn't want to break the bank, but want decent stuff. So they set me up with brushed motor and a Horizon air cooled ESC. Since there is no airflow inside the hull, I have been toying around with either buying an esc water cooling heat plate, or, cutting a 30-35 mm square hole in the hull below the water line and installing aluminum plate to cover the hole (flush to the rest of the hull), epoxy it in place, and viola(!), cooling plate with all the water one could ask for! I would mount the 'fin' side of the ESC against the plate with some epoxy and heat sink goop.
Any thoughts?
-MEC
Any thoughts?
-MEC
