View Full Version : Speed ?
Leadfingers
06-02-2017, 03:31 PM
Just wondered what kind of speed are you guys getting on the stock set up?
What prop and batteries are you running?
fweasel
06-02-2017, 05:09 PM
What boat are you asking about specifically? The V2 blackjack or the latest V3 version?
Leadfingers
06-02-2017, 06:05 PM
Sorry, the V3.
fweasel
06-02-2017, 07:04 PM
On 4S with a balanced and sharpened Octura x642 prop, the V3 will do 40-41mph. Same prop on 6S will see about 50mph. On 6s with a sharpened and balanced Octura x440/3, 7.5* timing, the boat will do 60mph. Sorry, I can't find any records of what I ran on a stock prop as I didn't make many runs with it.
Leadfingers
06-05-2017, 08:08 AM
Thanks, I'm running about 50 mpg, 6's and 215 prop.......might have to try the Octura x440/3. Where is the best place to pick one up, that is already sharpen and balanced?
REDLINE1
06-05-2017, 08:45 AM
Buy it from OSE send it to Dasboata
fweasel
06-05-2017, 08:53 AM
Buy the raw prop from OSE (http://offshoreelectrics.com/proddetail.php?prod=oct-x440%2F3) and have it shipped to member Dasboata (https://forums.offshoreelectrics.com/member.php?5485-dasboata) to be prepped. PM him and he'll get you a quote and address. It's a really good prop to have, I've used it on more than one boat. IMO, it's worth buying the Octura and paying for professional sharpening vs. buying an inexpensive aluminum CNC prop.
Leadfingers
06-05-2017, 07:55 PM
Thanks again, ordered one today from OSE. I have sharpen and balanced a couple of props before, so I think I will give the 440 a shot and see how it does.
Where are you running your strut and battery placement ?
Leadfingers
fweasel
06-05-2017, 09:12 PM
3S packs get run all the way back in the trays, towards the stern. Strut was pretty level, and raised above the bottom of the sponsons. REDLINE1 can give you an exact measurement, he's got the boat now and its really dialed in.
Leadfingers
06-06-2017, 06:18 PM
Thanks for the input......how were your temps?
fweasel
06-06-2017, 06:43 PM
Warm, around 140*, mid August, very warm lake water. REDLINE1 has since installed a custom dual cooling output rudder. I think he's doing better on temps, but the water is also much cooler right now.
Leadfingers
06-11-2017, 06:59 PM
Got the new 440 prop, sharpen and balanced today and tried my first run. I gained about 5 mph with it. Hit 56 mph, ran great !
Thanks for you suggestion on the 440/3.
Leadfingers
fweasel
06-11-2017, 07:53 PM
Did you lower your ESC timing to 7.5*? If not, you need to.
Leadfingers
06-15-2017, 03:39 PM
yes
G-UNIT
01-09-2018, 12:11 PM
Leadfingers
is that on 4s or 6s ?
TRUCKPULL
01-09-2018, 12:29 PM
In post 5 the OP says he was running 6S
The 440/3 was suggested to use on 6S with lower timing.
Seeing that the OP said he did lower his timing.
I would say that he is running 6S
Larry
fweasel
01-09-2018, 12:54 PM
Definitely 6S
G-UNIT
01-09-2018, 02:43 PM
Larry
right now im running the 3 blade on 4s and lowered the timing to7.5 and hitting 45.1 mph gps with a garmin etrac.
how does that sound, I do have a set of 3s but have'ent tryed them yet, its dark by the time i get home from work.
