View Full Version : 32" single cat sport build
kfxguy
08-28-2017, 05:08 PM
Wassup fellas. Haven't been posting many builds here, doesn't mean I'm not working on things though. Sometimes I just don't have the time to take pics and post them. I do like to share some of these builds sometimes, but I've refrained from it because a lot of times it's very close to the same thing as the last one. Well this one is a tad different. Different in the fact that nothing in this boat is expensive. It's all cheap components I had laying around. And to add to it, most of the boat I didn't build but I had a hand in a good bit of it. Complacent one is who built the boat. I hand made the servo mount, battery trays and esc mount (which I removed). He did the inlay and installed the hardware and motor mount. He never ran the boat, I think he lost interest in it and then sent it to me because he knew this is my favorite hull. He started a blue theme which I kept and added to it by laying up some blue carbon/Kevlar and wrapping the motor cooler and I just so happened to have a blue servo. He used blue colored epoxy that looks pretty awesome. I think I may put a blue carbon strip on the esc like the motor has. Here's the list of parts:
Tp power 4060 1720kv motor
Ose raider 150 with cap bank added
Savox blue waterproof servo
.187 flex of course
Mbp collet
Tfl hardware
Carbon battery trays
Carbon servo mount
Honey comb carbon inlay
I ran the thing on 4s a couple weekends ago. It went 54mph without trying. Not bad for a knockaround boat. I think if I put 6s in it, it will surpass 80mph if I decided to. I was really looking for about 60mph so I may have to do some tweaking to it.
I still have to paint the hatch. I added 5 layers of fiberglass to it last night. Maybe today I can spray the base boat. I have a really sexy looking blue for it.
https://s26.postimg.org/lqokd3p6h/IMG_9074.jpg (https://postimg.org/image/52x2aluet/)
https://s26.postimg.org/gqr455jjt/IMG_9075.jpg (https://postimg.org/image/ssmhzass5/)
https://s26.postimg.org/59h6wxoop/IMG_5566.jpg (https://postimg.org/image/5yzz9ap85/)
This is the color I'm painting it. I'm trying to decide if I'm going to extend the color onto the boat.
https://s26.postimg.org/gbqv94855/IMG_8362.jpg (https://postimg.org/image/6efug20j9/)
srislash
08-28-2017, 08:21 PM
Oh I like that color Travis. You can find the other 6+ mph.
R2315
08-28-2017, 08:31 PM
You do nice work! very clean, Looks amazing!
fweasel
08-28-2017, 09:05 PM
That blue looks fast for sure.
kfxguy
08-28-2017, 09:51 PM
Yea man that color is sharp. I want to add a design to the top of the boat in blue, something simple but to make it pop. And I'm sure the same ole colored top with carbon boat is getting played out. The only big issue I have is I don't want to clear the whole boat so I'm probably going to attempt blending the clear in. Not sure if I can make it happen tho. I'm not the best painter.
kfxguy
08-28-2017, 09:59 PM
Thank you sir! Here's another boat just like this one I built, my pride and joy I guess you could say. Not sure if I could ever part with this boat, on a mere 4 cells it goes 102. Probably faster now that I have some better props but I haven't run it lately. But it's super clean....
https://s26.postimg.org/iwf13yed5/IMG_4032.jpg (https://postimg.org/image/qp5ovxkc5/)
Mxkid261
08-29-2017, 08:20 AM
What prop did you have on that one again? And where did you have the strut roughly? Any angle to it?
kfxguy
08-29-2017, 08:33 AM
I usually run an abc 1815 and I think the strut is level. It's about .150 off the table if you lay it all flat on a table
Mxkid261
08-29-2017, 09:05 AM
Thanks. I haven't ran mine in like over a year. It went 72 but I think it has a little left in it. My strut was definitely a considerable amount lower than you're running. It was running pretty wet, I gotta get it aired out. I need to wipe the dust off it and start tinkering with it again. Probably will once the weather cools down, it runs a little hot Lol.
kfxguy
08-31-2017, 10:41 AM
Got the hatch painted and the trim on the esc done. I'm really thinking it needs a stripe on the boat itself to finish it off
https://s26.postimg.org/9z526cth5/IMG_9121.jpg (https://postimg.org/image/jjoot8it1/)
https://s26.postimg.org/fw4c9fl89/IMG_9119.jpg (https://postimg.org/image/sar49rcqd/)
https://s26.postimg.org/3k619omrd/IMG_9113.jpg (https://postimg.org/image/5bz04l645/)
https://s26.postimg.org/uxb84ftbt/IMG_9112.jpg (https://postimg.org/image/vzlemzc51/)
fweasel
08-31-2017, 11:02 AM
It's a good blue.. Maybe a single, offset stripe down the entire length would be worth mocking up in tape. Possibly even a 3/4" stripe flanked by a 1/8" parallel stripe. All personal preference I suppose.
kfxguy
08-31-2017, 12:13 PM
This is what I was thinking. It's simple. I've been wanting to do this for a while but the problem is clearing it. I don't want to have to clear the whole boat.
https://s26.postimg.org/3onqpe915/IMG_2766.jpg (https://postimg.org/image/s55wjv9rp/)
kfxguy
10-07-2017, 10:51 AM
I wanted to add, I sold this boat (most of you know that) and the new owner ran it on 6s once in windy conditions and I guess he couldn’t really get on it for long but it still went 81mph. I only ran it once and it went 54mph on 4s. I told him I thought it would go about 80mph as it sits on 6s. Pretty good estimate!
CraigP
10-07-2017, 11:53 AM
What's the Ford head to? Are those exhaust ports ported out?
kfxguy
10-07-2017, 12:21 PM
Ls 243 heads I’m porting for my gto
CraigP
10-07-2017, 07:36 PM
What year is your goat?
kfxguy
10-09-2017, 05:29 PM
2004
