MikeP323
02-15-2017, 07:14 PM
My motor is a TP 4070 1650KV 5D - V2 - I will be running 6S in this boat which is a 38.5 inch Delta force DF45 MK II.
At the present time the ESC is programmed as follows
LVC - 6 cells LVC per cell - 3.2V Brake Type - No Timing - 6deg. (probably should be four?) Cutoff type - soft Start Type - Soft PWM - 8KHZ
On Start Type I had standard but went to soft to cut the amount of cavitation before the boat hooks up? Perhaps I went the wrong way?
I have not tried this change yet. Also after reading in the forum it would seem that 6 deg. is too high on timing - five deg. is not
offered so perhaps I should drop to four degrees? I do not plan to use the logging feature at this time.
By the way what does PWM stand for?
Any suggestions pro or con with what i have so far would be appreciated. Thanks !! :help:
