View Full Version : Soft or hard start that is the question ??
MAXAMUS
11-16-2008, 08:00 AM
HI ALL
Eventually managed to get my BJ in the water after ETTI 150 amp programming hitches still needs fine adjustments but my question is the default setting is soft start well this morning when on its maiden after a refit and being in dry dock for a good while i hit the gas and the prop spins the boat hardly moved the whammo it took off nearly flipping just don't feel right and the same happened when coming back to shore you just want a smooth throttle and coast in not like a bullet out of a gun
Any guys running similar set up care to chime in
thanks ..........
set up
AMMO 2300
ETTI 150 AMP
X642 PROP
2X 6600MAH 2S 20C LIPO
Jeff Wohlt
11-16-2008, 11:05 AM
I always see soft start and linear throttle settings but not sure until I look at my ETTI manual I have some where. I thought we all used those settings.
MAXAMUS
11-16-2008, 11:29 AM
here is the Etti manual notice the default settings
http://www.himodel.com/en/info/manual/ETTI%20Brushless%20ESC%20Manual.pdf
