View Full Version : 1/10 Baby Bootlegger Build
AndyKunz
11-18-2008, 09:50 PM
Several years ago I promised my wife that I'd build her a big mahogany boat for the top of the piano. She's a patient lady! What got me off my duff was that she said I could buy a turbine... as soon as I got rid of a 4' cube of airplane kits and built her the boat I promised. Within 5 minutes both boys were assigned kits :) Last night I started on her boat.
The plans are Garry Finlay's, which you may find on the Astec Marine site (http://www.astecmodels.co.uk/plans.htm). Garry sized them to fit nicely on E-sized paper. You can download the PDFs (2 pages) and have them printed for just a few dollars at Staples or Kinkos. Note that Garry is in the process of updating the plans as I find minor issues. They are fine for building - we're just working to make things perfect.
http://www.montanadesign.com/bb-build/thumbs/dscf5747.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5747.jpg)
I began with a trued plywood base that is oversize for the boat. I added a straight centerline, then marked off the locations of each bulkhead.
http://www.montanadesign.com/bb-build/thumbs/dscf5749.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5749.jpg)
Then I used a triangle to make a pair of lines 3/16" apart (the thickness of the wood) across the width of the plank and labeled each pair of lines with the corresponding bulkhead letter.
So much for Monday night.
Ocean Racer
11-18-2008, 09:57 PM
so no videos of her floating along the pond.....sniff...sniff
AndyKunz
11-18-2008, 10:06 PM
My daughter Lena is going to be helping me with this build. I forgot to mention that last night we also joined two 3/16" sheets to form a 6" wide piece. I used hard balsa because I want to have strong bulkheads. You'll see the piece in the pictures below.
http://www.montanadesign.com/bb-build/thumbs/dscf5752.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5752.jpg)
Tonight we started out by laying the keel out on a sheet of 3/16" x 3" x 36" hard. It was necessary to join a piece at the bow to make it tall enough, and to add about 1/4" down the center to make it deep enough. If you use 4" wood you won't have a problem but you'll have more waste.
http://www.montanadesign.com/bb-build/thumbs/dscf5754.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5754.jpg)
Next we cut out all the bulkheads from Sheet 2 of the plans (I printed two Sheet 2's - you'd be smart to do the same). Using 3M #77 spray, they were laid out on the 6" wide plank we made last night. They fit nicely, we very little waste.
I didn't take a shot specifically of it, but in the picture above in the top right corner you can see that I have two pieces of 3/16" stacked together (a few dabs of glue between them) and clamps. They are going to be the deck sheer and the chine pieces. I had to remove a moon-shaped piece and relocate it to the top so that I could cut both items out of two pieces of wood without splicing in virgin pieces.
Tomorrow we will show you how to get long, thin paper pieces glued down straight on a sheet like that.
http://www.montanadesign.com/bb-build/thumbs/dscf5758.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5758.jpg)
Next, I cut out the bulkheads from the 6" wide sheet. First I rough cut them (1/8" - 1/4" oversize) just to separate them into manageable chunks.
http://www.montanadesign.com/bb-build/thumbs/dscf5763.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5763.jpg)
Still using the jigsaw, I then trimmed them much closer to the lines (within 1/32"). Note that the notches for the keel, chine, and sheer are not cut out yet. Doing so would have made those corners too fragile.
http://www.montanadesign.com/bb-build/thumbs/dscf5765.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5765.jpg)
Next, I sanded each piece down to the line. (In the background you can see a 54" Comet Taylorcraft that I'm also building with my son Caleb, but not doing a thread about).
http://www.montanadesign.com/bb-build/thumbs/dscf5766.jpg
Full-Size Image (http://www.montanadesign.com/bb-build/dscf5766.jpg)
When done, you end up with a stack of bulkheads looking like this. Thursday night we will be cutting out the notches.
Andy
11-18-2008, 10:19 PM
Must be nice to work on boats again!
