View Full Version : Boat stands for large cats and monos?
lt130th
08-03-2017, 12:19 AM
I'm looking for low profile stands for a couple hulls. I need one for a 73" cat and one for a 59" mono. I've searched but found nothing like what I have in mind. I just want something simple, like what typically comes with 30-40" RTR hulls. If nothing like this exists, I'll go a totally different direction with a DIY wall-mount solution for these hulls.
A stand similar to this would be fine:
153050
rol243
08-03-2017, 01:47 AM
just make them yourself. all you need is some plumbers plastic water pipe , some 90 degree bends and some foam rubber.
lt130th
08-03-2017, 02:43 AM
I'm looking for something more for display purposes. These hulls are kept in my office.
monojeff
08-03-2017, 02:49 AM
I would be happy to discuss making something more fancy for you if you want PM me and we can chat.
I can make anything you would want out of just about any material you would want.
lt130th
08-03-2017, 03:12 AM
PM sent, Jeff.
Thanks,
Michael P.
Aectryx
07-01-2021, 04:02 AM
lt, you ever and up finding a good option for this or a wall mount?
lt130th
07-01-2021, 10:12 AM
I didn't find anything available to buy for resting on a surface, so I went to a wall mount. I ended up making my own, using brackets I found on Aliexpress, and carving carbon fiber plates to whatever shape I needed to cradle the different hulls. I'm away from my office, so I don't have an image right this minute to share of the boats, but I do have a pic of how I did it for a large Mongoose 98 rocket:
173019
lt130th
07-01-2021, 10:17 AM
I can flip the brackets 180 Degrees depending on the type of hull, or where it's mounting, vertically, on the wall. It's a fairly versatile method for whatever type of craft you want to mount. And you can make the carbon plates adjustable by pivoting at the top or bottom bolts, to allow tilting it at whatever angle you want. I'll add pic's of how I did this for a boat, later.
1coopgt
07-01-2021, 06:27 PM
More Pictures . Very cool mount for the Rocket.
