View Full Version : ML Boatworks THX-305, 30.5" Outboard Tunnel hull design/ build
cybercrxt
09-07-2016, 04:41 PM
Well. some of you may have seen I have been playing around with a 38" and 50" Sport tunnel kit, and those designs are almost complete, so I decided I wanted to continue on with a 30" race FE tunnel design I have played around with for about a year. This is all new, and nothing like the last line of tunnels that PTI now owns, so this will require lots of testing, but I think its going to be a really nice layout for a small tunnel.Should be tons of room. I am working on the cowling design now, but the kit is complete and ready to build. I am not interested in doing other sizes of this tunnel, just this 30.5" FE hull is all I plan to do. To many other cool projects to work on! This is called the THX-305. Here are some 3d images of the hull kit. Enjoy, more soon, Mike
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305b_zpstgdjx0lr.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305_zpskxrl2jh8.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305d_zpsqdfbxc2g.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305a_zpsir3whb6c.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305c_zpsn5u5jurk.jpg
cybercrxt
09-21-2016, 08:53 AM
Well, here goes. I finished up in the garage last night, and pulled this kit out and worked on it till 1am. I have maybe 2 hours in it so far. Easiest tunnel build I have done. Really happy with the build so far, and cannot wait to see how it runs! Here are some pics:
This is where I stopped last night.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_002811_zps56xdzud5.jpg
cybercrxt
09-21-2016, 08:56 AM
Using my portable flat board, and a piece of angle aluminum, you first add the cross members, and bow block plate:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_230458_zpspcce6div.jpg
Then start laminating your transom plates:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_230635_zpsdvpljqx5.jpg
3rd and final plate:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_230747_zpsortkfdka.jpg
Dry fit your middle, and outer forward to aft frames:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_231729_zpsk3dyly67.jpg
Darin Jordan
09-21-2016, 08:58 AM
Following!
cybercrxt
09-21-2016, 09:00 AM
Looks like I lost some pics, but you then dry fit your radio box side plates, and inside deck forward to aft frame, and tack them in place, then slide crossmember plate "A" into the back, and glue in place.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_233944_zpshbu2ewul.jpg
Add the angled front radio box plate:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_233954_zpsloxfpfm9.jpg
Now glue in the steering servo mount sides:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_234252_zpsg54k7tb9.jpg
And the doubled servo mount top plates:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_234406_zpsst7aphpm.jpg
cybercrxt
09-21-2016, 09:02 AM
Now add the rear radio box hatch support plate:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_234549_zpshj6bwrrh.jpg
Pop out the top and pitch it:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_234614_zpstyjih1ig.jpg
Sand the top of the transom and add the hatch deck:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_235125_zpsmqwdxsnl.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_235224_zpsv0jk3vgw.jpg
cybercrxt
09-21-2016, 09:04 AM
Now repeat for the front hatch, and you will need to sand at an angle, the front end of the hatch recessed support to get it in place:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160920_235625_zpszsckwuqe.jpg
Sand the top of the radio box, and finally add the radio box front lid. (Be sure to remove the center of the recessed hatch support and discard.)
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_000304_zpsrt9vs0ij.jpg
Here it is with the sponson frames tacked up. More on that later.
cybercrxt
09-21-2016, 09:06 AM
1/4" diameter dowels will ultimately be added in 3 locations, all the way through the hull, and they will be supported against a hoop system in the sponsons:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_002822_zpsetllm3wg.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_002836_zpsx96jvbjv.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_002927_zpsy7ltkrvx.jpg
The new logo!
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_003216_zpsgjinbewi.jpg
cybercrxt
09-22-2016, 09:57 AM
Started on the sponsons, here are some pics:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_201202_zps4hwc74aj.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_201209_zpskxhbr0yc.jpg
Basswood strips added:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_201715_zpsfytwbyc1.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_201722_zpswfsymfhz.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_202134_zpsbfy4uppl.jpg
cybercrxt
09-22-2016, 09:58 AM
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_202139_zpskureaxw4.jpg
Glue on the outer strip. The lower side lines up with the main support from from forward to aft.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_202327_zpsvf4np2k5.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_203112_zpsovtcqy8c.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_203116_zpsfep7cnah.jpg
cybercrxt
09-22-2016, 09:59 AM
Very pleased with the lines on this one!
