View Full Version : U-31 MILLER HIGH LIFE 8th Scale build thread
K.R.Joye
01-25-2018, 08:51 AM
Gents, I'm making a lot of progress on my winter project U-31 `Miller High Life' Unlimited Hydroplane. Based on the Lucero designed Circus Circus platform, the`Miller High Life' was campaigned briefly on the 1988 Unlimited circuit. The scaled down 43" hull will legally meet all overall dimensional info provided on the NAMBA MHR#8700.
I inherited this project from a good friend as a plywood framed skeleton from Newton #146 plans. Most of the wood frames were disguarded after being used for patterns in favor of stronger G10 Epoxy sheet composite. CF angle will also be used for structural support, plywood Transom & Sponson bulkheads are G10 skinned. West Systems #610 2-part epoxy is used for bonding and Z-Poxy for sealing a bonding any wood to wood component. The center section of the hull has been offset from Port to Starboard for FE clockwise racing. Epoxy Glass Canopy, Cockpit and rear Wing Set(on order) are RC Boat Company pieces.
Power will be provided by IMPBA legal 1527 1.5y or Plettenberg HP370 BM A1-S on 10s1p lipo. Offset 3/16" cable driveline and hardware will consist of a combination of Zipp Kit(turnfin) and Speed Master(rudder,strut) components. Same hardware and driveline setup is used on my U-1 Atlas Van Lines.
Here's some pics so far showing rear afterplane tub construction. Everything is swiss-cheesed to save weight. Working my way forward to start soon on front sponson & canard spar structure.
K.R.Joye
01-25-2018, 08:53 AM
RC Boat Company canopy to be integrated into the hull.
bob horowitz
01-25-2018, 09:24 AM
Ken,
Nice job. Makes me itch like crazy just thinking about cutting all that G-10. Great idea though.
Bob
emspjay
01-25-2018, 05:45 PM
Great build! That is very cool! Can't wait to see it finished!
srislash
01-25-2018, 09:18 PM
Very nice. The canopy will really set it off.
K.R.Joye
02-04-2018, 08:13 PM
Worked on locking down the front sponson structure. The (2) CF angles are tied together with hardwood beams bonded to inside sponson walls to eliminate pickle fork twist. The forward CF angle will be part of the nose canard wing structure while the rearward CF angle will support the sponson transoms tying them in to the tub.
Sponson bulkheads and stringers next...
revoltrunner
02-05-2018, 03:48 PM
I bought these decals back in the 80s
and never used them.
just realized these are for the Miller American
not the Miller High Life.
K.R.Joye
02-12-2018, 10:51 AM
Bonding the Sponson transom & bulkheads along with stringers
Doug Smock
02-12-2018, 12:42 PM
Looking good Ken!
K.R.Joye
02-12-2018, 01:08 PM
Thanks for the nice comments guys. This nasty Mi. winter is providing me with lots of shop time.
Hopefully if all goes well i'll have some better competition for you Doug!:bowdown:
785boats
02-12-2018, 11:24 PM
Coming along very nicely.
I've never seen a hdro built up out of G10 epoxy sheet before.
Very interesting.
K.R.Joye
02-18-2018, 09:21 PM
Very interesting.
Thanks I've been following your U-3 build also your doing a great job! I've built plywood kits too, just to hard to repair when bad things happen.
K.R.Joye
02-18-2018, 09:26 PM
Working on the sponson bottom structures today. The West Systems 610 2-part epoxy i use on the G-10 takes overnight to dry so I try to setup something up for bonding as frequently as possible.
K.R.Joye
02-19-2018, 09:23 PM
CF angle air trap vents are in!
K.R.Joye
02-23-2018, 08:45 AM
Bonding sponson bottom stringers, note right pic show CF flat plane ride pad forms
K.R.Joye
02-27-2018, 07:59 AM
Bonding the after-plane non trip top form stringers
Shooter
02-27-2018, 04:30 PM
Ken, This is awesome!! When you mentioned G10 the other day, I wasn't envisioning this much of it! Nice!
K.R.Joye
02-27-2018, 08:23 PM
Thanks Pete lots more G10 to come
longballlumber
02-28-2018, 07:51 AM
Hi Ken,
Looking good! Do you have a bare hull weight target your working towards?
K.R.Joye
02-28-2018, 08:40 AM
I'd like to keep the hull under 5lbs, I know its going to be tough.
The deck, bottom and ride pads skins will be G10
Vertical sponson and after-plane non-trip surfaces will be Styrene sheet to keep weight down.
K.R.Joye
03-05-2018, 08:59 PM
Bonding the engine cowling support opening structure.
Heavy swiss-cheesed hardwood Airfoil blocks are bonded in. These really strengthen the whole front canopy/sponson structure to the afterplane.
Canopy nose construction up next...
