View Full Version : Zonda build
ade-rc
05-08-2017, 01:30 PM
New to RC boats, new to this forum, so diving in with a Zonda build.
ade-rc
05-08-2017, 02:08 PM
151413
151414
Blank hull ordered from Hong Kong.
151415
Drive line mock-ups started
Prodrvr
05-08-2017, 08:11 PM
Question...is that motor mount going to fit in the sponson at the correct angle, or do you have to mod it?
Mxkid261
05-08-2017, 09:10 PM
Are you setting this up as a twin?
ade-rc
05-08-2017, 10:34 PM
It has slots in the sides so can be adjusted somewhat. But mod'ing it is also on the table.
ade-rc
05-08-2017, 10:37 PM
Yes twin, other screw is in the picture on the balancer. First ever boat build, so hopefully will be fun building and learning.
hughb
05-09-2017, 01:51 PM
Looks really nice. All the best with you build. I have a CF Zonda too i wish to rebuild when time allows
ade-rc
05-09-2017, 02:40 PM
Thank you. Should be a fun build.
Beaux
05-09-2017, 03:15 PM
Nice going. Good luck, there's a lot of good info on here.
ade-rc
05-09-2017, 06:45 PM
Thanks. Will probably be scanning for build info as it moves along.
ade-rc
05-09-2017, 06:57 PM
151423
RH driveline started. Need to ream out the stinger for the stuffing tube. A bit tight and not going to force it.
Prodrvr
05-09-2017, 08:10 PM
Before you go reaming, what diameter are the shafts and tubes?
ade-rc
05-09-2017, 10:26 PM
Stuffing tube fitted nicely in LH. RH had burrs so reamed them out and fits perfect now. (9/32 brass for 0.187 Teflon)
Beaux
05-10-2017, 09:57 AM
Just checking if you got a left hand drive cable...
ade-rc
05-10-2017, 12:52 PM
Yes a LH and RH. Does anyone have estimates of length change at full RPM
Prodrvr
05-10-2017, 07:25 PM
3/16" cable...leave a 3/16" gap between the end of the stinger and the back of the prop dog.
ade-rc
05-10-2017, 10:07 PM
Thanks, Don't remember seeing gaps that big when researching boat builds. Was planning on maybe 0.040"-0.050" with a Teflon washer. Will need to dig deeper.
fweasel
05-10-2017, 10:47 PM
That's not enough. No real need for the washer if you run a proper gap. I also just use the diameter of the flex as a guide.
ade-rc
05-11-2017, 05:14 PM
Thanks for the info. Will make sure I have enough adjustment in the drive lines to accommodate the gap.
