montymike
08-18-2017, 09:49 AM
Have a twin cheetah with 1515 2200 s castle black in it x442 props and2 hobbywing v2 speed controls 0n 4s only goes aboat 30 mph put batteries all the way back to motors and adjusted batteies all 1esc will beep other won't depending on which one i hook up first that one will beep other won't. Have tatic radio.
have r/l props tuning in. Not sure aboat one speed control. On port
side that motor does not seem to turn as fast .One battery is draining normal and one is not draining but a little. Another strange thing is if you hook up one battery other motor runs .
connected by y connected. Do i have a bad esc, motor ore somthing else.also adjusted both strut angle helped but this boat should go 50+.
