View Full Version : Forward Thinking Cyberstorm P-Ltd Mono
properchopper
09-16-2016, 11:32 AM
Steve wanted something more substantial than his previous RtR mono which proved less than durable. I sent him an Insane34 P-Mono that ripped. Next, to compete with some forward thinking racers in a mythical kingdom where they dare to allow a wider selection of "spec" motors, this TP Powered P-Ltd Mono should get him on the podium:thumbup1:
First, a transom doubler of birch ply to reinforce the stock doubler apparantly made of Meunster cheese
146268146269
Big and strong Speedmaster stinger & dual pickup tapered rudder - before and after shortening stinger & raising/trimming rudder
146270146271
tapered tabs & nice racewater-ready turn fins
146272
[continued]
properchopper
09-16-2016, 11:56 AM
TP Power 3630 in CF mount supplemented by "mini-rails" providing much more bonding surface than with mount alone
146273
Leo cooling jacket just fits, comes with large fittings (and required mount to be notched)
146274
Birch ply battery platforms & ESC mounting thingie
146275 146276
OSE Raider 150A ESC - tucks right in & lots'a bang for the buck
146277
[continued]
properchopper
09-16-2016, 12:05 PM
Boat will run 4S2P so integral parallel adapters permanently soldered on ESC
146278
predetermined layout + long battery trays allow CG tuning . Trial balancing worked out using Super Hi-Tech CG-O-Meter thumbup1:
146287 146279
146280
[continued]
properchopper
09-16-2016, 12:13 PM
Steve has some cool graphics planned to finish off the hull and should kick some :censored: on the racecourse with this Forward Thinking Cyberstorm :smile:
146281 146282
Tony
rcboatbuild@hotmail.com
146283
Darin Jordan
09-16-2016, 12:49 PM
Tony, in case on one has told you lately... you ROCK!
Love ya, Bro!! See you in November??
properchopper
09-16-2016, 01:08 PM
Yowzah !!:hug1:
kfxguy
09-16-2016, 01:22 PM
Very nice Tony. Love the color too of course!
Tails Up
09-16-2016, 01:26 PM
Nice work!
785boats
09-16-2016, 03:31 PM
Beautiful set up.
ray schrauwen
09-16-2016, 07:31 PM
Very clean, very pro as always. Glad to sub your thread.
Tamelesstgr
09-18-2016, 09:53 PM
Plan on setting up my next mono exactly the same, clean as always sir!
Mxkid261
09-20-2016, 08:37 AM
Looks great. Think I will have to get that rudder for my DF 29. What does cutting the blade shorter help achieve? Also, what setback is that bracket? Thanks
ray schrauwen
09-20-2016, 10:44 AM
Less rudder = more speed.
properchopper
09-20-2016, 11:43 AM
Ray's correct. Plus, the longer the rudder, the more effect it has on the running attitude (as in pulling the nose down).
The Speedmaster rudder I used for the Cyberstorm is likely to end up being too large for the DF 29. It's huge, heavy and designed for much larger nitro or gasser hulls. Not only is it long, but quite thick. To shorten it's penetration I not only trimmed the bottom shorter, but modded the upper mounting location by cutting some of the top of the blade away and re-drilling the bolt holes to raise it up :
stock blade mounting location:
146410
raised mounting location:
146411
Mxkid261
09-20-2016, 03:00 PM
I does look quite thick now that you mention it. I was planning on using the speedmaster 21 rudder but I wish they had a dual pickup version
modvp55
09-20-2016, 05:18 PM
Looks good Tony. The transom material is called core-mat, much better to reinforce sides and deck than transom.
rayzerdesigns
09-26-2016, 02:45 AM
Gotta talk to you about the angle on ur tutnfins
properchopper
09-26-2016, 10:51 AM
Gotta talk to you about the angle on ur tutnfins��
The angle was derived from the position of Steve Martin's hands at the end of the vid:
https://www.youtube.com/watch?v=P1Hr9VPnMNc
The fins were mocked up for the picture, removed for shipping. Customer will adjust as needed. But thanks:Peace_Sign:
Tamelesstgr
09-26-2016, 02:05 PM
Forgot to add: "That ain't no Prius"
properchopper
09-26-2016, 02:34 PM
:wink:
ray schrauwen
02-18-2017, 11:30 AM
What kv of TP POWER motor did this run on?
What motors are NAMBA & IMPBA approved these days, I'm confused. I know the PB & AQ are still in there.
Will TP shorten the recent can or will it not matter?
properchopper
02-18-2017, 03:35 PM
Answered (1970 KV)
Ray, It's been pouring/flooding here in SoCal and I'll answer only because I'm suffering from cabin fever AND because anytime I start talking about "approved motors" I seem to get flamed for stepping on my [word redacted] so I'll answer only under suspicion of being in a purple haze of rainy-day temporary insanity :
I don't know about IMPBA; perhaps Mr. Smock could chime in
The NAMBA rulz for P-Ltd Specifies this :
149604
This ruleset is MANDATORY for National Records and FE National Point events.
