MGM esc programming problem
This is a sticky topic.
  • triton
    • Jun 2015
    • 48
    Hi
    May I need some help about the controllers programming?
    Three MGM controller what I have and the same problem with all.
    I use the default factory settings only a few parameters what I was changed. Like lipo cell, cut off voltage and the programmed throttle control.
    The problem is when I pull full throttle, around the middle of the throttle position the ESC block the motor.
    I was emailed with Martin from MGM and he said try to change the P16 parameter. This is the acceleration time or use a smaller prop. Now the p16 on 9.(default 1.5). So it's better but not the real one. The acceleration is too long time and need a "kilometer" for full speed
    The setup:
    Agitator XL cat
    Twin 5660 tp
    12s lipo
    x457 props reduced to 52
    250.63 x2 MGM
    The other mono boat do the same with the 400.63 ESC.
    I think something I do not do well.
    Is there any idea what to do?
    Regards Peter
  • RaceMechaniX
    • Sep 2007
    • 2827
    Peter,
    What radio and receiver at you running? Do you have a servo tester that could replace the receiver and test the motor and controller using the tester to rule out the receiver/radio.
    Also, which motors are you using?
    Tyler
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • triton
      • Jun 2015
      • 48
      Hi Tyler
      Sanwa m11 and rx 441 receiver.
      With no load the rpm goes to max.
      Under load comes the limit.
      With another futaba radio the same problem.
      • RaceMechaniX
        • Sep 2007
        • 2827
        Try setting the timing to a fixed value like 10 Deg instead of Autotiming.
        Tyler Garrard
        • triton
          • Jun 2015
          • 48
          Timing 6 degrees
          The motor type tp5660 7D
          I know it is on the limit with 12S.
          Is there a problem?
            Several guys in the local club reported seeing something similar with their HV MGM controllers. Throttle drops off after a short time, logging shows excessive amps even with proven setups, etc. These guys are not newbies. That’s all I know at the moment, odd.
            • RandyatBBY
              • Sep 2007
              • 3915
              Mine does the same thing on launch. I always roll in to the throttle lightly. If I seam to pull the throttle too quick it blocks/or stops it. Once I get to full speed I can then hammer it at any speed. I am running a 1530 .5Y MGM 400-63 and a 47MM prop on 4S3P in a 34 inch sport Hydro.
              Randy
              BBY Racing
              • triton
                • Jun 2015
                • 48
                I'm not happy to hear tha similar.
                I was changed all the cheap controllers (like flier,hifei,turnigy) for mgm professional ESC. These are 4 times more expensive like the others, and now I cant pull a full throttle with a 400Amp Pro ESC. Incredible.
                • RaceMechaniX
                  • Sep 2007
                  • 2827
                  1180kv is pretty hot for 12S. I am not too surprised. You are likely seeing current limiting due to high phase currents.
                  Does it do the same behavior on 6, 8 or 10 cells?
                  Tyler Garrard
                  • triton
                    • Jun 2015
                    • 48
                    Not yet.
                    Next time I will try with 10s and share the experience.
                    Do you know how does the controller measure the peak and the input current?
                    Because after last track the peak was 810 amper, the input was 237 amper.
                    • RaceMechaniX
                      • Sep 2007
                      • 2827
                      The MGM's track both DC input current and AC phase current. With hot motors, it's usually the phase current which will cause them to start current liming.
                      And if your data is showing 810A AC peak, then that is too much.
                      Tyler
                      Tyler Garrard
                      • rayzerdesigns
                        • Dec 2013
                        • 1228
                        I have had same issues with the mgm.. if u haven’t updated the firmware please do. It helps but does it eliminate it.. I’m not happy with mine either
                        • triton
                          • Jun 2015
                          • 48
                          I found another topic on OSE, and the guy who uses D wind motors like me, has the same problem. He said will try lehners but no response from him yet.
                          Possible the MGM does not work well with the D wind motors?
                          • photohoward1
                            • 1610
                            800amps? 12s on a 100 KV Motor? Why?
                            • triton
                              • Jun 2015
                              • 48
                              This came from the controller databox. This is the peak current. The input current much lower.
                              I dont know how.
                              The motor 1188kv.