AndyKunz
11-18-2008, 10:29 PM
Yup. Nice to work with Lena too. She's learning the camera pretty quickly and learning all the terms for the hull parts. I'm working on 2 planes at the same time, too. One is a magazine construction article, the other for flying indoors at the Armory this winter. AND doing an electronics consulting project.
AND writing about it all.
Andy
Jr Branham
11-18-2008, 11:20 PM
Andy,
Is that your work shop area??? Looks more comfy than a cold garage....:thumbup1:
Jr. B
JimClark
11-18-2008, 11:29 PM
Great job on the pictures Lena oh and you to Andy nice to see you making sawdust again
What you using for Mahogany?
What are you going to use for power of the BBL?
Jim
AndyKunz
11-19-2008, 10:21 AM
Jr - it's the unheated garage, except for a small ceramic heater that takes the edge off. I think I'm going to be doing a lot of modeling in my office this winter. I don't think the walls are insulated and the garage door has big gaps around the top and sides to let the cold in. Pretty shoddy installation, imho, but I'm just renting for the year so I can't complain.
Jim - I bought a whole bunch of 1/16x4x48 mahogany a few years ago specifically for this boat. I'll need to cut a lot of it down to make strips to plank. I just need to buy a 10" table saw (http://www.sears.com/shc/s/p_10153_12605_00922114000P) to cut it.
I'm not sure if it will be powered. Gail said it doesn't need to be, and it would take a lot of time out of the project, but I will probably build it so that it CAN be powered. It would have BJ26 power system in it, and room for a 3S/4S pack, and a Spektrum radio.
Kmot put me in touch with a fittings place. When we get closer I'll order and see how they look. I need a scale-like prop for it as well. I have photos of the real boat from the Clayton regatta, so I'll do my best on the details. I doubt it will be of ERCU quality, though.
Andy
JimClark
11-19-2008, 01:34 PM
How about sharing the link for the fitting's place?
And I don't care about ERCU quality anymore!!!!!!!!!!!!!!!!!!!!!!!
I just like building models and probably the one thing that stopped me from building a BBL was the fittings.
I have a bunch of really good Mahogany and just need to cut it down into a good size for making planks as right now ie is in big chunks.
Jim
Andy
icelert
11-19-2008, 03:54 PM
Andy,
Nice job on the project-it's great that your doing this not only for your wife and with your daughter but also for taking the time to share it with us. :thumbup:
A suggestion for cutting the mahogany pieces, it's cheaper and safer than a table saw, I made nice .2" wide mahogany strips with my current boat project the 66 Bud.
http://olfablades.stores.yahoo.net/9651.html
This cutter is also the cat's meow for cutting lightweight fiberglass and especially carbon fabric!
Bryan
Darin Jordan
11-19-2008, 04:21 PM
... my current boat project the 66 Bud.
Bryan... I'M NOT WORTHY... I'M NOT WORTHY!
REALLY fine work, dude! That's amazing...
Can't wait to see more Andy! COOL project!
AndyKunz
11-19-2008, 05:45 PM
Click on the table saw link, Bryan ;) It ain't no Harbor Freight! I need it for ripping balsa stock in the future - an investment. All those good terms. I need a Forrester blade for it too - no sense having a good saw and using a $10 blade in it.
I use those blades you linked already. They're great for glass - in fact I had to buy my wife replacement blades for hers back when I was manufacturing hulls.
I'll give it a try on the mahogany but I don't expect success. The wood is ten years old and very dry. I'm going to have to increase its humidity just to be able to use it at all. (My Dad's a cabinetmaker so we have the tools to do that properly).
Andy
Doug Smock
11-19-2008, 07:13 PM
Cool project Andy, keep up the good work!
Doug
Avanti
11-19-2008, 08:22 PM
Very cool, I was thinking about building one of these after seeing the link in docjets thread.
I will be watching your progress.
John
AndyKunz
11-20-2008, 09:53 PM
First item tonight - link to the fittings (thanks to Kmot). http://www.wetgoose.com/ His name is Ken Valk. I have not yet contact him, but I trust Kmot.
