View Full Version : SV27 W/Ouboard
ice329
11-17-2008, 11:43 PM
I am doing it. She is almost done. I placed the ESC under the radio box to lower the CG, the batteries will most likely need to be under the front deck. Moved the radio box forward, it wont be waterproof, I needed it to hold the servo. I left the trim tabs and turn fin on for now, I wasnt sure if they should come off or not. Should be finished tomarrow, i still need to run wires threw the top of the hull and make it waterproof somehow, but I may not be able to try it out I nearly blew the shaft in the outboard today.
http://i110.photobucket.com/albums/n103/ice0329/IMG_2243.jpg
http://i110.photobucket.com/albums/n103/ice0329/IMG_2240.jpg
Ocean Racer
11-18-2008, 12:29 AM
looks pretty sweet keep us updated
ice329
11-18-2008, 12:44 PM
A better look at some of the details. The water lines and ESC are all set. I kinda like where it is. I left the wood incase the project is a flop I can go back to regular, a few extra holes but the boat will be fine. I siliconed all the hardware so hopefully that wont leak. The motor feed is in, not as clean as I would like but it should be waterproof. New antena installed. Just about done. I may try with the busted flex drive... Its not totaly busted but close. here are a few pics
http://i110.photobucket.com/albums/n103/ice0329/IMG_2244.jpg
http://i110.photobucket.com/albums/n103/ice0329/IMG_2245.jpg
http://i110.photobucket.com/albums/n103/ice0329/IMG_2246.jpg
http://i110.photobucket.com/albums/n103/ice0329/IMG_2247.jpg
Darin Jordan
11-18-2008, 01:08 PM
I want VIDEO of this one on the water! No excuses!! ;)
Try to get ALL of the weight inside as FAR down into the keel of the boat as possible... Should help it handle better...
ice329
11-18-2008, 01:14 PM
I would have it on the water today but I somehow busted the flex in the outboard but it may be ok to use. I would hate to wreck the lower end if it really busts. I think my first run is gonna be with Nimh untill I feel good about the waterproofing then I go to Lipos. I also filed doen the Outboard a little so can now fit a M445 size prop. If this works on the SV I need a bracket from the captian if he would sell me just the mount, then to swap the outboard would be 4 screws. thats if this thing works.. it looks cool... hehe
Interesting project. Its just to bad those lower legs look so horrible. Does anyone make a lower leg that looks somewhat scale?
Also the re-distributed wieght of the motor being so high should make the Super Flip nickname even more meaningful.:w00t:
Looking forward to seeing it run though!:bounce:
ice329
11-18-2008, 03:34 PM
I got it on the water. Only got about 6 or 7 laps in before the flex shaft broke. My first impression... it ran good. I have the motor set very low and trimmed down for the first run. I took 3 slow laps just to feel it out. It definatly ran OK, needs more steering but a quick move on the the horn should help. Then I steped it up a lap but not full throtal just about half and she still did her thing, looked good knowing she was trimmed down and low. I nailed thotrotal and got about a 20 feet in and the flex shaft busted. Thats it till I get a new flex. She was bone dry, so next test run the Lipo's go in.
On the REK lower end the nut near the prop.. does it come off and is it regular thread or is there any tricks to getting it off. The broken flex shaft is in the lower end.
Darin Jordan
11-18-2008, 03:40 PM
I too the cheapest 3/8" wrench I could find (I think that's the right size... :confused2: I'll have to look when I get home) and I ground it down until it was thin enough to fit into the flats...
Threads are reversed, so it's "righty-loosy, lefty-tighty" on that one....
Don't overtighten it... and make sure your flex isn't too long... it should float slightly at both ends...
Flying Scotsman
11-18-2008, 05:32 PM
Ice, a question why did you attempt this? As Doby mentions the lower leg looks way out of scale. The power point (prop) is way back of the transom..does this offer an advantage? Just very currious
Douggie
ice329
11-18-2008, 06:12 PM
Why do I do anything...Just felt like it. The actual placement is a bit further back from the stock running gear but it should not matter anyway. I had the outboard for the TS2 and thought it would be fun to see a V bottom with a outboard. I could move it closer if I felt like it but on my real bass boat you pay big bucks for a hydrolic jack plate to have the motor as far back and high as you can with hydrolic lifts, not tilt but lift to make the boat even faster so I measured a few things on my real boat and just did it.
Thanks Daren for info on the nut, it came right off... to think I was taking the entire motor apart to regrease it... hahah
ice329
11-20-2008, 03:47 PM
Fullers... extreamly fast shipping. Got the flex shaft today. I still had to grind it down some.
Ran the SV w/ the outboard today....All I have to say is FAST real fast. There is so much adjustment. I only messed with the trim but I still have to play with motor height and also the trim tabs. The boat is radical, I would say it is much faster then a stock SV but right now I cant control it, can only stay in the throtal for a few second and she wants to fly away. The boat can run on the prop only the entire boat compleatly out of the water. I tucked the motor way under and tightened it up but thats not a fun way to run it. I will have fun tuning this thing. I am sure there will be some stock SV hardware available on swap soon.
Avanti
11-20-2008, 05:50 PM
I would move the motor up.
where in the prop shaft in reference to the keel of the boat?
ice329
11-20-2008, 06:02 PM
My exact thought. I didnt feel like doing it on the dock because I have to reposition the bolts to the upper holes, thats why I just messed with the trim. I will prob test it more tomarrow even though its gonna be cold. Thanks Avanti
Seeing how this reacted to the motor way down I think I need to get the motor down further on the TS2
RCprince
11-20-2008, 06:48 PM
I've did the outboard thing with my Sv also, I ran it with a feigao 9l and a 637 prop on 5s and the thing just launched like a bat out of hell, then chimed and went under, the best i got it to run was at 38mph with a BJ motor and 5s. Here are some picture from this Thread http://forums.offshoreelectrics.com/showthread.php?t=2268
http://forums.offshoreelectrics.com/attachment.php?attachmentid=3231&d=1199510361
http://forums.offshoreelectrics.com/attachment.php?attachmentid=3232&d=1199510377
ice329
11-20-2008, 08:06 PM
Do you have much adjustment on that outboard and mount. It looks more like a real motor. If it is fun, that is all that matters.
Flyguy55
11-20-2008, 09:44 PM
I raced Nitro Outboard Monos for many years . You will probably have to mount some very long trim tabs to get it stable at speed . The trim Tabs were maybe 3" long and an inch wide. It was important where they were mounted , too wide and they were out of the water when running. Also if the prop is too low it lifts the back of the hull . thats probably why its just running on the prop. Set up right you won't need to tuck it under , just like your bass boat.
Did you lub the flex shaft each run ? There is a 90 deg bend in the flex and needs good lube.
I have an earlier version lower unit thats open under the mounting plate. I fill the area around the coupler with a mix if 50 50 STP and a low friction motor oil. It works like an oiler during the whole run. Ive not broken a shaft in 2 years.
You also need to lube the prop shaft where it goes through the bushing before each run , otherwise the bushing wears out quickly , wobbles , and leads to flex breakage.
You might be able to drill a hole through the adapter so you can add oil . If you use an oil mix it also lubs the prop shaft and bushing.
The hulls that were good O/B monos had a farly wide beam.
Sanding and polishing the flex shaft before instaling it helps to. make it as smoth as possible , remember its a long shaft running in a long bushing .
Dick Roberts
Abq NM
ice329
11-21-2008, 10:44 AM
Thanks for the info Dick, I apprieciate all the good info. I will readj a few things and maybe get back on the water.
The lube I have been useing is the Grim Racer grease. I think I blew the shaft while on the TS2 when she flipped, the guy at Fullers said sometimes when your at full throtal and it reenters the water like a flip it could bust the shaft. Hopefully that is all it was.
Avanti
11-21-2008, 11:19 AM
Very true
ice329
11-23-2008, 01:01 PM
She is a keeper. Still needs tinkering to get her racable, she is still radical but what fun to drive this bitch. One of these days I will put her up against a stock SV but I will put my dollar on the outboard if I can finish the heat...hehhe Here are a few small vids
Now to pull it all off and get back to the TS2 and see if I can get it where I like it
http://s110.photobucket.com/albums/n103/ice0329/?action=view¤t=MVI_2297-1.mp4
http://s110.photobucket.com/albums/n103/ice0329/?action=view¤t=svob-1.mp4
Ocean Racer
11-24-2008, 12:18 AM
that is pretty sweet. From the video it looks like it slides in the turns or is that just our point of view.
ice329
11-24-2008, 09:47 AM
She drives completely differnt then the stock hardwere. In the second vid you see how it does turn if you want, I think what you see is the way I was driving it. I ran it at least 6 more times after the vids taken and dialed it in actually pretty good. Its just a compleatly differnt ride and I like it.
