View Full Version : Pro Boat UL 19 battery + upgrades
bigred86
06-16-2018, 10:07 PM
Hey guys! I'm brand new here. I just ordered my first electric boat today, a Pro Boat UL 19. I'm looking for top performance out of this boat right away. Is there a better prop I can install? What batteries should I purchase? Not looking to burn my equipment out, just looking for top performance out of my kit. Thanks very much in advance guys!
CraigP
06-17-2018, 11:34 AM
I recommend running it stock on 4s. I think you’ll find that the boat is very fast! Why don’t you get your feet wet first before changing parts. Save you some money and you get out on the water quicker.
Jesse J
07-01-2018, 08:40 AM
First of all, welcome!
So what do you mean by top performance? Do you have an mph goal or handling or reliability?
What is your budget?
There are three variables and you can only choose two: speed, reliability and cost.
This info will help us help you.
Tetefroid
07-01-2018, 02:14 PM
As an owner of the UL-1, I concur with what CraigP said. They are plenty fast and loads of fun, right out of the box.
bearstoy
07-26-2018, 11:32 AM
hey guys i am new here too.i am looking at the aquacraft UL1 or the proboat UL19. i know some guys with the UL19 that are having some major overheating issues with melting the connectors off their batteries.is this a common problem with these boats?
Tetefroid
07-26-2018, 08:44 PM
I have an UL1, I have not had this issue. But loose connection can cause this and also wire that is not rated for the amperage the motor will pull, can also get hot and melt the insulation.
bearstoy
07-27-2018, 04:42 AM
Thanks 4 info. I believe the boat in question was running totally stock but on 3s x 2 batteries in series. with a 50c rating. Temps 4 motor and batteries were in the mid 130's. does this boat require extra or at least larger cooling lines? The bullet connectors were upgraded but not the wires. As far as i know the boat has yet to make a full run on the water before connector meltdowns.I am watching this closely as i am on the verge of getting one of these boats. Being new in this game i want to make wise choices.
bob horowitz
07-27-2018, 10:42 AM
From what I've read on this forum, if you run on 6S with the stock prop, you are asking for trouble. To run safely on 6S you need to prop down. Take a look at the UL 19 tuning thread under RTR boats.
RacerX27
05-24-2021, 06:09 AM
I have a new UL-19 on order and it will be my 1st electric boat. I have many cars, a couple of planes, a drone, and I use to have a Deep Hull Nitro boat.
I'm going back and forth between 4S and 5S but will probably stick to 4S for now. My biggest question is about batteries. It looks like I would have to buy a new charger for most of the Spektrum batteries? Is this true? I'm not a fan of Spektrum radio gear but know nothing about there batteries.
Thanks,
fweasel
05-24-2021, 11:43 PM
You can charge spektrum batteries on any lipo charger with the correct charge leads, but you need a spektrum charger to take advantage of the smart features.
I’m looking to get the Pro Boat UL19 and i have read a lot of owners saying to avoid the 6s do to overheating ESC and motor, breaking drive shafts and other issues. They advise using a 3s and a 2s battery as stated in the manual to get 5s or go with two 2s batteries for 4s. Question: if the transmitter has a 75% power selection could i safely run two 3s batteries for 6s but set it to 75% which would essentially be running 4.5s??? Is this the way the system works? I would like to avoid having two different batteries (2s and 3s) for one boat. Has anyone tested this.
tbonemcniel
11-20-2021, 02:01 PM
I?m looking to get the Pro Boat UL19 and i have read a lot of owners saying to avoid the 6s do to overheating ESC and motor, breaking drive shafts and other issues. They advise using a 3s and a 2s battery as stated in the manual to get 5s or go with two 2s batteries for 4s. Question: if the transmitter has a 75% power selection could i safely run two 3s batteries for 6s but set it to 75% which would essentially be running 4.5s??? Is this the way the system works? I would like to avoid having two different batteries (2s and 3s) for one boat. Has anyone tested this.
You can, but it will increase heat in the ESC. I probably wouldn?t do it. Just run two 2S or start upgrading.
jkflow
11-20-2021, 05:47 PM
On 6S you will hit critical temps in about 2 minutes, motor wires will melt, but that is too late for the motor itself.