OK, on to tonight's progress. Lena and I continued working making parts. The other night I left the chine and sheer rough stock drying under weights. Tonight we put the paper templates on and cut them out.
Putting long, thin paper templates down straight requires use of a little trick. Prior to cutting the strips out of the large paper, I made a straight line down them using my 2' straightedge. You can see it near the pencil in the photo below.
http://montanadesign.com/bb-build/thumbs/dscf5767.jpg
Full Size Image (http://montanadesign.com/bb-build/dscf5767.jpg)
Using the straightedge to verify that I haven't deformed the paper on the rough cut blank, I scribbled dark areas about every 6" around the perimeter of the paper template.
http://montanadesign.com/bb-build/thumbs/dscf5777.jpg
Full Size Image (http://montanadesign.com/bb-build/dscf5777.jpg)
Next, I take the long strips over to the spray backstop (an old set of plans) that I put on the garage door and use #77 to make them sticky. Man do I look fat in that one!
http://montanadesign.com/bb-build/thumbs/dscf5778.jpg
Full Size Image (http://montanadesign.com/bb-build/dscf5778.jpg)
http://montanadesign.com/bb-build/thumbs/dscf5779.jpg
Full Size Image (http://montanadesign.com/bb-build/dscf5779.jpg)
Next I carefully lay them down on the blank, and use the straightedge to verify that I haven't twisted the paper any. If you do this quickly, the #77 will allow you to peel up the paper to get the positioning correct. I then allow it to dry for a few minutes before cutting on the jigsaw.
http://montanadesign.com/bb-build/thumbs/dscf5781.jpg
Full Size Image (http://montanadesign.com/bb-build/dscf5781.jpg)
After cutting out the keel (which is laid out using the same technique), I marked on the edges where each bulkhead will go. I then peel off the paper and label each set of marks for the bulkname name. I also marked the entry/exit locations of the driveshaft. These will be drilled out with a 1/8" bit BEFORE we go any farther with the keel. Also the rudder post hole. Having pilot holes will come in handy when it comes time to install the hardware.
After we finished those steps, we cut the notches in the bulkheads. No pix - I figure that's self-explanatory.
Tomorrow night we will be adding the tabs that lift the bulkheads above our building plank. We are almost done "making a kit" so we can begin construction.
Andy
Ocean Racer
11-21-2008, 01:40 AM
looks pretty cool how long do you think it will take to complete this?
AndyKunz
11-21-2008, 09:06 AM
IF I can keep on it, it should be done mid-January. I won't be able to do some things right away which will delay finishing. We moved this summer and I couldn't bring along a lot of supplies like West Systems epoxy, so I have to save $$ to buy a new gallon. Same for the varnish to finish it up.
Planking will take me a while because I can't use CA any more, so it'll probably take 2-3 weeks just for each of the two planking layers. I'm working on an airplane and a boat with Caleb, an airplane with Ian, and an airplane for a magazine article - plenty to keep busy.
Andy
AndyKunz
11-22-2008, 04:23 PM
We didn't do anything on the boat last night. My wife borrowed a season of The Untouchables from the library so we all stayed up late to watch it.
http://www.montanadesign.com/bb-build/thumbs/dscf5791.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5791.jpg)
I started this morning by cutting up the scraps from earlier steps into pieces 3/4" x 1-1/2". These will become tabs to loft the bulkheads above the building board.
http://www.montanadesign.com/bb-build/thumbs/dscf5794.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5794.jpg)
These were then attached to the bulkheads and allowed to dry. Note that I and H are different than the others.
http://www.montanadesign.com/bb-build/thumbs/dscf5801.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5801.jpg)
The approximate location of each bulkhead was marked on the sheers and chines. This was done to look "fuzzy" so I'd remember it was approximate. (I have a short memory :D ).
AndyKunz
11-22-2008, 04:24 PM
http://www.montanadesign.com/bb-build/thumbs/dscf5798.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5798.jpg)
Next I sanded the notches for keel, chines, and sheers to fit snugly at the marked locations. A snug fit will make things easier in later steps. The sanding was done with a large nail file.
http://www.montanadesign.com/bb-build/thumbs/dscf5804.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5804.jpg)
I don't like to cut the keel in two, so I notched it to accept the stuffing box. I chose to use a 1/8" ID tube instead of the 1/4" tube Garry recommends, but I'm using a different power system as well. This is one of those times when you need to make a choice about your own power system. Note also that I didn't extend the stuffing box below where the planking will be. This will make finishing easier. Should I decide to change the stuffing box to a larger size, the existing one can be removed with heat.
We are finally done making kit parts! Time to start BUILDING!
http://www.montanadesign.com/bb-build/thumbs/dscf5810.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5810.jpg)
Each bulkhead is positioned on the keel at the location marked on it back at the beginning.
http://www.montanadesign.com/bb-build/thumbs/dscf5814.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5814.jpg)
I had to modify the tab on A so that the sheers could butt against it. The marks tell me exactly where they will be located when aligned properly.
http://www.montanadesign.com/bb-build/thumbs/dscf5816.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5816.jpg)
Bulkhead I needs to be positioned properly too. I like to insert the chines at this time so that everything will be snugly linked together. The chines butted up snugly fore and aft as well as within the slots. Taking your time to make true parts pays off!
http://www.montanadesign.com/bb-build/thumbs/dscf5821.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5821.jpg)
After these components are assembled (but not yet glued), make sure that they are all perpendicular to the building board AND to the keel. The snug fit will allow you to adjust things and have them stay put. After you've done each bulkhead once, go back and verify just in case something was jostled.
AndyKunz
http://www.montanadesign.com/bb-build/thumbs/dscf5822.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5822.jpg)
Glue the tabs to the building board. Align the keel on one side of the drawn center line, and move it fore/aft until the bulkheads align with their lines.
http://www.montanadesign.com/bb-build/thumbs/dscf5823.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5823.jpg)
Then make sure your keel is still straight, and allow it to dry.
You may have noticed that I didn't glue any of the boat parts together yet. That's so that I will be able to double check them again after the glue to the board is dried. It's much easier to straighten things if they aren't glued together. This gluing is easily accomplished with thin CA wicked into the joints. I can't use it, so I will just have to work some wood glue into the joints.
At the same time I will glue down the chines, then sand in preparation for planking. I will also be looking for someone at work who will let me rip a bunch of 1/8" balsa into 1/4" and 1/2" strips.
Andy
Doug Smock
11-22-2008, 05:15 PM
Looking good Andy!!
I'm a little curious why you can't use CA anymore?
Doug
AndyKunz
11-22-2008, 07:58 PM
Allergic. If I catch a whiff, I have symptoms of a head cold for three days. I developed it making UL-1 (the real ones (http://www.bbyracing.com/images/UL1.jpg), not the imitations from AC) and Electric Thunder hulls.
Andy
Rex R
11-23-2008, 03:22 AM
I understand that the 'foam safe' ca's cause fewer problems* for those allergic to regular ca.
*note that I said fewer problems, NOT zero problems.
AndyKunz
11-23-2008, 01:48 PM
Exactly. It also doesn't bond balsa as well in my experience.
With diluted wood glue, the water will swell the joint and the glue will, of course, glue it. Then it will be double-glued and all will be well.
Andy
Rex R
11-23-2008, 02:35 PM
heheh I use wood glue(white) for my wood boats. I figure if after 6 or more layers of paint it isn't sealed...I got bigger problems :-)(I do seal the inside of the boats w/ epoxy)
Avanti
11-23-2008, 03:08 PM
CA has worked great for me, but I also fillet the insides with epoxy.
AndyKunz
11-23-2008, 08:53 PM
Aliphatic resin (the type of wood glue I use) is only water soluble until dry. Then it resists water nicely. Other wood glues (PVA, like Elmers white) stay water soluble even after drying.
