View Full Version : Outrigger transom bouncing - need help.
RiggerSpeed
11-13-2016, 11:01 PM
Predator outrigger: the rear end is bouncing and isn't stable. It's fine til you get to like 50-100% throttle then it starts bouncing.
Need suggestions on what might be causing this.
-COG off?
-I've moved the battery backwards/rearward 5/8" to help load the rear.
-P735 prop
TRUCKPULL
11-14-2016, 12:58 AM
What motor (size and KV) , batteries, hardware???
We need more info.
Larry
NativePaul
11-14-2016, 02:59 AM
Shaft pointing downwards too much, and/or CoG too far forward, and/or too much prop lift, those P series props don't have that much lift but the more pitch you have the more lift comes with it, you could try cupping the blades and/or an X435 (I would say an X438 for a similar amp draw, but that means swapping to a 3/16 shaft, and lthe lower lift may give you more usable speed anyway (despite having less power available)).
RiggerSpeed
11-14-2016, 07:03 AM
My setup:
3650, 3900kv 5mm shaft
3S, 5000mah Gen Ace
Seaking 120a
Octura P735 prop
NativePaul
11-14-2016, 07:16 AM
x435 will still give you good speed wit that gear when you get it dialed in.
boredom.is.me
11-14-2016, 07:41 AM
Why not an m series prop?
Edit:
I see why.
grsboats
11-14-2016, 11:08 AM
Too much lift with the 735..reduce to X435 with no strut mod to verify how your boat runs....basically your strut must be positioned to 0 degree.Gill
11-14-2016, 06:10 PM
At least part of the problem is the prop. It has less lift than the 1700 series it is based on, but still too much for a modern rigger. Where is the CG? That is the next thing to change, move it back 1/2" to 1" using balast if necessary. How fast do you want to go and how much run time?
coolcarwrench
11-18-2016, 05:29 PM
Photos of you set up could help