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_205307_zpsd52hophp.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_205316_zpskctmplp4.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_205328_zpsifn3prwd.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160921_205341_zpsc8yzr88q.jpg
cybercrxt
09-23-2016, 04:26 PM
Here is the cowling design I think I am going to do for this hull:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305f_zpsqzqhdsen.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/THX305e_zpsl8dgsws8.jpg
cybercrxt
09-26-2016, 08:55 AM
Sheeting templates made for the ride surfaces and sponson decks, and u can see the little rounded rear corner, I love little detailing, haha
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/IMG_20160924_55228_zpstkpob0is.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/IMG_20160924_0426_zpsmbl6ubtq.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/IMG_20160924_8545_zpscgjbwpld.jpg
cybercrxt
09-27-2016, 08:58 AM
The dowel lock loops work great keeping the sponsons square to the tunnel. You can see how well the ride pads sit on the granite board...dead square! Test fitting some recovery pads, they will be silicone on as i want to test various designs. That is one thing I never spent enough time on those with the past lineup, something Paul at PTI perfected on those hulls, so I need to do the same on this one.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160926_193253_zpsgoofqtdx.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160926_194657_zpseak9mvtc.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160926_194732_zpsh7qp83mm.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160926_194741_zpsw1wldk8g.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20160926_195625_zpsi2384qk0.jpg
cybercrxt
10-04-2016, 12:05 PM
Got the cowling plug framing in today. Should look real nice one the mold is done.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161004_115119_zpseqhcudse.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161004_115126_zpsk4pi72hj.jpg
cybercrxt
10-06-2016, 09:52 AM
Cowling plug is moving along. Got the foam in, and glass coat added. Next I will sand, add filler, and prime, and see where its at!
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161005_192208_zpsjcbpphcr.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161005_194839_zpso4diisjo.jpg
cybercrxt
10-07-2016, 10:21 AM
Plug is getting closer:
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161007_072958_zps2rk87mhv.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161007_073012_zps6z9ewtcy.jpg
cybercrxt
10-25-2016, 10:31 AM
Cowling plug getting close.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/920201684729_zpsybpu7fn3.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/92020168479_zps8llggt7u.jpg
cybercrxt
12-18-2016, 08:19 PM
Finished the cowling plug for the THX305 tunnel! Mold should happen this week.
cybercrxt
12-19-2016, 09:01 AM
The THX-305 cowling plug is now almost ready. I added the parting board, and cleaned up the base connection, and got another Duratec coat added this weekend. I should have this plug done this week. Mike
http://i42.photobucket.com/albums/e324/spoonefcrx/RSX240%20Rigger/20161218_183839_zpsuqqvnds6.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/RSX240%20Rigger/20161218_183828_zpsdduwyzth.jpg
rayzerdesigns
12-19-2016, 04:12 PM
U are the man
cybercrxt
12-31-2016, 05:57 PM
Finishing up the mold this weekend for the cowling. Wont be long!
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161231_094542_zpstahzhxrj.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161231_145004_zpsuki8o0ky.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20161231_145057_zps6zdwqseo.jpg
cybercrxt
01-06-2017, 04:28 PM
First cowling is out of the mold, and its slick as glass! Mike
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_070307_zpsmewwvti7.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_070259_zps7ni5habj.jpg
cybercrxt
01-09-2017, 12:11 PM
Aright, Here it is! Looks so freakin sweet. I cannot wait to get this one up and running! Mike
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_203820_zpskjargwyr.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_203830_zpsfsqbyfde.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_203748_zpsg3ac7oxd.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_203846_zpsmheapvb3.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170106_213828_zpss5w1tvoe.jpg
cybercrxt
01-09-2017, 12:15 PM
Also, This is the reason anyone can handle building this hull easily. Its pretty hard to mess up the sponson to center section bonding with the dowel and loop technique. it forces a 90 degree angle with the center section to inside sponson edge.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170107_122827_zps7xq4rzjb.jpg
Darin Jordan
01-09-2017, 12:23 PM
Simply BEAUTIFUL WORK!
Shooter
01-09-2017, 10:31 PM
I agree. You certainly have mastered the trade. Looks great.
cybercrxt
01-12-2017, 08:45 AM
Thanks guys!
rayzerdesigns
01-18-2017, 05:13 PM
Get it done yet
cybercrxt
01-19-2017, 11:30 AM
Heck no, always something going on. its on my workbench waiting to receive the top decks and epoxy tho.
cybercrxt
03-30-2017, 08:17 AM
https://forums.offshoreelectrics.com/cache.php?img=http%3A%2F%2Fi42.photobucket.com%2Fa lbums%2Fe324%2Fspoonefcrx%2FTHX305%2F20170322_2014 02_zpsqzneazyn.jpg
https://forums.offshoreelectrics.com/cache.php?img=http%3A%2F%2Fi42.photobucket.com%2Fa lbums%2Fe324%2Fspoonefcrx%2FTHX305%2F20170322_2014 18_zps7uftormn.jpg
https://forums.offshoreelectrics.com/cache.php?img=http%3A%2F%2Fi42.photobucket.com%2Fa lbums%2Fe324%2Fspoonefcrx%2FTHX305%2F20170322_2014 50_zpsydsp7b6y.jpg
Built in servo tray:
https://forums.offshoreelectrics.com/cache.php?img=http%3A%2F%2Fi42.photobucket.com%2Fa lbums%2Fe324%2Fspoonefcrx%2FTHX305%2F20170322_2014 31_zpsht8frcij.jpg
cybercrxt
03-30-2017, 08:18 AM
Got some clear on this one, and the canopy fitted, and its ready to head out to it's new owner.
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170329_184630_zpsenmukaeu.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170329_184647_zpssyzjov51.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170329_184718_zpsah5o7zrc.jpg
http://i42.photobucket.com/albums/e324/spoonefcrx/THX305/20170329_184615_zpsz9pzdu3q.jpg