This will be sealed inside and out also.
The wood glue is diluted (lots of water) to cause the wood to swell, giving a mechanical bond in addition to the adhesive. It's the same idea used on wooden ships.
Andy
I developed the same type of allergic reation to CA fumes. Only it lasted for several days, felt like I had asthma as well as a severe cold.
I still use CA. But I bought a respirator. Made all the difference. Now, whenever I use anything stinky, I breathe sweet clean air instead because I have this thing on my face:
http://www.coopersafety.com/item/100559/North-7700-Series-Half-Face-Respirator.aspx
AndyKunz
11-28-2008, 06:02 PM
Thanks for the respirator info, Tom. Being claustrophobic makes them impractical for me, but there may be another reader for whom they are an answer. Slow building is fun too!
OK, so I hope you all had a happy time with family, thanking the Good Lord for His blessings on our lives, our families, and our nation. With all the hubbub I didn't get to post these pictures from Wednesday, so here goes.
http://www.montanadesign.com/bb-build/thumbs/dscf5826.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5826.jpg)
The next step was to glue all the bulkheads to the keel and deck sheers. I then added the chine pieces and pinned them in place. A clamp holds the bow together.
http://www.montanadesign.com/bb-build/thumbs/dscf5828.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5828.jpg)
The pressure plate is glued and pinned in location also. Make sure it's level!
http://www.montanadesign.com/bb-build/thumbs/dscf5830.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5830.jpg)
This thing is starting to really look boat-like, even upside down!
The next step will be to sand all the bottom and side surfaces to get smooth flowing lines in preparation for planking. I will do the sanding outdoors using a 12" sanding block. We are still having nice-enough weather here (today was clear, 35, and winds 5-10) to go flying, so that's taking precedence.
Today I also cut a bunch of 1/8" balsa sheets into 1/4"' and 1/2" wide strips on a table saw with a friend from work. We used a 200-tooth 10" blade turning at 3500 RPM. Now THAT was a dusty operation, even with the dust collector running! (I also ordered my saw (http://www.sears.com/shc/s/p_10153_12605_00921805000P) - they are $80 off at Sears thru tomorrow!)
We cut way more wood than was necessary to cover the boat. This will allow me to use the best pieces for each position. Remember, we want to use pieces which do not try to twist the hull. We will be using comparable pieces for opposing parts, so we may not have as much usable wood as we thought.
Andy
Flying Scotsman
11-28-2008, 06:34 PM
Way to go Andy...superb workmanship...your gut and mine look about the same. It is great to see you are back into boat building.
Douggie
AndyKunz
11-29-2008, 05:42 PM
Thanks Doug. You make me feel SOOOO much better :sarcastic: :D It's good to build, especially with the carrot that's dangling!
http://www.montanadesign.com/bb-build/thumbs/dscf5847.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5847.jpg)
http://www.montanadesign.com/bb-build/thumbs/dscf5852.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5852.jpg)
Before I could sand everything, I had to trim them to fit. I did this by using a 3" long blade as a drawknife. To do this properly, you need to watch what the grain is doing. I was only able to do a little over half the length of the hull from each direction. I turned the boat around to do the other end. It is important to trim the deck sheer also, because you will be planking there as part of the sides. Don't try planking the deck though - just the sides and bottom with it on the building board.
http://www.montanadesign.com/bb-build/thumbs/dscf5855.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5855.jpg)
After I trimmed them, I sanded. First I did the sides using a standard 12" block sander. The bottom (shown in the picture) was done with a sander I got several years ago for drywall. I don't know what it's called, but it has a permanent grit about 200 or so, and is made of a flexible foam. I used it because I could sand the concave hull bottom without damaging it as a hard block sander would do.
http://www.montanadesign.com/bb-build/thumbs/dscf5857.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5857.jpg)
After you're satisfied with that you get to start the time-consuming part - planking. This underplanking is easy - if things don't fit perfectly it's not a big deal. However, I urge you to learn as much about planking as you can - you're going to have a lot more difficult time when putting on the mahogany. You want it to be nice, remember!