K.R.Joye
03-11-2018, 09:30 PM
Laying out deck skin patterns
Shooter
03-13-2018, 07:46 PM
She's lookin good!
K.R.Joye
03-19-2018, 09:28 AM
Lower Canopy nose and sidewalls are bonded in! Future home for 10S1P 5000-6000 lipo.:banana:
Tom G
03-19-2018, 05:24 PM
Do-in some nice wrk there
K.R.Joye
03-26-2018, 08:31 AM
Added a CF bonding strip to the nose side wall before attaching the Canopy fuselage. There's a removable rear top canopy piece for battery compartment access.
K.R.Joye
03-31-2018, 10:19 AM
RC Boat Company Wing Assembly and upright mounting. All 3 wing parts have packing foam sheet cores for floatation. Upright bases have G10 slide in sheaths bonded in. Blue masking tape is used throughout the build to keep exterior surfaces clear of excess glue
K.R.Joye
04-03-2018, 08:58 PM
Wing attachment hardware and mounting. Wing position is set neutral parallel to the rear after-plane bottom surface. Also showing removable canopy battery access panel bonding.
K.R.Joye
04-08-2018, 08:56 AM
Zipp Kit (large hydro) 7075 Turn Fin modified and mounted. Speedmaster 21 Rudder w/transom load transfer gussets installed. 6-32 SS Allen Bolts used throughout w/blind nuts sealed w/epoxy.
K.R.Joye
04-10-2018, 09:05 AM
Hydro Strut `G10 Wet Box' fabricated with a hardwood base is bonded, fastened to the hull bottom and transom. This is a long strut setup on offset driveline, angle-depth adjustment bolt will offer ease of access at deck surface. Faux`Turbine Exhaust' tube will hide any strut hardware proud of the deck.
Beaux
04-10-2018, 04:44 PM
That wet box looks like a good idea.
Shooter
04-11-2018, 12:00 AM
I agree. Awesome idea, and it will be hidden!
K.R.Joye
04-23-2018, 07:17 AM
Started skinning the sponsons and non-trip. Decided to go with .06 styrene sheet because its light, durable and bends easy.
eric113
04-23-2018, 09:19 AM
Interesting, I haven’t seen someone use styrene for sheeting. But it easy to work with.
Shooter
04-23-2018, 12:50 PM
My entire vacu-pickle is made of this stuff! :laugh: One of the most durable boats I own!
K.R.Joye
04-24-2018, 07:58 AM
Styrene is tricky to bond,`Marine GOOP' works very well. Be advised use in a well ventilated area. Stinks real bad...
https://www.amazon.com/Amazing-GOOP-172012-Adhesive-Cartridge/dp/B000KKOON4/ref=pd_day0_60_7?_encoding=UTF8&pd_rd_i=B000KKOON4&pd_rd_r=3P3GGNEQ1WFN1FHC4HGQ&pd_rd_w=Iq1bA&pd_rd_wg=Jf44C&psc=1&refRID=3P3GGNEQ1WFN1FHC4HGQ
K.R.Joye
04-25-2018, 08:55 AM
More sponson skin(styrene) and ride pad(G10) bonding
RandyatBBY
04-25-2018, 02:01 PM
Great build Ken.
K.R.Joye
04-30-2018, 11:03 AM
Great build Ken.
Thanks Buddy!
Last of the sponson skins bonding. Careful balance of aero, fluid dynamics and contact patch went into the right & left sponson designs. Overlaps still need to trimmed and fine sanded.
Shooter
06-04-2018, 12:59 PM
Man, that looks great Ken!!!
K.R.Joye
06-04-2018, 03:22 PM
THANKS!
More pics front canard wing structure, sponson floatation and through hull motor mount bases bonded in.
K.R.Joye
06-04-2018, 03:27 PM
Finally G-10 top skins are bonded to sponsons. Used small wood screws to hold the edges down while overnight bonding. They will be removed, holes filled etc...
Doug Smock
06-04-2018, 04:00 PM
Looks like you are fast approaching the down hill side of the build. Very nice work my friend!
K.R.Joye
01-02-2019, 11:21 AM
The deck is put together in sections for ease of assembly (and repair). CF Ram Wing exterior skin bonding & deck joint are composite so you wont read joints if the boat gets really soaked.
K.R.Joye
01-02-2019, 11:26 AM
Similar to sponson deck panels, these are glued and temporarily screwed.
K.R.Joye
01-02-2019, 11:29 AM
Joints for rear center section
K.R.Joye
01-02-2019, 11:33 AM
This completes the final exterior panel bondings. :banana:
Tetefroid
01-02-2019, 08:11 PM
Wow! This is a very cool build thread.
K.R.Joye
01-02-2019, 08:29 PM
Thankyou sir! Trimming edges and rough sanding comes next....
