View Full Version : Lost my steering ?
Leadfingers
04-24-2017, 06:17 PM
Lost the steering on the BJ. it was acting like a weak servo, so I replace it, but it's still doing the same thing and barely moving the servo. Could a bad ESC be the problem?
Any suggestions? Thanks in advance !
Leadfingers
fweasel
04-24-2017, 08:02 PM
What radio and receiver are you using? Does the transmitter have a steering rate/limit setting?
04-24-2017, 08:24 PM
Corroded sockets on the transmitter could be one cause, see if you can clean them. Or a bad BEC in the controller. Pull the red wire on the ESC plug and try an external battery, see if that fixes it.
Leadfingers
04-26-2017, 05:10 PM
I checked the steering limit knob, had no effect.
What is a BEC ?
Thanks. will keep checking.
