View Full Version : 1/10th 8255 SCALE BUILD - U-100 MISS ROCK
Speed810
01-21-2018, 10:49 AM
Well I had found that it was somewhat difficult finding an actual 1/10 scale build on here. There seems to be a piece here and another piece there.
So I started this on the well known Newton 8255 design & kit from ML Boatworks. The boat will be the 1985 U-100 Miss Rock. Haven't made a final decision as yet to power, ESC, or battery. A lot folks at MMEU have been getting into the 1/10 scale racing and everyone seems to be having a great time with them. So decided I had to build one....:smile:
Started off with building a jig for this build. I think that the Jig actually took longer to build than the framing in of the hull...LOL. You'll see the jig that the hull is sitting on. If you need a separate pictures of the jig just let me know.
I was also able to find some nice metal blocks to assist in the build. Picked up 4 lg. aluminum blocks ad 4 2X2X3/4 steel blocks all for $35.00. I thought that was a pretty fair price. All blocks are cut perfectly to 90 degree angles that helped out a lot with keeping the rails and bulkheads square thru out the build.
So everything on this boat had been test fitted together twice before I started up the gluing process. Doubler's were glued together for the transom and both sponson transoms. After everything was test fitted for the final time the gluing process starts with everything assembled from the transom up thru the #6 bulhead. What is really important is to just use thin CA to glue these surfaces together. Even when gluing with thin CA, go easy on how much is being used. If you want to save some time on your builds watch where the CA is being applied. You have many top and bottom stringers to install and you don't want a glob of CA blocking up the slots for the stringers.
The next thing was to add the remaining sponson bulkheads, stringers and the front nose sections. I then moved on to adding some glue strips to add to the glue area for the sponson sheeting. I use 1/4 sq. basswood under the ride pad and 1/16 sq. on all other sponson rail areas. The inside and outside interim sheets either side of the ride pad are the first to be installed. Then cut / sand the ride pad sheet to fit. All bottom sponson sheeting is 1/16. The top decking on this boat will be finished with 1/32 sheeting.
Next will be completing the turn fin, bracket and backplate before glassing and epoxy work. Also need top add rear wing mounts in the hull and complete glassing/epoxy work. Still trying to figure out what I want to do with the front nose section and air brake.
156347156348156349156350156351
Speed810
01-21-2018, 10:53 AM
Just some pictures of some of the sponson sheeting.
156352156353156354
785boats
01-22-2018, 12:18 AM
Sweet.
I love watching a boat come together. I can smell the birch wood from here.
lambo
01-22-2018, 01:48 AM
Can you post some more pics of the jig? I’m starting a similar kit. (ML 149 / mhr 8701)
Speed810
01-22-2018, 09:21 AM
Sweet.
Morning Paul....yes in deed...the birch wood saw dust is flying through the air...LOL :thumbup1:
Speed810
01-22-2018, 09:25 AM
Can you post some more pics of the jig? I’m starting a similar kit. (ML 149 / mhor 8701)
Morning Geoff....I’m at work for 1/2 day today, but will post some jig pictures when I get home.
Federal employee and caught up in the gov shut down....:ThumbsDown01:
T.S.Davis
01-22-2018, 09:42 AM
You decided to not carry those traps back. Very interested in seeing how that runs.
I think Ty might be spread to thin this season with all the killer boats I've put together for him. I might be running the 8255 Oberto for 2018. That class is stupid fun. The boats are all so close.
Speed810
01-22-2018, 03:55 PM
Hey Terry...
Yep decided to sand out the traps just aft of the #4 bulkhead. But I think I’m going to keep some of the air break up front. Really want see if it frees up the boat a bit in the turns, but keep it stable in the straights. Guess we’ll see...:lol:
I’m really looking forward to running it this summer. I’ve been watching you guys running these for the last two years and it just looks like to much fun...lol
Speed810
01-22-2018, 04:03 PM
Hey Geoff....
Well made it home after my 1/2 day of work...lol. But now it looks like I’m back to work tomorrow.
Here are some pics of the jig you were wanting. Let me know if you need any other info.
Just need to make sure everything is Square and flat. So take your time...it will be worth it in the end.
156412156413156414
lambo
01-22-2018, 04:22 PM
Thank you
T.S.Davis
01-22-2018, 05:15 PM
I've had this conversation a number of times with Mike. The physics aren't different with the notch in my opinion. It's still the air travel distance above vs the travel distance below the fuselage (so to speak). Negative pressure dictates the lift. Like a wing. He's not actually changing the dimensions by having the dam. It just looks worse.
