View Full Version : my new 1/8 scale Squire Shop neu 1527 1.5y
meangenesracing
04-13-2017, 02:44 PM
long time in the making is my ML Boatworks 1/8 scale
fweasel
04-13-2017, 03:04 PM
I love the different colors on the turbine and exhaust housings of the turbos. And the gold leaf is pretty sweet too. Nice work.
roofintrash
04-13-2017, 03:09 PM
Beautiful boat. Just dead sexy. Great job.
Tamelesstgr
04-13-2017, 03:11 PM
you're not going to put that in the water are you!?
Doug Smock
04-13-2017, 03:15 PM
Sweet ride Geno! Time for some video!
JimClark
04-13-2017, 04:11 PM
Not the exact same boat but my free time right now is to help to restore/rebuild the 1979 Squire Shop. it is quite a project.
150939
meangenesracing
04-13-2017, 04:24 PM
150939
the actual full size boat?
meangenesracing
04-13-2017, 04:26 PM
really don't want to. lol but I will
meangenesracing
04-13-2017, 04:27 PM
Doug, hopefully next Sunday I can get to the lake fingers crossed lol
JimClark
04-13-2017, 04:32 PM
yup the full size original boat
Doug Smock
04-13-2017, 04:39 PM
Very cool Jim!
meangenesracing
04-13-2017, 04:46 PM
[QUOTE=JimClark;688697]yup the full size original boat[/QUOTE NICE, would like to see some pitchers when it's done
JimClark
04-13-2017, 05:06 PM
due to the amount if damage there wasn't much of the original boat that can be used. A lot of hardware Cowling the orig tail and uprights have been found ect. Will take probably two years to get her done.
If you are on facebook you can follow along https://www.facebook.com/groups/1821412644739381/
Moonie
04-15-2017, 05:16 PM
Vary nice!
K.R.Joye
04-19-2017, 12:34 PM
Nice job, miss my old Squire!
meangenesracing
05-16-2017, 08:33 AM
not having very good luck running this boat. first time in the water jumped up right on plain ran great 1.5 laps and stopped got it back to shore did not change anything now it acts like its underpowered can't get on plane. the correct strut depth is even with bottom of sponsons is rhat a correct depth?
meangenesracing
05-16-2017, 08:42 AM
I have a etti 220 speed control 10s lipos is it possible it is not running on the whole 10s?
K.R.Joye
05-16-2017, 09:26 AM
What size prop?
Also is your CG setup to balance on front edge of turn fin?
Was anything hot or smelled funny when you brought it in 1st time it quit. I like those big Ettis have 3 of them. 0nly weak link on them is the short length of area battery leads are soldered on to the boards. They come on soldered if your taxing the controller sometimes.
RandyatBBY
05-16-2017, 11:21 AM
What prop are you running?
meangenesracing
05-16-2017, 12:00 PM
2 5s packs, and a 450/3 prop
meangenesracing
05-16-2017, 12:28 PM
What size prop?
Ken, everything was barely warm my cog is approximately 2" behind sponsons
K.R.Joye
05-16-2017, 12:39 PM
That's a good prop, you have the 5S packs in series correct? Check your packs for dead cells and the battery leads at esc board solder joints.
meangenesracing
05-16-2017, 01:45 PM
correct, in series, and I will check when I get home
specs on the packs??? Maybe your LVC is kicking in.
Doug Smock
05-16-2017, 08:16 PM
He got it going fellas. :wink:
meangenesracing
05-16-2017, 08:25 PM
with a lot of help from Doug lol. so thanks to everyone who gave me input. I think I have one fast boat
CraigP
05-16-2017, 10:28 PM
Fast or not, she's a beauty! Keep it looking good
longballlumber
05-16-2017, 10:37 PM
Soooo..... what was it controller settings?
meangenesracing
05-17-2017, 01:16 PM
I believe the strut was not correct. I did unhook the speed control and rehook it maybe it could have had a loose connection
klloyd67
07-02-2017, 08:48 PM
Are your batteries in the engine well or under deck?
meangenesracing
07-03-2017, 09:24 AM
here you go
cybercrxt
10-11-2017, 10:33 AM
That boat looks awesome Gene. I had built myself the same hull a while back, Doug S. owns it now...Yours looks better, lol! Mike
daveweagel
11-13-2017, 01:47 PM
here you go
do you mean that arc burned connector caused the power loss ?
CraigP
11-13-2017, 02:21 PM
Snapping your connectors and caps is very detrimental to the integrity of both components. It’s actually more harmful to the capacitors. Depending on the size of cap banks used, these surge current can easily go over 1000A! This causes separation of the dielectric from the aluminum, or air pockets in the cap. It’s so unavoidable by using a pre-charge alligator lead with a 10 Ohm resistor in the middle. Many argue this point, but there’s no arguing the cap and connector degradation.
daveweagel
11-13-2017, 02:45 PM
Craig,
thank you for the information.
here's the esc I have in my 8S 1/8 scale.
arcs and snaps every time I connect the red battery cable with the jumper.
the connector is arc burned more than the one in photo above.
I have not water tested my boat yet so I don't know if it will run under load.
please post photo of alligator clip - resistor set up you mentioned
thank you
CraigP
11-13-2017, 03:19 PM
Here’s the cable assembly. The alligators are available on the ose site. The resistor is a 10 Ohm, 1/2w, 5% carbon comp. those specs aren’t critical, should be able to pick up at a local electronics parts house. They are also available from Mouser Electronics, or Mouser.com under part number 791-RC1/2-100JB, very cheap. I clip one side on the loose wire and the other on the connect point. I wait 5 seconds, take off the jumper and plug in. I keep my BEC and ESC OFF until I get the main leads connected, then power up the transmitter, then the boat. If you don’t have switches, then you got to move pretty quick because the caps will get discharged with the electronics ON.
daveweagel
11-13-2017, 08:33 PM
thank you Craig