Note that the bow pieces are twisting and appear to be shingling. They aren't, really. The wood is being beveled and tapered in two directions, and the thickness makes it look like they aren't smooth. That's because they aren't. With the underplank you can do this, then sand smooth. Here is where you should take your time.
By the way, when fitting the pieces are do the bow taper first (starting between bulkheads A and B). You don't need to be too precise on where the bow pieces end, either now or later. That's because the edge will get a metal cover over it.
http://www.montanadesign.com/bb-build/thumbs/dscf5858.jpg
Full Size Image (http://www.montanadesign.com/bb-build/dscf5858.jpg)
You'll want to make the transom look better when doing the final planking. Note also how the planking extends way past bulkhead H. This will be trimmed later also.
I was very liberal with pins. I probably won't use quite so many when dong mahogany.
For the next few days all I'll be doing is planking. The bottom is done with 1/2" wide planks. I'll keep you posted on what I use as I go along.
Andy
Ocean Racer
11-29-2008, 11:28 PM
that is awesome and it not even finished
Jeff Wohlt
12-08-2008, 05:21 PM
Great work, Andy. Probably feels prety good again building a boat.
Keep them coming as you progress. I will have you some hardware for your other soon.
Doug Smock
01-06-2009, 06:38 PM
How's it coming Andy?
Doug :popcorn2:
AndyKunz
01-06-2009, 07:14 PM
I'm still working on the planking - this is the boring part, not much to show. Last night I pulled a zillion pins out of it.
Most of my time I'm concentrating on an electronics project to help a friend in a bind right now. When that finishes and I finish a magazine article then it will be top priority again.
Thanks for asking.
Andy
robert1974
01-22-2009, 03:31 AM
Hallo Andy
We (me and my son) are building the same boat and we are very glad we found your pictures and info/tips it saved us a lot of time trouble headache and tears :)
Can you tell us something about the powersystem your putting in ?
And we are anciously waiting for the next part.
Greetings
Robert and Gabriel from Holland
AndyKunz
01-22-2009, 09:01 AM
It will likely have a Proboat BJ26 system in it. The ESC is Proboat part number PRB3309 and the motor is PRB3310.
I will be posting more pictures in a couple weeks. I have had 3 high-priority ($$) projects to do, and the last should be done in about 2 weeks.
The key when you get to planking is patience. Just do a little every day.
Andy
woody5
05-06-2009, 02:56 PM
I've got the hull finished and am looking at motors and drive train options. Do you think the Englishman's plan for these elements is still a good option with todays more affordable BL motors?
If you go with the blackjack system are you going to use the out drive and prop also.
His rudder set up is very unusual.
CornelP
05-20-2009, 02:55 PM
Any ideas on how to make the front cutwater? I tried soft brass, but the curve is too complex... the aft one was ok, will post some pics. I am now thinking to cheat and do it in ABS painted brass...
woody5
05-26-2009, 02:45 PM
If you want to plate the ends in chrome the stainless self adhesive Duct tape is an easy answer. That tape is sold at most hardware stores here in Florida. You could paint the area of trim with metalic bronze or brass paint and then apply a coat of laminating resin to make it more durable. My hobby shop in town carries brass that is thin enough to make a scale cut water you would have to silver solder it and form the shape with a jewlers hammer. It would look real nice secured to your bow and stern with pin heads as nails. I am going to leave the cutwaters off to expose the laminated ends, I think they are to pretty to cover up!
Have you any ideas on how to make the G5?
rcboatfan
05-26-2009, 06:08 PM
looks great!!!!!!!!!
CornelP
05-27-2009, 03:44 AM
For the G5: I will either order a custom decal or, because I have one :biggrin:, use my cutter/plotter (roland Stika SV12) on a sheet of thin self adhesive vinyl and use the negative as a template for gold paint... I am now working on an upgrade to a cheap toy cat for the holidays, but next week I will finish the Bootlegger... hopefully take her out on the water.