Doug Smock
01-02-2019, 10:35 PM
Won't be long now!:thumbup1:
bozo586
01-02-2019, 11:15 PM
nice work KEN!
K.R.Joye
01-11-2019, 09:42 AM
I'm working on the cockpit windshield and driver area along with the turbine/canopy exhaust fitment. Yes i'll be using a lightweight aluminum water bottle!:tongue:
Shooter
04-05-2019, 01:10 PM
Sweet! Any updates?? I'm hoping to be at the pond tomorrow.
K.R.Joye
04-05-2019, 02:53 PM
U-31 Hull is ready for finish body work then paint. Just waiting for warmer weather to get started. I had to use 2 aluminum water bottles for the turbine exhaust, joint hidden under the rear support mount.
K.R.Joye
04-05-2019, 03:05 PM
I wanted a quick way to attach/remove the canopy and cowling. Came up with idea of using wiring nuts for locating connections. Then 2 fasteners, one on each the side of the cowl holds the whole assembly down. BTW checkout the new motor! :wink:
K.R.Joye
05-20-2019, 09:17 AM
After weeks of filling, spoting, blocking, priming repeat..... Basecoat White Gloss epoxy finish was applied last Friday. Were in the home stretch!
Shooter
05-21-2019, 09:22 PM
Holy Crap!!! That thing is beautiful. Deserves the Plett motor for sure!!!!! :)
Doug Smock
05-21-2019, 10:35 PM
Very nice Ken!:thumbup1:
K.R.Joye
05-22-2019, 08:17 AM
Thanks guys hope to finish up paint this weekend
785boats
05-22-2019, 02:00 PM
Excellent.
Certainly an interesting build from start to finish.
K.R.Joye
05-23-2019, 08:18 AM
Managed to get some painting done between rainy days in Michigan. Just hardware store enamel `Miller High Life' vinyl transfers and lots of clear!
K.R.Joye
05-28-2019, 07:51 AM
Finished up the color this weekend. Decals then finish clear coat come next. Took a couple hours to mask the boat for each color, well worth it!
fweasel
05-28-2019, 11:18 AM
looking good
meangenesracing
05-28-2019, 01:30 PM
Beautiful work Ken
K.R.Joye
05-30-2019, 07:34 AM
Finally had a 20 minute window yesterday when sun decided to come out to do the clearcoat. Paint work is complete!
emspjay
05-31-2019, 05:01 PM
That's beautiful!!
Shooter
06-01-2019, 06:25 PM
Dang. I think you better just hang that up on the wall and keep it as a showpiece. Are you really planning on putting that in the water with us yahoos!?!??!
K.R.Joye
06-10-2019, 10:25 AM
Its been 1 1/2 years since I started this project. A scratch built composite 8th Scale Hydroplane. OMG it feels so good to be done! Bench tested the Plett yesterday(goosebumps), testing starts this week.
K.R.Joye
06-10-2019, 10:27 AM
Luv this one!
Shooter
06-10-2019, 04:52 PM
I don't think the water in the pond is good enough for this boat.
K.R.Joye
06-10-2019, 08:58 PM
Thanks buddy
K.R.Joye
06-11-2019, 12:41 PM
Hey guys christened the `Miller' at my favorite test site today. The GM Tech Center 22 acre west pond(pic) with fellow engineers watching me.
Boat got right up on plane and ran 4 laps in 2" chop before the coupler loosened up. It went straight great and ran really smooth over the chop at approx. 3/4 throttle for the break in run. No heat on the equipment, propping up next time out.
Can already tell this boat is going to be a vast improvement over my past scales. :banana:
Mike W
06-11-2019, 03:20 PM
AMAZING build! You inspired me to finally order my hull kit. What does the finished hull weigh?
Doug Smock
06-11-2019, 06:13 PM
Sweet ride Ken! Congratulations!
K.R.Joye
06-11-2019, 06:35 PM
Mike The boat weighs 18lbs RTR w/10S1P Giant Power 6000s. Congrats on your decision to order your scale!
Hey Doug thx for the support buddy!
785boats
06-15-2019, 03:17 PM
Absolutely superb!!!
Congrats on the initial test run.
Coug90
07-03-2019, 09:42 PM
That is one nice looking boat there!! Nice build and finish work. It's a beauty. Now the fun parts of getting to see it out on the water, running and adjusting stuff for peak performance. We never stop tinkering and trying new stuff. Love the boat, man. Love the hobby.
K.R.Joye
07-05-2019, 07:24 AM
Update; I ran the Miller again a few days later after sorting my coupler issue. The tapped grub screw holes needed to be run through a couple times to seat better. Boat ran awesome with a X450/3 did 6 high speed laps and brought it in. Motor, battery & ESC temps were real good an no leaks I'm am really happy. I'll start checking for top speed with my old Geko in upcoming testing and report out.
