View Full Version : Gps
CharlesR
01-11-2018, 10:04 AM
Any suggestions on a GPS it would solely be used to record speed runs
MADRCER
01-11-2018, 10:31 AM
Check ebay for a Garmin Forerunner 101,201,or 301. Or the dynamite gps linked below.
http://www.advantagehobby.com/256353/DYN4401/GPS-Speed-Meter/?gclid=EAIaIQobChMItqCk6pzQ2AIV0bXACh2nCQGFEAQYAyA BEgIUe_D_BwE
Bp9145
01-11-2018, 01:10 PM
I have both the Garmin Forerunner 101 and the 201 and it seems the 201 picks up the satellite signal faster. Also I've put both in the same boat and sometimes they were off with each others readings as much as 2mph. Usually with the 101 less than the 201. So I would go for the 201 as it would give you higher speed readings. . and that I like more. LOL. and as Mark indicated you can get them on eBay for a great price as these are older models.
fweasel
01-11-2018, 01:20 PM
I use the Forefunner 201 and 301 models. The 201 uses a proprietary charger and the 301 charges straight from mini-USB.
CharlesR
01-11-2018, 02:37 PM
Thank you everyone
CharlesR
01-11-2018, 02:41 PM
These are runners watch's is that correct
boatsrnew2me
01-11-2018, 03:00 PM
no ,not watches persay . wearable yes ,would i consider it a "watch" no .
https://www.ebay.com/itm/Garmin-Forerunner-201-GPS-Fitness-Watch-Training-Running-Biking/173076802073?hash=item284c2e6a19:g:dFYAAOSwPypaTvV I
fweasel
01-11-2018, 03:02 PM
Yes, the Forerunner 20X series was the original design from Garmin as a wearable GPS device, promoted to runners, hikers, and bikers. The velcro wrist-strap is removeable with traditional watch band spring loaded pins.
dethow
01-11-2018, 03:07 PM
RC BoatBitz out of AUS has some new tech you could consider. It's real time telemetry with GPS. All waterproof for use in boats and sends data back to Android device in real time with average and top speed readings. I think these would be nice for speed runs as you'll also get real time reading on motor, esc and battery temps.
I bought a couple of these to test this summer. I'm really surprised by the small light weight components. Garmin 301 weight is 2.3 oz while all components for this system total in at 2.4 oz. That includes sending unit, GPS unit, and all sensors. Costs $77.50 USD plus shipping from AUS. OSE sells these for $65 but out of stock for some time now. OSE's additional images show the nice read outs you get.
Only real drawback compared to a Garmin is that you need a different system for each boat and/or setup for easy transfer. But I think it would take unwanted time no matter what to transfer all components from one boat to another.
http://www.rcboatbitz.com/index.php?main_page=product_info&cPath=131&products_id=2629
https://www.offshoreelectrics.com/proddetail.php?prod=ose-83279
CharlesR
01-11-2018, 04:04 PM
I did not mean to refer to it as a watch .I meant it's wearable which was just a way of describing it .I'd just like to know if it will work Thanks
MADRCER
01-11-2018, 09:11 PM
Charles, Yes the Garmin Forerunner series work well in boats, as long as they aren't made out of carbon fiber. See below pictures of both units.
156130 156131 156132
NativePaul
01-12-2018, 03:28 AM
There is a big difference in the watch style GPSs and the much bigger but still wearable devices. All the watch styles only ping the satellites at 1hz to save their tiny battery, whereas most of the bulky wearable ones like the garment above ping at 10hz.
dethow, does that telemetry system save a log of the run to the phone as well as showing live data? I have always seen loggers as much more useful than telemetry as I can't look at data and drive at the same time.
fweasel
01-12-2018, 03:11 PM
There is a big difference in the watch style GPSs and the much bigger but still wearable devices. All the watch styles only ping the satellites at 1hz to save their tiny battery, whereas most of the bulky wearable ones like the garment above ping at 10hz.Agreed.
Not to split hairs, but the Forerunner 101, 201, and 301 were the first watch style units. The reason they didn't look as much like watches or run on actual watch batteries as the models do today, was because the technology wasn't there at the time.
CharlesR
01-12-2018, 03:24 PM
Thank you for information
dethow
01-12-2018, 03:45 PM
I haven't used them yet... but from what I've read and seen on OSEs additional photos it shows live data AND logs with both average and max for speed and temps.
Understood that no one can look at data and drive at the same time... but it'd be nice to be able to check out your speed and temps right after making a speed pass. And be able to see when your temps have dropped to a safe level for your next pass.
As for oval racing... I'd like to stop my boat after a lap of testing a new prop to see what speed was and where temps are without having to bring it in and untape. If speeds look good and temp looks good... now I'll throw down a few laps, stop and see where temps got to. This could reduce testing and setup time dramatically.
fweasel
01-12-2018, 03:50 PM
Exactly!
dirtdummy
01-12-2018, 06:46 PM
I like that bringing in opening and taping again is a pain.
