Tom G
09-29-2017, 02:20 PM
Making a return to 1/8th hydro's after a 20 yr hiatus. This hull will be one of the 1995-99 Miss Budweiser T-5 if I get the Namba hull registration. Or if not it may change to one of the others hull's this 9601 kit can recreate.
Spent a few hrs making a build fixture, punching out all the parts and dry fitting to make sure all is right before starting the glue up.
I did find one issue with a few of the engine well side panel notches for the rear non-trip ribs the laser missed cutting so simply set them up in my milling machine cut them with a 1/16 end mill. All the dry fitting is done waiting for the BVM V epoxy, carbon fiber and resin to show up in a day or so.
MORE TO FOLLOW
154015
154016
MORE TO FOLLOW
154015
154016
