View Full Version : Blackjack 29 V3 .187 upgrade shaft
Rayzor31
10-01-2016, 01:12 PM
I purchased the upgrade strut and the .187 upgrade flex shaft for my blackjack 29 v3, can I use the 9/32 brass tubing with the .187 Teflon liner or do i have to use the 1/4 tubing without the liner? Is there enough material to mill the strut or tubing for fitment of the 9/32?
fweasel
10-01-2016, 01:33 PM
for a 3/16" (.187) flexshaft use 9/32" tube w/ .187 liner or 1/4" tube w/o liner. Seems like a lot of work to replace the 1/4" tube already in the hull. I would just pull the teflon liner and run the .187 OSE shaft that way. Looking at the strut on my V3, the nose cone tapers down from 11/32" OD to just a hair over 1/4", so you could probably modify the strut if you felt inclined to go the difficult road.
Rayzor31
10-03-2016, 12:46 PM
The bare shaft on brass tube won't produce too much heat to cause a shaft failure?
Mxkid261
10-03-2016, 01:41 PM
Not if the cable is well greased every run and the motor is aligned perfectly with the stuffing tube. I have 5 boats they all run 3/16 cables with no liners
Blevins
10-04-2016, 02:10 AM
Just remove the Teflon liner and run the 3/16th/.187 shaft on the stock tube. Been doing this for over a year at speeds of nearly 80mph on GPS....
https://www.youtube.com/watch?v=qjxdN6NSCyI
Fixitguy1
01-12-2017, 12:18 PM
what prop are you using looks crazy fast and stable