CornelP
08-16-2009, 09:01 AM
Got the first run with it, just lovely. I f you push it, it will go like a dream...
http://www.youtube.com/watch?v=euEeULXYn4c
CornelP
08-30-2009, 10:51 AM
Second run, much better, but still need to fins a decent prop. It now runs on a 3 blade 32mm Graupner...
http://www.youtube.com/watch?v=0LgIxaLFb8E
JimClark
08-30-2009, 12:50 PM
alright we need pictures of all the details especially the hardware.
Looks great
JIm
CornelP
08-30-2009, 01:02 PM
Motor: brushed Permax 600
ESC: Graupner 50A
Batt: 8.4 4300 mAh
Prop: 3 blade Graupner J (not very good though...)
Driveshaft, rudder as per plans.
Will post pics later.
astecme
02-02-2010, 07:45 AM
Andy,
For plank on frame I always prefer cascamite - water based resin glue. Aerolite would work as well. Not sure if they are still available. I Found that the Aliphatic glue will still release if it is kept damp or wet. A coat of epoxy will sort that.
For the planks the hull will only deform if you plank all one side and push the planks in to place. agood hull normally does not need that though. A tip is to measure the plank width you will use and at the hulls fattest point - mark those spacings. on each former measure the surface and divide by the number of planks - generally you can rough taper a plank and tidy up when it is in place. For absolute accuracy you will need to look closely at the original pics.
If the planks "run out" then do not force them but put a fillet in. I used a small zip type plane back then - now I have a french one that uses stanley blades and it is great. Save the sawdust for filler - mix with the glue - at the right consistency it will disappear.
I'd love a pic when you are done. My website (as you know) does not have a suitable pic. This is next on my list to kit.
Looking very nice.
Allan
AndyKunz
02-02-2010, 08:58 AM
Hi Allan,
I haven't been working on it this winter. Some other stuff came up in the electronics area plus I'm working on an entry for scale at the AMA Nationals this summer.
As it's not intended to be run much if at all, the glue won't be a big deal. Besides, as you mentioned, it will be sealed in epoxy internally. Externally I haven't decided yet, probably 3/4 oz glass and finishing resin with lots of elbow grease.
Andy
astecme
02-02-2010, 02:22 PM
Ah - did not read the date!! I found the link through tracking hits on my site - You just have to finish it!! There are some nice builds in Europe. You need one in the home country ;)
woody5
05-02-2010, 10:33 AM
Finished my BB with a swap shop special speed 700 $20 new and a proboat blue 50 amp esc. Nice scale + speed with an 11.2 2200mha lipo. Hand made cooling coil and brush hoods no cooling issues from the low end components. I used a Granpinger black plastic resin prop 40mm X 55mm. The boat proposes alot a speed maybe trim tabs would help but is it worth it? I think in retrospect that a surface prop mounted right behind the step would have been better than the fully submersed wheel.
astecme
05-02-2010, 11:12 AM
Beware of that prop if it is subsurface. Max 35mm on a 700.
Allan
captain
04-27-2014, 06:06 PM
How did you remove the patterns after using the 3M 77 adhesive ?
boredom.is.me
04-27-2014, 09:12 PM
uh...you peel them off. 3M77 is more of a tack than a glue, unless you are working with paper on paper.
captain
04-28-2014, 07:52 AM
Thank you. I have never used 77, and the directions don't explain it very well.
golfito
02-02-2020, 04:16 PM
Hi! Excuse me. It was a great construction. I would have liked to see the ship sailing. Greetings.
02-02-2020, 06:35 PM
This is an 11-year-old thread. To whom are you asking the question? The OP hasn’t been back to the forum in three months.
golfito
02-02-2020, 10:07 PM
Hi, sorry. I am working on the same boat. Greetings.