Stay on 4S for now, learn how to play with it. Upgrade the motor if you want 6S. 3674 has a longer can, get a longer cooling can to go with it.
It's plenty fast on 4S already.
If you are using SMART batteries, you have a learning curve ahead of you and go play before you upgrade. Once you upgrade you will ditch all that smart stuff anyway, it's rather underperforming imho.
fweasel
11-20-2021, 05:52 PM
If you're set on 6S, run a smaller prop.
Thanks for the responses, I already have some 4s and 3s Smart packs and a couple 3s Zeee packs. I like the performance on the Zeee much better then the smart packs. So I think Ill go with the 2s and 3s combo and pick up some 2s packs. a lot of People seem to be recommending this when starting out with this boat. I also got a dual pickup rudder that I'll install on it right out of the box and dedicate it to the ESC and then a separate pickup for the motor to help with cooling. Can anyone recommend what size and style propeller to get if I want to eventually go to 6s? I see a lot options on OSE for props but I'm not familiar with the differences? Any help on other upgrades is much appreciated.
jkflow
11-22-2021, 10:53 PM
Don't do the dual rudder, won't help you with overheating. Install a transom water pickup instead, plenty of water.
Seen many people do the dual rudder pickup, and they don't achieve anything but having a cooler ESC while the motor still overheats.
Stock prop is good, just a matter of cooling things down.
Thanks for the advice on the cooling. If I go 6s what would be a safe prop size? the original is 43mm with 1.6 pitch. Im looking at the Octura props and there's seems to be and endless number of options in styles and sizes. Trying to do my homework ahead so I don't burn anything up and learn the hard (expensive) way.
jkflow
11-25-2021, 09:39 AM
There is no right answer, what is your motor kV rating? That determines the rpm and the best prop size.
kV= rpm per volt (4S=15V, 6S=23V rounded)
Try the stock prop, see how hot it gets after 2 min (max) and go from there.
Motor should be in the 1600-2000kV range.
Got my UL-19 and have been running it with 6S and the stock prop but I added a lot of cooling up grades including duel pickup rudder, a flush mount pick up on the bottom and a small water pump to keep it cooling running and even when stopped. Also changed out the ESC for a OSE Raider 150. Still running the stock a3650 2000Kv motor. I ran temp sensors on the esc, motor, and in the wiring. Temps top out around 110 even when running WOT for the motor and esc however the wires run a little hot at 120 to 130 but I can trim some length out (about in half o 3 to 4 inches) and should be able to reduce that heat there quite a bit. Question: I have an extra spectrum Firma 4074 2050Kv 4-Pole Brushless Motor, would there be any issue with running it on this set up? And if so would I need to change anything up? The specks are below and it is quite a bit more motor then the original Dynamite 2000KV. It's and extra motor laying around and I would like to use the Dynamite in another boat if this Spectrum will work in the UL-19?
Second question? if the Dynamite spec below shows 680w of output power at 7.2V. would that mean running it at 6s (22.2V) its output is roughly 2000w?
Spektrum https://forums.offshoreelectrics.com/blob:https://forums.offshoreelectrics.com/f03450a4-b95a-45ff-8a93-966fef2c86c3https://forums.offshoreelectrics.com/blob:https://forums.offshoreelectrics.com/de7a6606-fbd0-4b39-bde2-96d4d901f981Bearings
4mm Bullet
12.6–25.2V
Brushless
5050W (6S)
2.9" (74mm)
Spektrum Firma 150 Smart ESC 4074
10 AWG
Dynamite
RPM/VCurrent (A) at 7.2V Dimensions (Dia. x L) Weight
Efficiency
Poles
Power
Shaft Dimensions (Dia. x L) Turns
Voltage
Connector Type
Maximum Timing
2000Kv
2.3A +/-0.8
36mm x 56mm (1.42 in x 2.20 in) 294.8 g (10.4 oz)
92%
6
680W
5mm x 15.5mm (0.20 in x 0..61 in) 1.5-D
7.4V–22.2V
5.5mm bullet
7.5o
