FastVee
07-12-2016, 10:07 AM
Just ordered 2xTurnigy Marine 180A esc´s for my big cat project(expresscraft thunderbolt)
http://forums.offshoreelectrics.com/showthread.php?43036-50-quot-Thunderbolt-with-twins/page2
The motors are SK3 helidrive T600-1250kv
Cant find that much info on these but I think they have 25 /steps when rotating 360 deg.
edit:new version of this motor:
Specs.
Turns: 6T
Voltage: 6S~10S Lipoly
RPM/V: 1250kv
Motor Poles: 8
Internal resistance: 0.0077 Ohm
Max Loading: 115A
Max Power: 4250W
Shaft Diameter: 6mm
Shaft Length: 21mm
Screw Mounting Spacing: 25mm/30mm (M4)
Weight: 372g
Motor Plug: 4mm Bullet Connector
http://www.hobbyking.com/hobbyking/store/__55497__RotorStar_Brushless_Outrunner_Helicopter_ 4956_1250kv_550_600_50_size_heli_.html
thinking 15deg timing to try?
Specs.
Turns: 6T
RPM/V: 1250kv
Motor Poles: 8
Max Loading: 115A
Max Power: 4250W
Shaft Diameter: 6mm
Shaft Length: 21mm
Weight: 372g
