ray schrauwen
01-27-2018, 07:17 PM
This one I will ask a bit of advice on.
I mainly run 4S packs and I have one set of 6S.
Bought 10- 1 ohm 100watt resistors and planning either 2 banks in series of 4 or 5 in parallel to obtain either .5 ohms total or .4 ohms. This will pull either 33.6 amps or 42 amps respectively.
They will be stacked like the one's from RL Power on 12V fans.
3 layers of fans sandwiching 2 layers of resistors.
Do you think I should use 4 or 5 resistors?
That's all I need to know.
I do have a watt meter and a cell monitor to link all together but it will be manually operated as I sit and watch the voltage.
Just a crude mock up. 4 seems neater...
