View Full Version : Vs1 tunnel
teamgear1973
06-26-2017, 05:13 PM
Looking to see if anyone has turned the VS1 nitro into a electric tunnel. If so could you be kind enough to share how you did it and what all is needed to do so. Thanks for y'alls help. https://uploads.tapatalk-cdn.com/20170626/9543960869e7a82e505ca9f705ba10af.jpg
Sent from my SAMSUNG-SM-J120A using Tapatalk
JestDanny
06-26-2017, 08:55 PM
I have one on the bench now. Just mounted the outboard earlier this eve, all that's left is to make up steering cables , every thing is in place an benched tested. H2O testing starts next weekend. The biggest mod I did is the battery tray. I kept the steering servo an the rx in front box. I cut a recessed well in the center tunnel deck to lower battery to the floor of the tunnel, steering cables go over top of battery. ESC is where fuel tank should be. Very easy convert , took one weekend.
teamgear1973
06-26-2017, 09:50 PM
Got any pics you wouldn't mind sharing of it bud
pescador
06-26-2017, 10:47 PM
I have pics of my conversion build on photobucket
http://s4.photobucket.com/user/Pescador58/library/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion
Sent from my iPad using Tapatalk
teamgear1973
06-27-2017, 08:01 AM
Awesome bud. Thanks for sharing them
teamgear1973
06-27-2017, 08:15 AM
Pescador the steering cable that you are using in your boat are they the ones that come with the kit?
pescador
06-27-2017, 10:26 AM
I used new cables and a belcrank arm but you could use the wheel and cables from the kit I think. I can't remember if the stock steering cables came with the plastic cover like the yellow throttle cable but the way the cables come thru the battery box I used the same plastic cover so the cables wouldn't rub the batteries. They are Dubro I think, easy to find at the hobby shop with the airplane stuff.
JestDanny
06-27-2017, 06:48 PM
152255152256152257152258
I an going to run 3S buy a 4S will fit in my battery tray.
teamgear1973
06-27-2017, 07:03 PM
Thanks for sharing. Hope to start mine soon
rol243
06-27-2017, 10:14 PM
guys, there used to be a good upgrade for the K & B outboard leg that many guys did . what you do is if your leg is fitted with a teflon shaft tube only you get rid of it and bend to shape the same length of brass tubing to use as the main shaft log. this eliminates any drag caused by the teflon / bend thus lets the motor run alot freer. also if your running the pull pull steering set up use fishing wire stainless trace, never breaks.
properchopper
06-28-2017, 02:55 PM
I built several tunnels. The VS-1 was a fun build. (pictures from different builds)
just a few details:
I enclosed the whole interior
152304
Most builders locate the servo up front using cables to steer. I preferred rear-mounted servo with 4-40 rods
152305
Pass - through "tube farm" for 3 motor wires, two servo rods plus 2 cooling lines. I inset the motor mount to shorten the pivot length for crisper handling (not necessarily worth the effort)
152306 152307
continued
properchopper
06-28-2017, 03:00 PM
Two of the builds: (same cowl)
152309 152312
Best to avoid "death buoys" ; can cause slight disassembly :Sinking:
152311
teamgear1973
06-29-2017, 07:52 AM
Those are some nice builds guys. Thanks for sharing the build photos
teamgear1973
06-29-2017, 05:45 PM
Whoop whoop my VS1 should be here next week..
teamgear1973
07-07-2017, 10:01 PM
Hey what did you use to enclose where the battery goes?
pescador
07-08-2017, 10:45 AM
On mine I made cardboard templates to figure out the sides then cut them out of hobby plywood. Then some pieces of basswood to reinforce the corners and make a lip for the lid. You can just copy the way the original servo box is constructed.
properchopper
07-08-2017, 02:58 PM
3/32" Birch plywood [Midwest brand] from LHS. Rather than piece together the sides I just made a template for a once-piece side cover. (notch in back 'cause transom inset, hole is to hang it up )
152471
JestDanny
07-09-2017, 07:07 AM
I don't do anything to seal batteries, let um get wet. I use to, but not any more, on my Dumas Sprint despite my efforts to seal the electronics the first time I flipped the boat the compartments flooded, I dried it up no ill effects every thing worked fine minuets later. Second time I flipped it my sealing job only worked a little better but still took on h2o, dried it up no ill effects back on the water in minuets. I gave up trying to seal all my water proof gear. That boat has been upside down half a dozen time so far no ill effects on the un protected gear. Funny but when my Sprint is upside down it floats low enough that the prop is still in contact with the water, I can drive it back to shore upside down with all electronics totally flooded, under water lol. I know eventually I'll have to replace A water damaged part, till that happens don't care. Haven't flipped the new VS1 yet but I'll try.
teamgear1973
08-17-2017, 10:00 AM
Hey bud where duf you get your water line fittings that you used on the tunnel
pescador
08-17-2017, 10:42 AM
The bulkhead fittings and water exits are from right here at the Offshore store.
teamgear1973
08-17-2017, 10:46 AM
Ok thanks
