View Full Version : UL-1 motor timing
johnnyb5.0
12-07-2016, 12:47 AM
Hey guys I was wondering if anyone has played with the timing on one of these motors and if so what were you able to set it to and not burn up a motor or esc and get a little more out of the motor
thanks John
Revolt Flash
12-07-2016, 05:02 AM
I know 15 works really good on the 1800kv and 2030kv.
longballlumber
12-07-2016, 08:30 AM
It's probably important to note the OEM UL-1 Controller states 10 degrees in their specs.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVSV4&P=7
Later,
Ball
Revolt Flash
12-07-2016, 12:59 PM
longballlumber is correct on what Aquacraft states. I have been running Seaking 120 on the 1800 and a Seaking 180 on 2030 and the temps have been around 110 degrees across the board after about 3 1/2 minutes of running. That's on 6s and 15 on the timing.
johnnyb5.0
12-10-2016, 07:31 PM
ok thanks guys I'm running 4S not 6S so do I assume with less cells more timing isn't an issue or even the other way around ? I want to be safe but was wondering if I can get a little bit more out of the setup
12-10-2016, 08:44 PM
It is the load which determines the timing advance, the more load the more timing is required. The RTR setup is moderate amp draw and works well at ten degrees. I ran my 2030 motor in an aggressive P-LSH and used 15 degrees with great success.