Now here's where it can get "fuzzy" : In general, District racing series or "local" events generally adhere to this ruleset to keep a level playing field for all entrants BUT can make exceptions if they want : e.g. the Dynamite PB 2000KV motor (stock motor for the latest BJ29), while not on the list may be allowed at local Club level (as in SCSTA Legg Lake series) just to create a larger choice for new entrants.
Now This : Some daring, radical revolutionary futurists (probably descendants of those forward thinking rebels who dared to revolt from the Crown back in the 1770's) have proposed (and in some top secret locations and possibly disguised as a band of touring yodel-dancers) began allowing for any P-Ltd any inrunner no bigger around than 36.3 mm and longer than 61.2mm.
I built Steve's boat to race with a Club consisting of these forward thinkers.
[it might matter to the mindset that required me to sand .0625 " off the sponson tips of my Cheetah to meet the 34" max length requirement during record 2-lap trials. :olleyes:
ray schrauwen
02-18-2017, 03:55 PM
Thanks Tony. I hope the rain stops but, you guys need the water!! lol... Take care.
You see, I can get a nice PB DYNM3835 A3630-1500Kv 6-pole for $54 + shipping to Canukistan but a TP will cost me a bit more. I just don't want to go to Michigan or Rochester and have someone get bent that I have a long TP power motor however if the quality is better I'd rather invest in that??
Whatever. I'll just run the PB motors and leave it at that. Even if I bought a TP motor the Michigan guys would never send me packing away, they're pretty cool.
Lets wait and hear from the Winter Warm ups to see if motors were any factor in the racing weekend.
One more Q:
How did you determine trim tab placement? I have those tabs and I want to use them possibly on my Cyberstorm.
I also have a larger set. Sometimes I like to build a mono that can convert from Limited power to full P power. I did it on my DF33 and it works well.
Still on the fence to build it full P power or do it like this for spec racing.... Can't decide...
properchopper
02-18-2017, 04:08 PM
Ray,
I'm of the school of thought that tabs are most called upon at full boogie in a straight line when the hull is fairly aired out (high in the water) so I like tabs to be close to the keel line BUT with the caveat that the prop does best with unobstructed water coming at it minus the effect of the tabs.
ray schrauwen
02-18-2017, 04:21 PM
O.k. thx
properchopper
02-18-2017, 04:40 PM
Ray,
Somehow in a re-edit this answer got left out :
TP Power is aware of the issue with the longer can not meeting the PPPP (PotentiallyPossiblyProposedP-LT) situation and I've been advised that future shipments of the winds of interest to P-Ltd folks will be back in the shorter cans that meet the PPPP. FWIW the longer can D-Wind and one Y-Wind 3630 of interest to boaters have the SAME length stator and rotor as the shorter can versions.
ray schrauwen
03-23-2017, 02:41 PM
How thick of a transom doubler did you use? I'm about to slap one together for P-limited.
properchopper
03-23-2017, 06:47 PM
Ray,
I use 3/32" birch ply from the LHS.
ray schrauwen
03-26-2017, 10:42 AM
Thx for the reply. Checking my wood stocks...
properchopper
03-26-2017, 12:55 PM
Send me your address (again) :smile:
I'll make one & send it to you.
150530
Ignore the hole; just for storage
150533
ray schrauwen
03-26-2017, 01:01 PM
Sure buddy! That would be great.
properchopper
03-26-2017, 01:36 PM
I'll make one today if I can tear myself away (ZZzzzzzzzzzzzzz) from the 200 lap Auto Club Speedway NASCAR extravaganza [ authors message : Martin Truex Jr. # 78 is an IMPBA record holder and occasional Legg Lakester- being a fan of his goes with the territory - He's on the grid starting in 4th qualifying position today]
ray schrauwen
03-26-2017, 07:25 PM
Cool factoid!! No rush, many builds a happening...
Shooter
03-26-2017, 08:29 PM
Martin Truex Jr.!!!! No kidding! How cool! He probably hates turning right!
properchopper
03-28-2017, 07:27 PM
On it's way. To save on postage it's strapped on the back of a northward migrating beaver. Keep a lookout for a furry letter carrier:wink:
150591
ray schrauwen
03-28-2017, 08:00 PM
That's awesome Tony. Muchos gracias!
Let me know if you ever need anything.
ray schrauwen
03-28-2017, 08:06 PM
Just out of curiosity, is the Pursuit windshield the same as the Cyberstorm? They look really close.
I ask since mono Jeff hasn't had time to get back to me and Steve sells the Pursuit windshield in vinyl for 7.99.
Placing an order soon....
properchopper
03-29-2017, 02:04 PM
Ray,
Can't say for sure - never owned a Pursuit -'tho scuttlebut suggests that the Pursuit is a splashed Cyberstorm (although some details of the canopy look different.)
rayzerdesigns
03-29-2017, 02:16 PM
Not the same
Darin Jordan
03-29-2017, 02:34 PM
Ray,
No... definitely not the same... TFL has a longer "flat" in the keel, deeper V, and more plunge in the bow. Part of the reason they run so well when it gets a little rough.
ray schrauwen
03-29-2017, 04:37 PM
That I cannot disagree with however, I'm only concerned with the windshield. :tongue_smilie:
