I'm about done building my new Smash Shark and its time finalize my OSE order for the last bits and pieces, unfortunately there isn't a whole lot of info out there on this boat.
Its 4s 5000's 50c thru a Sea King 180a.
I need a good prop. I read somewhere this hull works well with a 3-blade, but I don't know the specifics?
I dont want it running hot or short run times, this is a basher for around the dock, but I don't want to give up a bunch of top end either.
Also need..
Longer rudder (that either mounts to existing TFL bracket, or at least uses the same holes + a couple new holes if needed?)
One-piece cable/shaft
Larger turn fins
Trim tabs
I'm not overly familiar with boats (particularly what size of things I should buy) and most of the info I've found on alternative parts for this boat refer back to HKing and its old or out of stock... and I'd much rather buy from OSE anyway.
What would you add to it?
Also need..
Larger turn fins
Trim tabs
