View Full Version : HK/TFL Pursuit Mods
Hydrocarbon82
09-17-2017, 08:13 PM
The HK Pursuit was on sale so...I got it in 5 days from AZ to WI, zero damage. Their website doesn't show updated pictures, so I hope this helps somebody.
The first thing I did was order an OSE single-piece driveshaft. This version uses a full 3/16" shaft, 1/4-3/16" teflon stinger bushings, and 7mm stuffing tube with teflon liner. I got it set up with a Flycolor/Raider 150A with the stock motor & M445 and it only did 36mph - really disappointing. I put in a GoolRC 3674 2250kv and that bumped it up to a consistent 43.3mph, but the ESC was thermaling on occasion. Batteries are Gens Ace 5500mAh 45C 4S.
I decided to reconfigure a few things. First was the stinger - I replaced the lead teflon with 1/4" x 0.014" & 7/32" brass tube to replicate a Speedmaster bushing. The bushings came out with a drift & hammer, but the brass needed some mild sanding. While doing that I noticed the stuffing tube was drilled nearly 1/8" off from the stinger centerline! TFL used a nice silicone gromit, but it doesn't let the tube move down low enough. I just hogged out the hole & added some silicone.
After that I put new SS bearings in the motor. I also changed from 4mm to 5.5mm connectors on the motor. The last thing was to shorten that strut turnbuckle on my lathe. It was maxing out while the strut was even & has more adjustment now.
Next test lead to zero esc thermaling, much cooler motor, and an increase to 48.5mph. It was a busy day on the lake with some mild chop. It still seemed to ride perfect in the water, so I decided just to enjoy it rather than try strut adjustments. Keep in mind this motor is nothing like a Leopard. It's a $23 motor and I'm fine with performance since it's a sport boat.
To condense speed info:
36mph - stock 1620kv motor, M445, mis-aligned strut
43mph - 3674 2250kv motor, M445, mis-aligned strut
48mph - 3674 2250kv motor, M445, speedmaster-style bushing
39mph - same as last but with 2x SPC 2S 5000mAh 40C instead of Gens Ace 4S
https://i.imgur.com/7kQfuF6.jpg
https://i.imgur.com/75BlrbC.jpg
https://i.imgur.com/Bz9opsq.jpg
https://i.imgur.com/AoIBW1y.jpg
https://i.imgur.com/onDfncR.jpg
runningman
09-17-2017, 11:49 PM
What runtimes do you have?
srislash
09-18-2017, 12:29 AM
Good improvements, nothing wrong with 48mph. Good work
iop65
09-18-2017, 01:38 AM
Prop needs some sharpening
Hydrocarbon82
09-18-2017, 02:34 PM
I didn't want to go too far since it's just a sport boat prop. I know it's far from a "bad job", as this M445 is on par with my X642. It was a little faster on my Revolt and a little slower on my Shockwave. The guy who sold me the X642 thinned the heck out of it, sharpened it like a steak knife, de-tongued it, and claimed to have checked it one of those expensive prop modding/measuring rigs.
As far as run times, I can't really say since I mix full throttle passes along with holeshots & slow sweepers to entertain the kids & dogs. The first runs before the stinger mod were 5 mins max & runs after felt like 10 mins. I actually pulled it in before LVC because I thought it wasn't working.
The next step is my custom datalogger. I could have bought an Eagletree, but I wanted bluetooth so I don't need to pull the hatch. It's $15 in parts and will use a 200A version of the Allegro amp sensor, a 10hz ublox GPS, and IC-type thermisters. I also want an RPM sensor, either optical or hall.
https://i.imgur.com/TYInn5I.jpg?2
runningman
09-18-2017, 02:54 PM
Interesting. I put 2200kv motor and with m440/3 prop got 72.9km/h. on 2x5000mah batteries. But not sure if my run times more than 5 min. m445 should draw more umps on more kv motor. No?
MadProps
09-18-2017, 02:55 PM
whats the stinger mod you did?
runningman
09-18-2017, 02:56 PM
Just O-ring mode. Nothing special.
MadProps
09-18-2017, 03:04 PM
OK....I was trying to account for your increase in run times
edit: possibly you were running a little wet and then you changed the angle a wee bit positive doing the mod?
boatsrnew2me
09-18-2017, 03:16 PM
Mine ready for a evening run 153874
runningman
09-18-2017, 03:25 PM
I think you need to ask Hydrocarbon82, not me :)
MadProps
what motor are you running?
I just tested mine with a new 4082 1600kv 42mm octura 2 min ago, runs great, started to do a little tuning then it started raining on me ....will also try a 45mm octura when the rain stops
good luck on the run tonite!
Hydrocarbon82
09-18-2017, 04:18 PM
Looks like a healthy 6S setup, Boatsrnew.
Straightening the flex cable's transom exit & replacing the teflon bushings with 2pc brass bushings. The cable has 1 bend now instead of 3, so a bit less friction at 30k rpm.
I eyeballed the strut as level as before. I think it's just good a better combination of strut angle, motor connectors, bearings, and flexshaft friction.
I'm not a prop guy, but what I've seen shows a 445/2's load similar to a 440/3. 73kmh translates to 45mph. Before the mods I considered a 442/2 due to overheating. Most people seem to run ~2000kv in a 4S Pursuit with an M445, so we're probably near the limit.
MadProps
09-18-2017, 05:36 PM
ya I got members crossed
boatsrnew2me
09-18-2017, 05:44 PM
leopard 4082 1600kv with a ose b&s x645 . my best run has been 57.4 . todays best 52.1 ,i could use higher c lipos . most are 50c .achieved my best speed on my turnigy heavy duty 3s 5000 60c set .they are some stout lipos for sure .
motor barely gets warm ,highest i have seen is 105 ,most times high 90`s . the flycolor 150 esc gets a bit warmer then that ,i have seen 150 on the caps and 135 on the sink.
after a few hard passes lvc kicks in and i have to slow down or stop for a few until the lipos recover ,then its back to the races .the flycolor esc does a good job of protecting my lipos so that doesnt bother me .
i set my timer for 5 minutes and my lipos come in at about 30%. i have never tried the front lipo tray ,i went this way because i already had a bunch of 3s lipos for my other boats .
MadProps
09-18-2017, 06:03 PM
me too
my temps were 90-95F
my LVC also kicked in so I lowered that setting because I run with LV alarms and a timer
I now have the hull dialed in will get a speed check tomorrow
what timing are you using I set mine to 11.25
thanks
boatsrnew2me
09-18-2017, 06:45 PM
me too
thanks
same here
Hydrocarbon82
09-19-2017, 11:34 AM
Talk about timing got me thinking. I believe I had mine set to 3.75 or even 0 degrees for another [delta wind] motor. I'm going to try 7.5 & 11,25 degrees next time, it should be interesting.
MadProps
09-19-2017, 11:43 AM
talking about timing......
without a data logger what should one expect to see when advancing timing to get better running motors...hotter esc, motor, batts?
Hydrocarbon82
09-19-2017, 02:41 PM
Yes everything will get hotter, more timing generally creates more load (amps). The "sweet spot" is generally no hotter than what a non He-Man can touch for over 5 seconds. Once you pass the "sweet spot" for a particular motor or setup, it will use a lot more amps for a marginal speed increase. In some cases you'll draw more amps but be slower, particularly true with delta-wind motors.
You can also lower timing below the sweet spot if you need less heat but can't prop-down, or if you need to run the hull wetter due to chop.
MadProps
09-19-2017, 04:33 PM
thanks
Hydrocarbon82
09-24-2017, 08:57 PM
I got the gps unit working and tested some old 4s turnigy batteries in parallel. Max was 48.6mph. The gens aces did a little better at 50.5mph.
The great thing about this gps is i don't have to pull the hatch off to check speed. I drive it next to the pier, connect via smartphone, and it spits out the numbers below. When i send a command it resets the max after saving it.
https://i.imgur.com/3PVvypT.png
https://i.imgur.com/yQ2Rhg4.png
Hydrocarbon82
09-25-2017, 06:16 PM
Slow-motion vids of the 48-50mph runs. Only time it chine walks is after a few decent waves at full speed. The turnigy batts put the CG 35-40% from the rear but didn't alter speed much.
https://www.youtube.com/watch?v=a00WCtyw0XE
Hydrocarbon82
09-25-2017, 06:21 PM
It sounds pretty cool at half speed, almost like a full scale boat might from a distance
https://www.youtube.com/watch?v=fhYjqSKF_XM
Hydrocarbon82
09-27-2017, 02:36 PM
I set timing to 7.5*, raised the inner trim tabs just above flush, and trimmed the strut down 1/2 turn. Best speed was 51.8mph. It would start skipping on turns so I put the outer tabs down a bit, but it was also fairly rough water. I got some air a few times but this boat just don't want to flip. My last 2 boats would practically flip at random above 35mph, and trimming them down just lost speed.
T.S.Davis
09-27-2017, 03:04 PM
Good ole' Pursuit. Great boats.
runningman
09-27-2017, 05:09 PM
Cn you show what you changed lead teflon with? And how it looks like now.
