Meniscus
11-10-2008, 02:11 PM
OK, here it is:
I'm thinking about running two servos on a boat for steering. I have my reasons for needing to use two servos, so let's not get into all of that. I merely have some general questions. Having never done this, I was hoping that someone could point me in the direction of some good info regarding this type of setup? I hope to answer the following questions: :unsure:
How much is the drain on the BEC and can it handle it (I know that this is servo specific a lot of times)?
Do I always need to run a separate batt (in place of BEC) to make this happen?
Any way to adjust center points on the "slave" servo (other than physically moving) (potentiometer circuit)?
Limit on size of servo or drain on BEC and or separate batt (in place of BEC)?
Any throw differences incurred when using different servos in tandem like this?
Interference issues that could be as a result of running current to the servos in various directions (antenna array)?
Go ahead and tell me if I'm off base and I should just wire up a Y and be done with it, LOL!
Thanks for the input.