Ty's boat is really fast, turns, and doesn't blow off the water so we'll take it.
longballlumber
01-22-2018, 08:27 PM
Hi Mike, where did you find the weight blocks?
Speed810
01-22-2018, 10:00 PM
Hi Mike....I got them over at Alero Steel. They have an outlet over here in Lansing. They have 8-10 shelves full of scrap aluminum, and different types of bar steel blocks. Cost was between $1.50 to $3.00 per lb. depending on the type of metal. They will even cut this stuff for you at $5 for the first cut and $1 each cut after that.
I didn't think that was a bad deal. Those blocks I found were all cut that way...LOL.
They might have an outlet over that way in Detroit. Or let me know if you need any and I'll see what I can find....
macomb
01-23-2018, 07:45 AM
There is another Alro outlet store on Groesbeck south of I696
longballlumber
01-23-2018, 08:26 AM
Thanks fells! always looking for ways to hold stuff in position while gluing.
T.S.Davis
01-23-2018, 10:06 AM
Did not know that. Wonder if Metal Mart on Dequindre would have a scrap shelf of sorts.
I've used aluminum chunks for years but mine are small. Those are sweet.
longballlumber
01-23-2018, 11:50 AM
"Ball's Bags" work really good for non flat surfaces, but a PIA if they break! Need a better mouse trap.
T.S.Davis
01-23-2018, 12:09 PM
bahaha Didn't want to say I broke Mike's "Ball Bag" but I did. Steel shot went everywhere. Wait........."Ball's Bags" are made of steel? Yes. Yes they are.
The steel shot are great for other things though. I cut the finger off of a nitrile glove and filled it with shot to make very exact weights to use as ballast. Need 3oz somewhere? Make one. I double up the glove layers.
T.S.Davis
01-23-2018, 12:10 PM
Now that I think about it........why not put the shot into nitrile gloves instead of latex balloons? Could work.
Speed810
01-25-2018, 09:19 PM
That's a great idea Terry!! Sure a lot better than trying to put a bolt someplace..LOL
Todd Fleury
01-26-2018, 08:45 AM
Use dive weights, they use lead shot. Also, you can buy them in any weight you need.
T.S.Davis
01-26-2018, 01:15 PM
Not sure why I didn't think of it before. Just put the steel shot I already have in a sock. Tie a knot. Done.
CraigP
01-26-2018, 01:42 PM
I did this with my mono. Fishing weights! They are taped to Velcro and applied in the boat. You can fine tune by snatching it out of there, add/subtract as you need.
Speed810
02-13-2018, 09:33 AM
Morning all... Sorry haven't posted lately on the 10th scale build. You haven't missed anything....I been working on buddies 1/10th scale for the past few weeks. I'll be getting back to mine hopefully this week.
Had a question for you expert sealing and finishing folks....:smile: Has anyone tried using the JD Total Boat penetrating epoxy system?
I am aware of the CPES system and seen some posts on that. Seems like it works really well. This appears to be the same type of system other than its a 2:1 mixing and its a bit less money. That CPES system is expensive, but I guess right on par with West Systems.
I have used West Systems for the past 5 years trying different thinning processes and just want to try something else where I can get away from all the clogging that takes place when sanding the hulls down. I have read some could reviews of guys using the Total Boat system on full size wood dingy type projects with very good results and hardly any sanding at all. They are usually mixing 50% acetone which makes it flash off and cure much quicker.
Appreciate any input you may have on this or different systems your using.
Thanks
Navherc130
03-22-2018, 10:53 AM
Maybe I missed it above. What class does this boat (1/10) run that is "stupid fun, all boats are so close!" I wanna try!!!! Thanks forum members....
T.S.Davis
03-22-2018, 11:41 AM
Just that. 10th scale. It's not run everywhere. I'm not sure any clubs on the east coast are doing it.
Navherc130
03-22-2018, 03:29 PM
Copy all. Thanks. I know district 1 does not run those. If you do,I think you have to run as p sport or q sport depending on length??? Still learning.
T.S.Davis
03-22-2018, 04:06 PM
It would be tough. We run the opposite way with our tenth scales. The ML boats are cut to turn left. If he cut one to turn right it would be subject the length limits for P. If it crested 34" it would become Q.
Navherc130
03-22-2018, 06:25 PM
My Atlas is cut with centerline mounting and equal dimensions starboard and port. Think it makes Q. 34.5" tip to tail.
cybercrxt
04-16-2018, 11:38 AM
I saw some questions in here I want to address...Left turning vs Right turning 1/10th hulls...My 1/10th scale kits are offered in both clockwise, and counter clockwise versions, which flip the frames so you can build it in either turning direction you need.
Next, addressing the quarter round on the bottom of the hull. I saw where Terry doesn't feel it really does anything, other than make the bottom look bad, lol. Nothing could be further from the truth. With that being said, I want to discuss a project I did with Don Ferrette years ago, which started all of this quarter round air dam being incorporated into many of my kits. I get a lot of people who feel they know better, and delete the air damn, or publicly say it does nothing. I love ya Terry, but you are wrong if you feel it doesn't work the way I intended it. Don set out several years ago, to break the 1/8th scale hydroplane FE SAW record which at the time, was in the 75mph range if I remember. Well, Don started testing, using the air damn technique, and he found his hull, which ultimately went 100mph with 10s and a 1527 Neu, would blow off in the 80mph range..So he added the air damn very close to the front of the bow block...and the hull stayed on the water and has never blown off during his 100mph runs. Fast forward the following year. Scott Liddycoat wanted to set a new 1/8th scale Nitro record, using basically the same hull as Don used for his FE record...The only difference, he had his quarter round about 4" back from the bow...and as fate would have it...he blew off in the 80mph range...the following trials, he came back, quarter round was moved to the front like Don's...His only hull change..and as you can see in the IMPBA record book, he posted a 93mph record. So Let me tell you, the quarter round works, it may be more subtle on a sport hydro, as I am able to make other aerodynamic features more correct for hi speed running, taking some pressure off the influence the bottom of the hull creates...but in the scale hydro world, you cannot change those curved deck features..The boat has to look scale...the only thing I can do, is mod sponsons, and center section bottoms...Having some features like this are important. Don has also run the 171 extreme 1/8th scale Elam kit in the 75mph range in heat trim, and he swears the quarter round bottom has made a difference. ML Boatworks works with many many top racers in the world, and has had those guys share a lot of secrets for the better of the hobby, and the chose me to do these because I listened. Believe in them, they are not just fancy hype! Sorry to rant, but I see a lot of people tell the mass public the things I do don't really do anything, and they are wrong.
Oh, and it was mentioned that Distance is the only thing that changes airflow speed...That is wrong. Diffusing the air with the air dam changes the time the air travels under the hull. It diffuses, rolls the air flow, slowing down how long it takes for the air to travel under the hull..That changes how long the bottom airflow vs. the top airflow take to travel. If that bottom time is longer than the top..guess what, you have a reverse airplane wing without the simple physics you normally see..You have to think outside the box!!
T.S.Davis
04-16-2018, 12:49 PM
Sorry Mike. I don't mean to be disrespectful. Especially with the effort you put into our hobby. Not everyone appreciates it the way I do.
An air dam is a bandaid used to fix a design flaw. This isn't really debatable. Don needs a dam because the boat has a flaw that was making it blow off. The dam was the fix. Design the boats so that the pressure on top is correct and you don't need a dam. It's not simple by any stretch but it IS wing design. Top dim longer than bottom dim across the tub will produce lift. You're using the dam to change the dimension across the bottom. Reducing lift. Works killer on a cat that won't stay put too.
I can accept that it's part of the design. I'm only suggesting the same thing could have been accomplished without it.
I don't think Ty's 8255 has been beat. Usually it requires a crash or some other break down. No 1/4 round.
Coug90
04-26-2018, 03:56 AM
I've never used 1/4 round on the bottom, but I've certainly tamed a few boats down with shallow L aluminum or carbon fiber across the tunnel. I'm interested in trying 1/4 round. Is it most effective with the flat facing forward or the round? Love to see a photo. Do you use one deep piece or prefer a few shallower pieces in line? I've noticed that adding things like this also changes how the boat gets on plane from a standstill but they certainly make a difference if a boat is a bit flighty. Thanks for sharing.
Speed810
04-27-2018, 02:23 PM
Let me start off by apologizing for not posting more on this build. With 3 boats going and everything else taking place this past winter season I just started running out of time.....:frusty:
The build went extremely well. Everything is 1/16 sheeting except for the top sponson sheeting which 1/32. Flotation is just 3/4 pipe wrap foam tube. I modified the front air-damn slightly, but still used 1/4 round and cut the angle down a bit more. I had to cut the sides out on the inner rail a bit up front in order to allow the batteries to fit across the tub. You will find that you will need to have everything up front as far as it will go if you build this hull with the rear wing. On the pre-balancing I found that I may even have to add about 2 oz. up front in order to hit the COG right.
