View Full Version : ProBoat Programming Module question
bitton79
11-07-2008, 01:41 PM
Hello,
I want to use lipo's with my bj26. Can anyone please tell me, if i need to progrem the esc with the programming module only once or every time i open the power on.
Thanks' guys.
Meniscus
11-07-2008, 01:56 PM
Once. But for my own piece of mind, I program every 4 or 5 times or so.
Meniscus
11-07-2008, 02:00 PM
Manual is available online here.
http://proboatmodels.com/ProdInfo/Files/PRB3311_Programming_Module.pdf
As a side note, make sure you set the programing card to high voltage cutoff.
bitton79
11-08-2008, 10:01 AM
Thanks' a lot.
Meniscus
11-09-2008, 01:56 AM
No problem! That's what this forum is for.
Chewy6696
09-10-2009, 10:15 PM
I am trying to set up my BL with my new set of lipos. I get the single beep when I turn on with the program card and when I plug esc back into the tx in channel 2 I dont get any throttle. I can stear and that is all. I just put in a new ESC and I am getting nothing.
PLEASE HELP !!
domwilson
09-10-2009, 10:18 PM
Is it the same brand ESC? Try flipping the connector that goes in the receiver.
Chewy6696
09-10-2009, 11:03 PM
it is a new stock ESC
tiqueman
09-11-2009, 01:48 PM
Try simple diagnostics first...
I had a similar problem when I first got mine. The PB reciever went bad after one run. Channel 2 (throttle) died. Unplug, your steering servo and plug your ESC into Ch 1. Power it up and move the steering (wheel or stick) on the controller and see if the motor spins.
animigan
09-12-2009, 12:04 PM
I actually talked to the ProBoat guys about this a while back, and he said that it was normal and you just need to unplug batts and then plug back in for throttle and steering. Sounded weird to me, but it works every time and he said it was just the way it is. Go figure.
Andre
jlr3rd1
09-12-2009, 11:09 PM
Question when using lipos is it best to run on soft timmimg or hard timming?? i am running soft timing?
