As a newcomer to the hobby, I have been doing some research to determine what would be best to use. I have an older ABS 70 cm mono that I have removed the old stuffing tube skeg leaving an opening in the hull approximately 10 mm wide by 100 mm in length. I also would like to reinforce the transom and lower part of the inner surface of the hull.
As I am converting the hull from skeg drive to transom mounted surface drive, I feel that the transom will need beefing up plus keying it more securely to the hull inner surface. I also considered laminating very thin plywood between the transom inner face and the fibreglass/carbon fibre mat to further reinforce the transom. Now my research has returned that polyester resin will attack and distort the ABS plastic and epoxy will not securely adhere to the surface (bond strength too brittle for flexibility), I am left with the somewhat expensive West System G-flex 650 epoxy resin. The manufacturer's spiel states that it will bond to ABS and provide flexibility if the surface is sanded.
My surface preparation has involved 80-grit sanding of the surface. I am thinking of substituting woven and chopped strand fibreglass mat for carbon fibre strips, overlapping down the centre of the hull. Would this be a problem, please? Does carbon fibre require any special wetting out technique?
This is all new to me so any help is appreciated.