I had read some other posts on OSE and one other that some were using the CPS penetrating epoxy thru Jamestown Dist. Co. Well decided to try this product and see how it worked. The standard mix is 2:1 and I also added one part of Denatured Alcohol. This epoxy went on great. It got two coats. After each coat I just used a white rag cloth and wiped it down lightly to catch the excess. Dried over night. What I was really impressed with was the sanding ability. It had barely any clogging / build up on the sanding block. It just dusted like I was sanding the bare wood. Went through half the sandpaper that I usually go through when using West System.
The finish is standard PPG Automotive paints and clear. Going to hit it one more time with a clear tonight to hit some spots that need attention. I think the biggest pain was getting the stripping put on and in a logical sequence. Anybody that has an easy way they do this, please let me know.....:lol:
The cowling and cockpit are from Mitch Dillard at HSC, along with the stacks and the driver was from Doug at ClassicHydros. A big thanks to both of these folks for all their help. If you would like any info on how I finished these just shoot me an email.
Here are a few pictures of the almost finished boat (1985 KISW). Stacks still need to be added and hardware installed. Have our 1st club race on Sunday, maybe I'll have a chance to test it out.
Coug90
04-27-2018, 09:26 PM
It turned out great looking! Nice work. Hey, send me a picture of it sitting in the water when you get a chance to launch it. I love those shots. I'll post it on my site. Glad I could be of help. Happy building!
Doug Smock
04-27-2018, 11:28 PM
The boat looks fantastic Mike! Very nice as usual!:bowdown:
785boats
04-29-2018, 04:28 AM
A superb model Mike.
It looks brilliant.
Speed810
05-04-2018, 08:21 AM
Hi guys...Thanks very much for all the great comments...:lol:
The boat ran great and looks awesome on the water...
Thinking I would like to build this boat in the 1/8 scale version.
A few photo’s of the boat from its first race day.159066159067159068159069
T.S.Davis
05-04-2018, 02:20 PM
Me too Mike. I would do the sausage boat. I just really really struggle to be inspired by 1/8 with there being so few places to race them and all.
Your boat looked great last weekend. It's beautiful guys. Run well too. More in the tank I think.
This hull itself is an easy build. The canopy.....not so much. One of us should have made a mold. Next time I'll glass the surface for less paint chipping. Ty's boat looks like it's been through a meat grinder.
CraigP
05-04-2018, 02:29 PM
Looks great and has very good ride characteristics!
Navherc130
08-20-2018, 02:20 PM
Maybe I missed it. What is your power setup of choice? Looks nice. I'm still looking for a driver figure.
don ferrette
08-20-2018, 08:52 PM
I apparently missed this thread earlier but not now. Terry..... think the world of ya man but I gotta disagree with you on this one. Band aid?? Not even close my friend, it's what the correct fix is. Design flaw? Well......... yeah it's called THE BOAT. Since they are scale replicas you can't make top side corrections to alter the air flow of something that is creating lift BY DESIGN. The real ones are trying to create lift. Our issue has become the opposite as even at just 50mph by "scale" sizing it's like trying to run the full size at 400mph. Certain hulls like the 8255 don't trap a lot of air under them compared to some others but the real ones tended to run "wet" and why that design only lasted about 3 1/2 years- 82 to roughly early 86 (not counting the hangers on that were around a couple more years). The "108" style hulls (7207,7474) work great with the air traps cut off immediately aft of the sponsons but the reshaped bottom is best for most others. I say reshaped because it's not an air dam per say but a lowering of the belly to speed up airflow and reduce pressure build up. You saying "Top dim longer than bottom dim across the tub will produce lift" only supports what we do- reshaping the bottom to try to offset the top shape. And I'm sure Ty's boat runs quite well but to use that to discredit what the 1/4 round drop accomplishes across the board is wrong. I've raced 1/8 scales for over 20 years as well as setting nitro and FE scale records and no one has officially gone as fast as I have (Liddycoat came close using what he saw me do) with an 1/8th scale and have shared a lot of what I've found to work on them with Mike for the sake of improving these boats.
T.S.Davis
08-20-2018, 09:35 PM
, it's what the correct fix is..
Did you read that before you posted it? Haha. If a design is correct why are you fixing it?
A design that uses packed air and/or negative pressure to work requires a delicate balance. If it's off you have to "fix" it. That's all I'm saying. Some of the designs we're emulating weren't very good in full scale.........so.......we....um......have ta........do something........what was it?.........slipping my mind. What were we talking about again?
T.S.Davis
08-20-2018, 09:36 PM
Almost all of the guys from our club are running the Proboat 1500kv motor. 4s lipo around 6k. As little 120 amp esc works. I like the Raider150.
don ferrette
08-20-2018, 10:37 PM
LOL!! The design isn't correct but we can't change the top shape because...... so we change the bottom. All good my brutha!
