View Full Version : New esc for 1/8 scale
chevelledude
07-07-2017, 10:24 AM
After reading many posts about esc's Iam no closer to knowing whats good out there. I have a 1/8 ml boatworks executone hull with 1527/1y running 8s. I currently have a 160 dynamite esc in it and want a esc that I could mount on the inner rail and maybe be able to switch to 10s at some point.
CraigP
07-07-2017, 10:41 AM
Well, that limits your choice to HV ESC's. That motor will pull some current, for sure. If it were me, I would go with the Swordfish Pro+II 200A HV, which can go to 12s. I never use the max number they recommend, always de-rate for safety... These things ain't cheap! This ESC has internal data logging so you can work your setup in closer...
A word of warning: Work your props up from small to larger, checking the temps and data logger on each step. If you over prop, you'll take out the ESC and possibly other things like batteries and motor. It is very unforgiving in HV setups!
meangenesracing
07-07-2017, 11:20 AM
I have a etti 220 esc in my 1/8 scale Squire Shop works great on 10 s barely gets warm
CraigP
07-07-2017, 11:41 AM
Does Etti have data logging now?
CraigP
07-07-2017, 11:54 AM
I see they do...
07-07-2017, 07:44 PM
What motor? A 1250 Kv motor is really too much for 10S and a big 1/8th scale. Can it work? Sure, but it isn't near optimal and amp draw can be high even with a small prop - that's near 40,000 loaded rpm, SAW speed. Feel free to ignore well-meaning advice, but then it's on you. Good luck! 🙂
Doug Smock
07-07-2017, 08:31 PM
Hi Jay, Geno is running a 1.5Y.
Richard, I also run the Etti 220 Pro with a 1.5Y on 10s with a M cut 450/3 and it has been VERY reliable. Jay is spot on you'll want to drop the kv when switching to 10 cells.
https://www.offshoreelectrics.com/proddetail.php?prod=etti-e065
chevelledude
07-07-2017, 09:35 PM
As Iam fairly new to the fe coming from many years of nitro and gas. I want to buy a good controller that will last and maybe get me to 10s but thats a ways off. What is optimal for a fe hydro that weights 14.5 with batteries in it? Is my motor to much?
pescador
07-08-2017, 11:01 AM
As mentioned your motor is too much for 10s but okay for 8s. I run a Swordfish 240 on 10s but it's the 1.5y motor like the others.
Sent from my iPad using Tapatalk
