View Full Version : Upgrade from a stealthwake
be8843
03-09-2017, 03:55 PM
I'm looking to get a bigger boat. I currently have a stealthwake and want something a little bigger. I'm debating between the zelos36 and the voracity. The pond I run in is 110' x 450' and does get a slight chop. Any pros and cons of each would be appreciated. Thank you
Tamelesstgr
03-09-2017, 04:11 PM
From a simplicity standpoint (if you are a relatively new boater) that the Voracity would be better suited to you as a single motor. It's plenty capable of really good speed stock and modified.
fweasel
03-09-2017, 04:33 PM
I own both of those boats. The Voracity likes to run on just the last bit of hull and is more prone to flip, despite it running really fast. It has a really shallow V bottom so it doesn't cut through the chop like you might immediately assume a V-bottom mono would. I find the Zelos easier to run in a more conservative setup with more hull in the water and as a result, more stable. I'm sure if I propped down on the Vracity, it would be more tame, but where's the fun in that? :laugh:
Tameless is right, the single motor setup on the Voracity is cheaper to run, maintain, and upgrade. Can't say you'll have a bad time with either boat. I like them both for different reasons.
be8843
03-09-2017, 05:41 PM
fweasel how stable is the zelos in a light chop?
fweasel
03-09-2017, 06:29 PM
It's all relative honestly. If you're not running these boats, or any boat for that matter, at the bleeding edge of stability, you'll do fine in light chop. In stock trim, both boats will handle light chop just fine and will be reliable runners. How quickly you get bored with out of the box performance and decide you need more is the better question. Some of us have about a single stock run in us before that point is reached. Others have no interest in doing any modifications other than those that increase reliability.
be8843
03-10-2017, 12:06 PM
Good to know. Upgrades would be nice but with my limited pond size speed isn't a concern unfortunately. I'm waiting to buy since they are teasing us with this new boat coming out. Lol
Tamelesstgr
03-10-2017, 12:24 PM
Have you thought about a nice used boat? Lots of opportunities to find a really well upgraded boat for decent money around here and other forums.
fweasel
03-10-2017, 02:14 PM
There's a good deal on a 32" pursuit in the classifieds right now.
be8843
03-10-2017, 06:28 PM
I kind of want to stick with new. Warranties are nice lol. Looks like that pursuit is sold.
Erroneous
03-10-2017, 06:48 PM
Cant really go wrong with the Zelos36. Plenty power out of the box and will stun onlookers. Ive run Vs and Cats and can say Cats are more predictable because they have a wider stance. The Zelos has been proven (although not easy) over 90mph. Small pond might get sketchy but it corners well and scoots out of the hole. I recommend running 4 3s packs for 6s2p.
Erroneous
03-10-2017, 06:53 PM
Small chop, more power and probably 15mph winds. 84mph just fine.:buttrock:https://m.youtube.com/watch?v=TFYVfm_elkA Heres mine.
be8843
03-10-2017, 07:37 PM
Nice!!!
Hemifear
03-11-2017, 01:57 PM
I too own both the Voracity and the Zelos. The Voracity would be better suited for a smaller pond. The Zelos really needs space to stretch her legs. I would consider a Kintec Pursuit as well. Good size, already upgraded and hauls the mail!
be8843
03-11-2017, 02:33 PM
I may end up going with the miss geico. Since it's only one set of electronics to deal with and I could buy a few batteries with the the extra $270.
fweasel
03-11-2017, 03:00 PM
You can run the V3 29" proboat cats on 4S with stock electronics and do about 40mph with a sharpened x642 prop or all the way up to 60mph on an x440/3 prop and 6S with reduced timing on the ESC. Fun boat and handles well.
be8843
03-11-2017, 03:08 PM
Do you know if the rudder is stainless? I was looking at pictures on the proboat site and it looks stainless on the black jack and plastic on the miss geico. Unless they upgraded them with the v3.
fweasel
03-11-2017, 03:11 PM
V3 hardware is black anodized aluminum, on the Geico, Blackjack, and Impulse 31 for that matter. The website picture is incorrect.
Erroneous
03-11-2017, 10:35 PM
V3.. https://m.youtube.com/watch?v=Rxd_qGFopoM
be8843
03-12-2017, 12:18 PM
That's what I figured.
be8843
05-23-2017, 07:20 PM
Bit the bullet and bought a Miss Geico before I can't find one!
fweasel
05-23-2017, 08:46 PM
Fun boat, you're going to enjoy it. Re-plumb the cooling lines first thing: Rudder, ESC in, ESC loop, ESC out, motor lower in, motor upper out, and then out the side of the boat. I also don't like the red grease that comes in the stuffing tube, too thick. I would clean that out and use the blue Proboat stuff after each run.
be8843
05-23-2017, 09:39 PM
Thanks for the plumbing advice. I have plenty blue grease. That's what I did with my stelathwake.
