View Full Version : lehner 2240/5 help
Jcarlton
01-19-2017, 09:36 AM
hey guys got a awesome deal on a lehner 2240/5 hi amp 2960kv loaded . was wondering if a turnigy 180v3 can handle that motor on 6s ? was thinking about installing on a mg 29 (prolly overkill) ! any ideas or other input would be appreciated !
Todd Fleury
01-19-2017, 11:03 AM
No way will that esc hold up.
Todd Fleury
01-19-2017, 11:04 AM
I run a 2250 - 2603kv lehner with a 250 amp esc and I still peak the amps on 4s
Jcarlton
01-19-2017, 11:16 AM
what esc would you suggest ?
Todd Fleury
01-19-2017, 11:22 AM
That all depends on what you want to spend. But you would need to get something 250+
Jcarlton
01-19-2017, 11:53 AM
what are you running todd ?
T.S.Davis
01-19-2017, 12:20 PM
You'll need more than 250. That's way too many kV for 6s. It's a lot for 4s.
Jcarlton
01-19-2017, 12:49 PM
so whats the best setup in your opinion ? what esc and what batery size ? im new to these lehner motors . was going to run the lehner in a mg 29 with a octurra x438 prop any thoughts ?
Todd Fleury
01-19-2017, 03:28 PM
I run an MGM 250
StevenBryant
01-19-2017, 03:45 PM
You motor would be a good 3s motor maybe 4s but that's gonna be a hot setup. A good speed controller is the MGM 280-26
photohoward1
01-19-2017, 04:38 PM
6s? That motor it to much for 4s. POOF.
Jcarlton
01-20-2017, 08:55 AM
great thanks for the input fellas !!
Jcarlton
03-09-2017, 11:41 AM
ok guys got a good deal on a 200a swordfish pro+ . can this controller handle the lehner 2240/5 on 4s 70c lipo with a 38mm prop on a 36 in cat .
Todd Fleury
03-09-2017, 11:57 AM
That motor is 3255 kv unloaded. That esc will not be able to handle the amp.
Jcarlton
03-09-2017, 12:04 PM
loaded its 2960 kv whats the difference ? and how many amps do you think it will pull on the above setup ?
StevenBryant
03-09-2017, 12:12 PM
I would suggest a 250 amp plus esc, MGM 250 or 280.
RaceMechaniX
03-09-2017, 12:26 PM
That motor can pull North of 400A if loaded hard. However, if propped correctly it should be around 200A.
Very small prop will be required.
Jcarlton
03-09-2017, 12:49 PM
any suggestions on where to start on prop size tyler ?
RaceMechaniX
03-09-2017, 01:58 PM
X440/3, X445, 1816, P220 Something in the range of 40-45mm to start.
Jcarlton
03-09-2017, 03:39 PM
thnx tyler gonna start with a x438 and go from there .
