View Full Version : I apologize if this is not the place for a suggestion.
lonewolf0420
04-05-2017, 10:17 PM
I had recently Overhauled my Gieco V3 - I upgrade to OSE heavy duty flex cable assembly, and CNC 7075 prop. I used the provided included (cable assembly locking nut and bullet nut)
The torque after 5+ minutes of running, literally loosened and spun off both nuts ( YES I LOST BOTH MY NUTS! ) :)
I might suggest that a nut with nylon is included instead to make assembly more secure.
And yes i was sure everything was tight before running....
04-06-2017, 06:46 AM
I have no control over what Steve sells, but IME you should always use a true lock nut, like these:
https://www.offshoreelectrics.com/proddetail.php?prod=ose-8135
Jam nuts cannot be relied upon to hold a spinning prop. They may work for awhile, but they will eventually fail.
Mxkid261
04-06-2017, 08:21 AM
I ALWAYS put a dab of locktite on the prop shaft threads no matter what kind of nut is on there. Usually just a lock nut is all I use. My buddy runs a bullet with a dab of locktite and that's it. Lost a $50 prop once, never again.
ray schrauwen
04-06-2017, 09:05 AM
I lost a x455 Dsasbota prop using a nylon lock nut, never again. The lock tite will be my new norm with those aircraft lock nuts.
kfxguy
04-06-2017, 10:05 AM
I use loctite too but if you swap props as much as I do, you don't give it a chance to loosen up. Lol. I did lose a prop once using a set screw type bullet nut. I no longer use those.
lonewolf0420
04-06-2017, 11:01 AM
Ouch!