Hydrocarbon82
09-27-2017, 11:31 PM
Unfortunately it looks virtually the same. Look at post #1 - picture #4 shows the 7/32" floating bushing already on the flex shaft and #5 shows the stinger with the 1/4" tube installed. First I pressed out the lead bushings by hand with a drift (towards the front), next I cut a 60mm length of 1/4" x 0.014" tube, then chamfered the edges & sanded the OD before pressing it in. I had to put the stinger on a wood block to tap the 1/4" tube in. I tried a drop of loctite but started grabbing before it was in half an inch.
I found a pic with the K&S tube in the stinger for a test fit:
https://i.imgur.com/VWfdvzT.jpg?1
Insanity Plea
09-28-2017, 05:43 AM
I like the stinger mod, I was thinking of doing something similar, thanks for sharing. I've already done the 3/16 flex upgrade and installed a Leo 4075 1750kv, running 5s with a X642 from Dasboata. 48mph has been my best of two outings, stinger is strait, temps are around 110. Fun little boat to play with...
MadProps
09-28-2017, 10:24 AM
Im a little confused here are have you discarded the bushings completely and running on the 1/4 tube only?
runningman
09-28-2017, 12:30 PM
No. 7/32" floating bushing already on the shaft. Look at #4 pictures of firsts post.
Hydrocarbon82, thanks for sharing. Will try to find and buy a new TFL stinger to modify over winter.
Peter A
09-28-2017, 03:25 PM
I have just done pretty much a similar mod to my Pursuit. I am setting it up for endurance so I wanted the teflon liner gone and a better oiling system for the shaft. I replaced the teflon liner wit a 1/4" brass tube all the way through the stinger. The 1/4" tube is slid up through the original brass tube. I have a speedmaster floating bushing (the one with holes in it) in the stinger end. It is worth the mention that I removed the original teflon bushes which have had 4 years use and had next to no slop. I put an oiling 'can' into the existing oiling tube on the shaft. I have replaced TP 4050 2050kv motor with a smaller TP 3630 1500kv one as the goal is for long runtimes. I need 10 minutes from 4S 2P 10000 mah. It will keep the speed down but this is about testing the theory, so I need to get the current draw to around 40-45 Amps average.
Here is a pic of the new setup, esc is still an OSE 150 Raider. The second pic is from my phone, using the RCM Telemetry, of a run I did last Saturday around the same course petrol offshore boats were running. It was with the 4050 motor and revo Go packs, 4S 5000mah 2P. I inadvertantly ran the packs right down as the LVC didn't kick in (set at 3.2v) and they took over 4900mah to charge back up! They didn't puff or seem to have suffered. Prop was a detongued X442. After about 7or 8 laps one of the guys timed me at 27s for a lap, which was as fast as the gassers were running. The 12 laps done in six minutes equates to 40 laps for 20 mins, the best the was done on the day was 38 laps for 20 mins, by gassers with bigger more powerful boats. Just interesting.
154007154008
runningman
09-28-2017, 04:19 PM
154007154008
Thanks for shearing. What oil can did you use? Was it direct fit?
Which speedmaster floating bushing do you use? Do you know where to buy a new stinger?
MadProps
09-28-2017, 05:16 PM
154007154008
does the 1/4 tube go all the way into the boat to the end of the existing tube....what Im getting at is drilling the oil hole in the tube(s)? if your drilling thru both are you epoxying the tube to keep the holes lined up or is easier to just cut the inner 1/4 tube shorter....I have a 1/4 tube already to eliminate the liner tube mod and would like to add the oiler aswell
yes please post a link to your oiler parts and thanks for posting your mods
ray schrauwen
09-28-2017, 06:26 PM
Where did you get the motor wire separators?
Peter A
09-28-2017, 06:53 PM
The oiler was one I made a couple of years ago the was sitting around, If I was going to by a new stinger it would probably be a speedmaster one https://www.offshoreelectrics.com/proddetail.php?prod=ros-stinger-str 3/16" or https://www.offshoreelectrics.com/proddetail.php?prod=ose-80990.
The bushing https://www.offshoreelectrics.com/proddetail.php?prod=ros-spdsd-187
Peter A
09-28-2017, 06:57 PM
Yes the 1/4" tube goes all the way through plus a bit more to fit some silicone tubing on to make a shaft seal. The original tube fits the transome hole and the stuffing tube holder, it all makes a nice fit. I annealed the 1/4" tube after fitting it into the stinger (which I opened up with a 1/4" drill bit) so that it would shape easily to slide into the original tube. Once it was in place I just drilled the oil hole through.
Peter A
09-28-2017, 06:58 PM
Car wreckers, they are off spark plug leads.
MadProps
09-28-2017, 08:17 PM
thanks
