View Full Version : 33'' mono twin setup
Sheffield
07-02-2017, 11:53 PM
Hello,
I need your help about a twin setup for a 33'' mono.
Motors : Dr Mad Thrust 2970 2200kv
https://hobbyking.com/fr_fr/dr-mad-thrust-2200kv-1600w-70mm-edf-inrunner-6s-version-29mm.html
ESCs : Seaking 120A
Batteries : 5S
Thanks
So....what kind of help do you need?
2200 kv motors are more suitable for 4S.
Speed3
07-03-2017, 07:03 PM
That motor may be limited to a 35 to 37mm prop on 4s. Just a thought, two motors will require two speed controls, counter rotating prop pair, two set of batteries, while a single is one of each. A motor like a 4082 or 4092 will give that boat all it can handle.
Sheffield
07-04-2017, 02:07 AM
Ok I understand,
If I use 2200kv motors the batteries must be 4S. If I want to use my 5S batteries I must choose 1900kv motors.
Looking to the size of the hull which choice lookk better ?
Speed3
07-04-2017, 02:32 AM
1900kv on the 5s will be better than 2200 on 4s.
07-04-2017, 10:01 AM
What do you want to do with the boat - sport run, oval race, speed runs, long run times? The motors are rather small for a 33" hull. They will "work" but I think you will be much happier with 36mm motors. Unlike the tiny motors you plan to use, they will swing props large enough to be efficient with that hull.
It doesn't matter whether you use separate packs for each motor or both motors pull from the same pack. You will need enough capacity for the amp draw regardless of the number of motors.
Sheffield
07-05-2017, 03:14 PM
Is a set of two Aquastar 3660 1700kV a good choice with 5S voltage ?
https://i11.servimg.com/u/f11/19/41/42/53/smash_11.jpg
07-05-2017, 05:38 PM
That's a better choice IMO. Loaded rpm should be around 25,000 with the ability to spin a larger prop. You should be able to spin counter-rotating x442s for speeds in the 40s. You can probably go up to x447s with large enough ESCs, 100 amp minimum. Speeds approaching 50 mph.
...And I would use struts and put them as low as possible..and as narrow as possible. Maybe 50 mm apart so you can prop up.
ray schrauwen
07-06-2017, 10:10 AM
That's a nice add in to note for a build of mine, thanks!
Its just logic. The propshaft can probably be anything between 2 and 8 mm lower on a strut then a powertrim. So you will have anything between 2 ang 8 mm more prop in the water...imagine a deep V hull with the drives 10 cm apart..Even a 447 could not, (or barely), toutch the water in an upright hull position.
Sheffield
07-07-2017, 12:45 AM
Great, thank you for your help. Anyway the voltage will be 5S / 18,5 v . Last question about motors, what do you think about those outrunner motors ?
Scorpion HK3026 - 1900kv
https://i11.servimg.com/u/f11/19/41/42/53/hyperi10.jpg
Thanks
Well powerfull motors, (193 g). https://www.youtube.com/watch?v=o3KCKjPuZkc
I am curently running a pair of HK Helidrive 49-56, (about 350 G) / 1350 kv /6s /55-14 props in a heavy 15 pound mono..No problem. So if your boat runs well and not build to heavy (6 pounds ?) I think it would be great.
if money matters you could get aprox. the same power by using these. https://hobbyking.com/en_us/rotorstar-brushless-outrunner-helicopter-4249-1600kv-500-size-heli.html
And they are not 14 pole, but 6. I know the "new" T-180 works perfect with at least up to 8-pole.
Sheffield
07-07-2017, 05:59 AM
Well, I never used outrunner motors, the guy sells the 2 Scorpion 3026 - 1900kv for 100 usĀ£ , they are new in the box, never used.
Or I saw those 3650, same size than the Scorpion :
https://i11.servimg.com/u/f11/19/41/42/53/hobbym11.jpg
Did you look at Dr Mad Thrust 2970 / 2200kv inrunner motors ? I had one in my hands magnets are very strong but 2200kv ...
https://i11.servimg.com/u/f11/19/41/42/53/p1_hul10.jpg
Nevs, the Rotorstar 1600kv look strong too, thanks for help guys.
ray schrauwen
07-07-2017, 11:57 AM
YOu can get just as good for about $50-$60 US Suppo motors.
http://www.altitudehobbies.com/suppo-motors/suppo-h-series-heli/suppo-h3126-3-2200kv-brushless-helicopter-motor-500-class
ray schrauwen
07-07-2017, 12:00 PM
Scorpions are a good deal.
Sheffield
07-07-2017, 12:55 PM
Those SUPPO motors look great , I didn' t know them. I add the link in my favorites.
I think I will buy the NOS Scorpion 3026 1900kv.
Rcsurfrider
07-07-2017, 02:39 PM
Ive been using heli motors in my Rc jetboat using 28mm kmb drive. Tiny little motors 12pole 2836 with 700 watts and gobs of torque. I can jump it out of the water to clear rocks going upstream. My other jet boat uses a 3656 in runner . I really like how the outrunner boat motor handles better. I use a high pwm 60a heli esc with it, the esc has an added water cooling plate and it is fully water proofed. So I can run 80A continuous through it now and it stays cool:) The heli esc/ motor seems to give better throttle control compared to my inrunner setup, especially when river crawling.
Im a big fan of outrunners as they are torquey has hell and self cool needing only a water cooled motor mount, which is standard for me.
RunningBeer
07-09-2017, 07:33 AM
Hi Sheffield, have a look at the photo galleries on my page, I've built a twin pursuit and a twin pirate. I also don't think 29mm motors will disapate enough heat for you. My pursuit had 2x HET 2200KV 3668's on 4S. The boat was a bit wild, there's a lot to learn about twins (like all boats).RB
Sheffield
07-10-2017, 02:25 AM
Thanks, pictures help me a lot, I will install the blade behind the propellers and motors low as possible.
Sheffield
07-16-2017, 12:39 PM
I will use flex shafts with 3/16'' prop shaft .
Which one should you use ? 4mm flex shaft with 3/16'' prop shaft or 3/16'' flex shaft with 3/16'' prop shaft ? Thanks.
RunningBeer
07-17-2017, 07:25 AM
I'm a 3/16 man myself. I guess it kinda matters what you have in the ol' prop box.
Sheffield
07-21-2017, 05:07 AM
I made a motor mount for two Scorpion 3026 1900kv, the two parts are strongly glued using threated shafts in the holes + epoxy . It is strong enough.
Picture with the modified TFL rudder, motors will be low a possible in the hull .
https://i11.servimg.com/u/f11/19/41/42/53/smash_13.jpg
It looks great..And the shafts between the 2 mounts is another great idea..I have done this a couple of times but used a 1 piece 3mm aluplate...Your mount will be lighter..
ray schrauwen
07-24-2017, 09:00 AM
You can only get one threaded shaft between those mounts to join them no?
I've seen it done before but not sure how it was done???
CraigP
07-24-2017, 10:31 AM
Nice, very close mounting! Have you thought about a small carbon fiber piece going from the point of the joint to the hull? That would triangulate that mount nicely! Could be epoxy attached the the motor mount I believe...
Sheffield
08-08-2017, 10:12 PM
What do you think about those stingers ? I will order 2 stingers for 3/16"" shafts, any suggestion is welcome
http://www.ebay.com/itm/adjustable-stinger-drive-for-3-16-4-76mm-flex-cable-rc-boat-75-100mm/151660578098?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
CraigP
08-08-2017, 10:51 PM
That is a great looking piece! I've been thinking about a single motor cat, but I'm pretty busy on my hydro. A guy posted a boat last week for $160, I reached out to buy it, but he never responded. I'm over the impulse buy!
Sheffield
08-09-2017, 09:10 PM
I order two stingers for this project.
What distance do I need between the 2 stingers, 51 mm or more ?
https://i11.servimg.com/u/f11/19/41/42/53/image_23.jpg
CraigP
08-09-2017, 09:16 PM
I would think it depends on where you can put the motors and try to keep sharp bends out of the flex cable. What does the manufacturer recommend? Might want to start there
Sheffield
08-09-2017, 10:27 PM
Sheffield
08-11-2017, 01:44 PM
Setup : Motors SCORPION HK3026 1900kV , 5S batteries
What do you think about 47mm + 3mm secure = 50mm ?
srislash
08-13-2017, 12:47 AM
I doubt you will need 447's, I have a 40" running the same RPM as you have planned and I have found 442's the best fit for my application. But this depends how deep the prop runs.
Here is a vid of mine https://youtu.be/6-KjgtRim_Q
Sheffield
08-13-2017, 01:34 AM
Great !
I received two stingers, they are very well build. Perfect ! 50mm between the propellers look fine.
https://i11.servimg.com/u/f11/19/41/42/53/smash_14.jpg
srislash
08-13-2017, 02:24 AM
I can measure mine tomorrow or Monday and post pics.
RunningBeer
08-13-2017, 03:29 AM
45mm between centres on my Pirate. In this video running 42mm props. https://www.youtube.com/watch?v=tobZ3H2icco I can't adjust my struts any lower as the bottom edge is already parallel with the bottom of the hull. This boat works best with parallel struts. I eventually calmed the bounce with 44mm props. That's as big as I can go, in diameter and amps.R.B.
srislash
08-13-2017, 09:43 AM
Now see mine needed 42mm to calm the ride. I was aiming for 445's on the build. But I have steerable drives which are pretty long.
CraigP
08-13-2017, 11:26 AM
That sure is great looking hardware! The machining work looks very well done. What's the length on your hull?
srislash
08-14-2017, 12:37 AM
153223
Here is a pic, mine are 55mm centre to centre
Sheffield
08-14-2017, 02:43 AM
Ok, thanks. I think I will install the drives with 50mm maximum centre to centre.
iop65
08-14-2017, 02:44 AM
Post nr 1!
Sheffield
08-14-2017, 02:45 AM
Hull lenght is 33" / 83 cm.
Sheffield
08-16-2017, 09:35 AM
Finally the distance between propellers is 48 mm, I want to run Graupner K45 carbon and 445 Tenschock propellers.
